    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 7.9k Views 3 Watching
      sdetweil @lpt2007
      @lpt2007 if u want to run it on the same system, yes, it is a graphical application,
      if you want to access the server from a remote system (only) , then no… it can run in serveronly mode
      for pi 0, the local embedded browser (electron) is no longer available for the version of node now being provided, so we drop back to serveronly mode and use chromium-browser to run the mirror locally, but that requires graphical mode
      as most users don’t know all this, i updated the run-start.sh script to do all this for you.
      if no X11, (system in console mode) then run in serveronly
      • L Offline
        lpt2007
        I try to run it in docker container with gui on my pi . But when I start it, there is no output to HDMI. MM starts in server mode no matter what I do.
          sdetweil @lpt2007
          @lpt2007 said in Does magicmirror need minimal X11 to run?:
          which docker container?
          the linked one starts MM in serveronly inside the container and then u use a browser on the outside of the container to access to exposed port.
          there is a second docker solution that uses the fact that one can SEE and ACCESS the docker runtime and launches electron to push content out to the X11 gui… this is really cheating…
          but there was a fix created
          replace the run-start.sh with this one from the next release
          https://raw.githubusercontent.com/MichMich/MagicMirror/develop/run-start.sh
          • L Offline
            lpt2007 @sdetweil
            @sdetweil said in Does magicmirror need minimal X11 to run?:
            I changed run-start.sh file and now I get this error:
            > magicmirror@2.10.1 start /root/MagicMirror
            > ./run-start.sh
            /root/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
            npm ERR! code ELIFECYCLE
            npm ERR! syscall spawn
            npm ERR! file sh
            npm ERR! errno ENOENT
            npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
            npm ERR! spawn ENOENT
            npm ERR!
            npm ERR! Failed at the magicmirror@2.10.1 start script.
            npm ERR!     /root/.npm/_logs/2020-01-15T11_40_27_011Z-debug.log
              sdetweil @lpt2007
              @lpt2007 graphical stuff not loaded in container.
                I would look at this docker setup
                https://gitlab.com/khassel/magicmirror
                Otherwise run container in serveronly mode and use chrome on the pi to view the app.
                • L Offline
                  lpt2007 @sdetweil
                  I added needed graphical libraries, now I get this error:
                  /root/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /root/MagicMirror/node_modules/electron/dist/electron)
                  npm ERR! errno 1
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR!     /root/.npm/_logs/2020-01-16T19_00_47_796Z-debug.log
                    sdetweil @lpt2007
                    @lpt2007 need more libraries.
                    I’d run serveronly in the container, and use chromium from outside the container
                    • L Offline
                      lpt2007 @sdetweil
                      Thanks, but this is not an option, because I try to use mm as addon for Home Assistant and I use hassos image. The mm will be one of the systems I will use on rpi and I will call them trough ha when I need them.
                      Any idea what error I posted means?
                      S 3 Replies Last reply Reply Quote 0
                        sdetweil @lpt2007
                        yes, u need more libraries loaded into the container…
