    Fresh install but pm2 error
    37 Posts 2 Posters 11.0k Views 2 Watching
      sdetweil @Hubschra01
      @Hubschra01 yes
      do
      pm2 logs --lines=100
      • H Offline
        Hubschra01 @sdetweil
        [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
        /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
        0|MagicMir | npm ERR! code ELIFECYCLE
        0|MagicMir | npm ERR! errno 1
        0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
        0|MagicMir | npm ERR! Exit status 1
        0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
        0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        0|MagicMir |
        0|MagicMir | npm ERR! A complete log of this run can be found in:
        0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log
        /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
        0|MagicMir |
        0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
        0|MagicMir | > ./run-start.sh
        0|MagicMir |
        0|MagicMir |
        0|MagicMir |
        0|MagicMir | [17:37:28.657] [LOG] Starting MagicMirror: v2.10.1
        0|MagicMir | [17:37:28.673] [LOG] Loading config …
        0|MagicMir | [17:37:28.686] [LOG] Loading module helpers …
        0|MagicMir | [17:37:28.689] [LOG] No helper found for module: alert.
        0|MagicMir | [17:37:28.825] [LOG] Initializing new module helper …
        0|MagicMir | [17:37:28.827] [LOG] Module helper loaded: updatenotification
        0|MagicMir | [17:37:28.829] [LOG] No helper found for module: clock.
        0|MagicMir | [17:37:30.081] [LOG] Initializing new module helper …
        0|MagicMir | [17:37:30.082] [LOG] Module helper loaded: calendar
        0|MagicMir | [17:37:30.083] [LOG] No helper found for module: currentweather.
        0|MagicMir | [17:37:30.084] [LOG] No helper found for module: weatherforecast.
        0|MagicMir | [17:37:30.172] [LOG] Initializing new module helper …
        0|MagicMir | [17:37:30.173] [LOG] Module helper loaded: newsfeed
        0|MagicMir | [17:37:30.173] [LOG] All module helpers loaded.
        0|MagicMir | [17:37:30.175] [LOG] Starting server on port 8080 …
        0|MagicMir | [17:37:30.199] [LOG] Server started …
        0|MagicMir | [17:37:30.201] [LOG] Connecting socket for: updatenotification
        0|MagicMir | [17:37:30.202] [LOG] Connecting socket for: calendar
        0|MagicMir | [17:37:30.204] [LOG] Starting node helper for: calendar
        0|MagicMir | [17:37:30.205] [LOG] Connecting socket for: newsfeed
        0|MagicMir | [17:37:30.206] [LOG] Starting module: newsfeed
        0|MagicMir | [17:37:30.207] [LOG] Sockets connected & modules started …
        0|MagicMir | [17:37:30.821] [LOG] Launching application.
          @Hubschra01 said in Fresh install but pm2 error:
          yeh,
          there are two launches,
          1 ended at 2020-01-21T16_37_02_810Z
          1 still running,
          • H Offline
            I restart the Mirror again an no there are no Errors in the Log. :-)
            I can´t post the log because Akismet mark this as span… wierd
            Thanks Sam
              @Hubschra01 no problem… glad we got it working…
              –lines=nnn only shows the last nnn lines, so old errors could be above that
              • H Offline
                I Think the errors come if i reboot the Mirror by
                sudo reboot
                without to stop the mirror.
                the log show
                PM2| 2020-01-22T17:48:05: PM2 log: Stop watching MagicMirror
                PM2| 2020-01-22T17:48:05: PM2 log: Stopping app:MagicMirror id:0
                PM2| 2020-01-22T17:48:05: PM2 log: pid=802 msg=failed to kill - retrying in 100ms
                PM2| 2020-01-22T17:48:05: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2| 2020-01-22T17:48:05: PM2 log: pid=802 msg=process killed
                PM2| 2020-01-22T17:48:06: PM2 log: PM2 successfully stopped
                If i do this
                pm2 stop MagicMirror
                sudo reboot
                after reboot the log show this
                PM2| 2020-01-22T17:51:13: PM2 log: pm2 has been killed by signal, dumping process list before exit...
                PM2| 2020-01-22T17:51:13: PM2 log: Exited peacefully
                I can´t post the log because Akismet mark this as spam… wierd
                  @Hubschra01 yes, askimet is a pain…
                  thanks for your information…
                  I suspect the other bad failure info is reboot after just npm start
                  • 4 / 4
