    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 9.0k Views 3 Watching
      I would look at this docker setup
      https://gitlab.com/khassel/magicmirror
      Otherwise run container in serveronly mode and use chrome on the pi to view the app.
      • L Offline
        lpt2007 @sdetweil
        @sdetweil said in Does magicmirror need minimal X11 to run?:
        @lpt2007 graphical stuff not loaded in container.
        I added needed graphical libraries, now I get this error:
        /root/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /root/MagicMirror/node_modules/electron/dist/electron)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.10.1 start script.
        npm ERR!     /root/.npm/_logs/2020-01-16T19_00_47_796Z-debug.log
          sdetweil @lpt2007
          @lpt2007 need more libraries.
          I’d run serveronly in the container, and use chromium from outside the container
          • L Offline
            lpt2007 @sdetweil
            Thanks, but this is not an option, because I try to use mm as addon for Home Assistant and I use hassos image. The mm will be one of the systems I will use on rpi and I will call them trough ha when I need them.
            Any idea what error I posted means?
            S 3 Replies Last reply Reply Quote 0
              sdetweil @lpt2007
              @lpt2007 said in Does magicmirror need minimal X11 to run?:
              yes, u need more libraries loaded into the container…
                sdetweil @lpt2007
                @lpt2007 use the other docker image I posted a link to… it ‘supposedly’ works… but depends on a security breach in my opinion,
                letting a container write directly to the docker host XWIndows
                  sdetweil @lpt2007
                  i don’t really understand, as BOTH approaches will require some browser to be running ON the HASSOS image ALL THE TIME… (somewhere)
                  • L Offline
                    lpt2007 @sdetweil
                    This library is already installed.
                      sdetweil @lpt2007
                      https://github.com/electron/electron/issues/16364
                      • L Offline
                        lpt2007 @sdetweil
                        not the right one
                        I installed this one:
                        root@local-mm:/# apt install libdbus-1-3
                        Reading package lists... Done
                        Building dependency tree
                        libdbus-1-3 is already the newest version (1.10.28-0+deb9u1).
                          sdetweil @lpt2007
                          @lpt2007 i don’t know… the error says its not right.
                          I don’t know how to solve it…
                          again, I would go look at that other docker container which does what you want (maybe)
                          • L Offline
                            lpt2007 @sdetweil
                            Container with mm must connect to host display. I made something simmilar with kodi media center in docker container.
                              sdetweil @lpt2007
                              @lpt2007 ok, and why does chrome on the hassos not work?
                              • L Offline
                                lpt2007 @sdetweil
                                Maybe I can try to made ha addon with chrome in kiosk mode to see where the problem is?
                                • L Offline
                                  lpt2007
                                  Thanks for your time @sdetweil :)
                                  I will first try docker container from link you posted before. One of scenario is about:
                                  Scenario 2: Using docker on the raspberry pi and starting the magicmirror on the screen of the pi.
                                  I will post results back.
                                  • L Offline
                                    lpt2007 @lpt2007
                                    Again without success :(
                                    Error:
                                    (electron:41): Gtk-WARNING **: cannot open display: unix:0.0
                                      sdetweil @lpt2007
                                      @lpt2007 yeh, its a tricky, not really supported approach
                                      I personally wouldn’t even try it
                                      • L Offline
                                        lpt2007
                                        Maybe the problem is host os, not a container?
                                        • L Offline
                                          lpt2007
                                          Problem is host os. I downloaded latest raspbian buster image and followed guide from the link. Works like charm in docker container and display picture to host hdmi.
                                            sdetweil @lpt2007
                                            @lpt2007 now, if you go back to the 1st docker image, and then open a browser on the host connecting to
                                            http://docker_container_ip:exposed_port
                                            you will get the same results…
