Navigation
    • Search
    UNSOLVED Remote Control doesn't work for me, Please help!
    Troubleshooting
    • J
      justlearning last edited by sdetweil
      Hi everyone/anyone.
      Hoping if anyone can provide some guidance for me. I have the latest version of MM2 installed with Buster. I have managed to get everything I wanted up and running except MMM-Remote control. I get the common error that you normally get when something isnt right and it wont display. I have copied from the https://github.com/Jopyth/MMM-Remote-Control using the following:
          module: 'MMM-Remote-Control'
          // uncomment the following line to show the URL of the remote control on the mirror
          // , position: 'bottom_left'
          // you can hide this module afterwards from the remote control itself
              customCommand: {},  // Optional, See "Using Custom Commands" below
              customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              apiKey: "",         // Optional, See API/README.md for details
      I also need to mention this is my 2nd day learning this, so I know I have much to learn. I have no clue why I can’t get the remote to work. I also tried to follow https://www.youtube.com/watch?v=539zmAJREe4 on youtube. I really don’t what I am doing wrong. If anyone can assist that would be awesome!
      Thank you for reading this and your time & wisdom.
      Best Regards,
      F
      1 Reply Last reply Reply Quote -1
      • T
        ttarzan last edited by
        @justlearning I think it’s just missing a comma in the first line. Try
        modules: ‘MMM Remote Control’,
        • A
          Alloc last edited by Alloc
          Please use the </> when posting code
          My guess is that your problem is within point 3.
          (3) For security reasons, the MagicMirror (and therefore the Remote Control) is not reachable externally. To change this, configure address, and ipWhitelist in your config.js (see these lines in the sample config). For
          example change address to 0.0.0.0 and add two allowed devices with IP-Adresses 192.168.0.42 and 192.168.0.50:
          address : ‘0.0.0.0’,
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.0.42”, “::ffff:192.168.0.50”],"
          You can also add multiple devices in an IP range (e.g. all devices with 192.168.0.X):
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/120", "192.168.0.1/24"],
          • J
            justlearning @Alloc last edited by lavolp3
            @Alloc Thanks for the advice, I have now gotten to the point , its showing that the : HTTP://ip-of-your-mirror:8080/remote.html this is what I see. Here is all my code now:
            Thanks to anyone that can solve my stupidity!
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	//address: "localhost", // Address to listen on, can be:
            	address: "0.0.0.0",
            	port: 8080,
            	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
            	ipWhitelist: [], // Set [] to allow all IP addresses
            	language: "en",
            	timeFormat: 12,
            	units: "metric",
            			     // false, default for all  NON-armv6l devices
            			module: "alert",
            			module: "updatenotification",
            			position: "bottom_bar"
            			module: "clock",
            			position: "top_left"
            			header: "Canadian Holidays",
            						symbol: "calendar-check",
            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/canada_Holidays.ics"					}
                    disabled: false,
                    module: 'MMM-Lunartic',
                    position: 'top_right', // Best in left, center, or right regions
                        mode: "rotating", // rotating or static
                        image: "animation", // animation, current, DayNight or static
                        distance: "km", // miles or km
            	    sounds: "no", // howling wolf, only on a full moon
                        useHeader: false, // true if you want a header
                        header: "The Lunartic is in my head", // Any text you want
                        maxWidth: "300px",
                        animationSpeed: 0,
                        rotateInterval: 15000,
              module: "MMM-GooglePhotos",
              position: "center",
                albumId: ["XXXXXXXXXXXXXXXXXXX"], // your album id(s) from result of `auth_and_test.js`
                refreshInterval: 1000*60,
                scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
                //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
                sort: "time", //'time', 'reverse', 'random'
                showWidth: "800px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                showHeight: "600px",
                originalWidthPx: 800, // original size of loaded image. (related with image quality)
                originalHeightPx: 600, // Bigger size gives you better quality, but can give you network burden.
                opacity: 1, // target "opacity" property (https://www.w3schools.com/cssref/css3_pr_opacity.asp)
                mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            					position: "bottom_right",
            				locationID: "6173331",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				appid: "XXXXXXXXXXXXXX"
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				appid: "XXXXXXXXXXXXX"
                        apiKey: ''
                module: 'MMM-Remote-Control',
                 //uncomment the following line to show the URL of the remote control on the mirror
                 position: 'bottom_left',
              module: "MMM-NowPlayingOnSpotify",
              position: "bottom_left",
                clientID: "XXXXXXXXXXXXXXXXXXXXX",
                clientSecret: "XXXXXXXXXXXXXXX",
                accessToken: "XXXXXXXXXXXXXXXXX",
                refreshToken: "XXXXXXXXXXXXX"
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "Canada News",
            						url: "https://www.ctvnews.ca/rss/ctvnews-ca-canada-public-rss-1.822284"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
            A lavolp3 2 Replies Last reply Reply Quote 0
            • A
              Alloc @justlearning last edited by
              @justlearning I would edit that out, because it shows all your API secrets.
              Fx. Spotify
              lavolp3 1 Reply Last reply Reply Quote 0
              • lavolp3
                lavolp3 Module Developer @Alloc last edited by
                @Alloc @justlearning I have removed some sensitive information
                • lavolp3
                  lavolp3 Module Developer @justlearning last edited by lavolp3
                  @justlearning said in Remote Control doesn't work for me, Please help!:
                  its showing that the : HTTP://ip-of-your-mirror:8080/remote.html this is what I see.Here is all my code now:
                  What is the remaining problem? What happens if you visit the site in your browser?
