    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 9.2k Views 3 Watching
    • L Offline
      lpt2007 @sdetweil
      @sdetweil said in Does magicmirror need minimal X11 to run?:
      @lpt2007 graphical stuff not loaded in container.
      I added needed graphical libraries, now I get this error:
      /root/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /root/MagicMirror/node_modules/electron/dist/electron)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.10.1 start script.
      npm ERR!     /root/.npm/_logs/2020-01-16T19_00_47_796Z-debug.log
        sdetweil @lpt2007
        @lpt2007 need more libraries.
        I’d run serveronly in the container, and use chromium from outside the container
        • L Offline
          lpt2007 @sdetweil
          Thanks, but this is not an option, because I try to use mm as addon for Home Assistant and I use hassos image. The mm will be one of the systems I will use on rpi and I will call them trough ha when I need them.
          Any idea what error I posted means?
          S 3 Replies Last reply Reply Quote 0
            sdetweil @lpt2007
            @lpt2007 said in Does magicmirror need minimal X11 to run?:
            yes, u need more libraries loaded into the container…
              sdetweil @lpt2007
              @lpt2007 use the other docker image I posted a link to… it ‘supposedly’ works… but depends on a security breach in my opinion,
              letting a container write directly to the docker host XWIndows
                sdetweil @lpt2007
                i don’t really understand, as BOTH approaches will require some browser to be running ON the HASSOS image ALL THE TIME… (somewhere)
                • L Offline
                  lpt2007 @sdetweil
                  This library is already installed.
                    sdetweil @lpt2007
                    https://github.com/electron/electron/issues/16364
                    • L Offline
                      lpt2007 @sdetweil
                      not the right one
                      I installed this one:
                      root@local-mm:/# apt install libdbus-1-3
                      Reading package lists... Done
                      Building dependency tree
                      libdbus-1-3 is already the newest version (1.10.28-0+deb9u1).
                        sdetweil @lpt2007
                        @lpt2007 i don’t know… the error says its not right.
                        I don’t know how to solve it…
                        again, I would go look at that other docker container which does what you want (maybe)
                        • L Offline
                          lpt2007 @sdetweil
                          Container with mm must connect to host display. I made something simmilar with kodi media center in docker container.
                            sdetweil @lpt2007
                            @lpt2007 ok, and why does chrome on the hassos not work?
                            • L Offline
                              lpt2007 @sdetweil
                              Maybe I can try to made ha addon with chrome in kiosk mode to see where the problem is?
                              • L Offline
                                lpt2007
                                Thanks for your time @sdetweil :)
                                I will first try docker container from link you posted before. One of scenario is about:
                                Scenario 2: Using docker on the raspberry pi and starting the magicmirror on the screen of the pi.
                                I will post results back.
                                • L Offline
                                  lpt2007 @lpt2007
                                  Again without success :(
                                  Error:
                                  (electron:41): Gtk-WARNING **: cannot open display: unix:0.0
                                    sdetweil @lpt2007
                                    @lpt2007 yeh, its a tricky, not really supported approach
                                    I personally wouldn’t even try it
                                    • L Offline
                                      lpt2007
                                      Maybe the problem is host os, not a container?
                                      • L Offline
                                        lpt2007
                                        Problem is host os. I downloaded latest raspbian buster image and followed guide from the link. Works like charm in docker container and display picture to host hdmi.
                                          sdetweil @lpt2007
                                          @lpt2007 now, if you go back to the 1st docker image, and then open a browser on the host connecting to
                                          http://docker_container_ip:exposed_port
                                          you will get the same results…
