    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 7.9k Views 3 Watching
    • L Offline
      lpt2007 @sdetweil
      @sdetweil said in Does magicmirror need minimal X11 to run?:
      replace the run-start.sh with this one from the next release
      https://raw.githubusercontent.com/MichMich/MagicMirror/develop/run-start.sh
      I changed run-start.sh file and now I get this error:
      > magicmirror@2.10.1 start /root/MagicMirror
      > ./run-start.sh
      /root/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.10.1 start script.
      npm ERR!     /root/.npm/_logs/2020-01-15T11_40_27_011Z-debug.log
        sdetweil @lpt2007
        @lpt2007 graphical stuff not loaded in container.
          I would look at this docker setup
          https://gitlab.com/khassel/magicmirror
          Otherwise run container in serveronly mode and use chrome on the pi to view the app.
          • L Offline
            lpt2007 @sdetweil
            I added needed graphical libraries, now I get this error:
            /root/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /root/MagicMirror/node_modules/electron/dist/electron)
            npm ERR! errno 1
            npm ERR! Exit status 1
            npm ERR!
            npm ERR!     /root/.npm/_logs/2020-01-16T19_00_47_796Z-debug.log
              sdetweil @lpt2007
              @lpt2007 need more libraries.
              I’d run serveronly in the container, and use chromium from outside the container
              • L Offline
                lpt2007 @sdetweil
                Thanks, but this is not an option, because I try to use mm as addon for Home Assistant and I use hassos image. The mm will be one of the systems I will use on rpi and I will call them trough ha when I need them.
                Any idea what error I posted means?
                S 3 Replies Last reply Reply Quote 0
                  sdetweil @lpt2007
                  @lpt2007 said in Does magicmirror need minimal X11 to run?:
                  yes, u need more libraries loaded into the container…
                    sdetweil @lpt2007
                    @lpt2007 use the other docker image I posted a link to… it ‘supposedly’ works… but depends on a security breach in my opinion,
                    letting a container write directly to the docker host XWIndows
                      sdetweil @lpt2007
                      i don’t really understand, as BOTH approaches will require some browser to be running ON the HASSOS image ALL THE TIME… (somewhere)
                      • L Offline
                        lpt2007 @sdetweil
                        This library is already installed.
