    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 8.0k Views 3 Watching
    • L Offline
      lpt2007
      Thanks for your time @sdetweil :)
      I will first try docker container from link you posted before. One of scenario is about:
      Scenario 2: Using docker on the raspberry pi and starting the magicmirror on the screen of the pi.
      I will post results back.
      • L Offline
        lpt2007 @lpt2007
        @lpt2007 said in Does magicmirror need minimal X11 to run?:
        Again without success :(
        Error:
        (electron:41): Gtk-WARNING **: cannot open display: unix:0.0
          sdetweil @lpt2007
          @lpt2007 yeh, its a tricky, not really supported approach
          I personally wouldn’t even try it
          • L Offline
            lpt2007
            Maybe the problem is host os, not a container?
            • L Offline
              lpt2007
              Problem is host os. I downloaded latest raspbian buster image and followed guide from the link. Works like charm in docker container and display picture to host hdmi.
                sdetweil @lpt2007
                @lpt2007 now, if you go back to the 1st docker image, and then open a browser on the host connecting to
                http://docker_container_ip:exposed_port
                you will get the same results…
                • 3 / 3
