    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 9.2k Views 3 Watching
    • L Offline
      lpt2007
      I try to run it in docker container with gui on my pi . But when I start it, there is no output to HDMI. MM starts in server mode no matter what I do.
        sdetweil @lpt2007
        @lpt2007 said in Does magicmirror need minimal X11 to run?:
        which docker container?
        the linked one starts MM in serveronly inside the container and then u use a browser on the outside of the container to access to exposed port.
        there is a second docker solution that uses the fact that one can SEE and ACCESS the docker runtime and launches electron to push content out to the X11 gui… this is really cheating…
        but there was a fix created
        replace the run-start.sh with this one from the next release
        https://raw.githubusercontent.com/MichMich/MagicMirror/develop/run-start.sh
        • L Offline
          lpt2007 @sdetweil
          @sdetweil said in Does magicmirror need minimal X11 to run?:
          I changed run-start.sh file and now I get this error:
          > magicmirror@2.10.1 start /root/MagicMirror
          > ./run-start.sh
          /root/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
          npm ERR! code ELIFECYCLE
          npm ERR! syscall spawn
          npm ERR! file sh
          npm ERR! errno ENOENT
          npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
          npm ERR! spawn ENOENT
          npm ERR!
          npm ERR! Failed at the magicmirror@2.10.1 start script.
          npm ERR!     /root/.npm/_logs/2020-01-15T11_40_27_011Z-debug.log
            sdetweil @lpt2007
            @lpt2007 graphical stuff not loaded in container.
              I would look at this docker setup
              https://gitlab.com/khassel/magicmirror
              Otherwise run container in serveronly mode and use chrome on the pi to view the app.
              • L Offline
                lpt2007 @sdetweil
                I added needed graphical libraries, now I get this error:
                /root/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /root/MagicMirror/node_modules/electron/dist/electron)
                npm ERR! errno 1
                npm ERR! Exit status 1
                npm ERR!
                npm ERR!     /root/.npm/_logs/2020-01-16T19_00_47_796Z-debug.log
                  sdetweil @lpt2007
                  @lpt2007 need more libraries.
                  I’d run serveronly in the container, and use chromium from outside the container
                  • L Offline
                    lpt2007 @sdetweil
                    Thanks, but this is not an option, because I try to use mm as addon for Home Assistant and I use hassos image. The mm will be one of the systems I will use on rpi and I will call them trough ha when I need them.
                    Any idea what error I posted means?
                    S 3 Replies Last reply Reply Quote 0
                      sdetweil @lpt2007
                      yes, u need more libraries loaded into the container…
                        sdetweil @lpt2007
                        @lpt2007 use the other docker image I posted a link to… it ‘supposedly’ works… but depends on a security breach in my opinion,
                        letting a container write directly to the docker host XWIndows
                          sdetweil @lpt2007
                          i don’t really understand, as BOTH approaches will require some browser to be running ON the HASSOS image ALL THE TIME… (somewhere)
                          • L Offline
                            lpt2007 @sdetweil
                            This library is already installed.
                              sdetweil @lpt2007
                              https://github.com/electron/electron/issues/16364
                              • L Offline
                                lpt2007 @sdetweil
                                not the right one
                                I installed this one:
                                root@local-mm:/# apt install libdbus-1-3
                                Reading package lists... Done
                                Building dependency tree
                                libdbus-1-3 is already the newest version (1.10.28-0+deb9u1).
                                  sdetweil @lpt2007
                                  @lpt2007 i don’t know… the error says its not right.
                                  I don’t know how to solve it…
                                  again, I would go look at that other docker container which does what you want (maybe)
                                  • L Offline
                                    lpt2007 @sdetweil
                                    Container with mm must connect to host display. I made something simmilar with kodi media center in docker container.
                                      sdetweil @lpt2007
                                      @lpt2007 ok, and why does chrome on the hassos not work?
                                      • L Offline
                                        lpt2007 @sdetweil
                                        Maybe I can try to made ha addon with chrome in kiosk mode to see where the problem is?
                                        • L Offline
                                          lpt2007
                                          Thanks for your time @sdetweil :)
                                          I will first try docker container from link you posted before. One of scenario is about:
                                          Scenario 2: Using docker on the raspberry pi and starting the magicmirror on the screen of the pi.
                                          I will post results back.
                                          • L Offline
                                            lpt2007 @lpt2007
                                            Again without success :(
                                            Error:
                                            (electron:41): Gtk-WARNING **: cannot open display: unix:0.0
