    Fresh install but pm2 error
    37 Posts 2 Posters 11.0k Views 2 Watching
      sdetweil @Hubschra01
      @Hubschra01 weird… delete that instance
      pm2 delete 0
      then run my fixup script
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
      • H Offline
        Hubschra01 @sdetweil
        PM2        | 2020-01-21T11:38:39: PM2 log: Node.js version      : 10.18.1
        PM2        | 2020-01-21T11:38:39: PM2 log: Current arch         : arm
        PM2        | 2020-01-21T11:38:39: PM2 log: PM2 home             : /home/pi/.pm2
        PM2        | 2020-01-21T11:38:39: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
        PM2        | 2020-01-21T11:38:39: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
        PM2        | 2020-01-21T11:38:39: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
        PM2        | 2020-01-21T11:38:39: PM2 log: Application log path : /home/pi/.pm2/logs
        PM2        | 2020-01-21T11:38:39: PM2 log: Worker Interval      : 30000
        PM2        | 2020-01-21T11:38:39: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
        PM2        | 2020-01-21T11:38:39: PM2 log: Concurrent actions   : 2
        PM2        | 2020-01-21T11:38:39: PM2 log: SIGTERM timeout      : 1600
        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
        0|MagicMir | + arch=armv7l
        0|MagicMir | + false=false
        0|MagicMir | ++ grep -i serveronly:
        0|MagicMir | ++ awk '{print tolower($2)}'
        0|MagicMir | ++ tr -d ',"'\'''
        0|MagicMir | ++ grep -v '^\s//' config/config.js
        0|MagicMir | + serveronly=
        0|MagicMir | + serveronly=false
        0|MagicMir | ++ pgrep Xorg
        0|MagicMir | + xorg=429
        0|MagicMir | ++ uname
        0|MagicMir | + mac=Linux
        0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']'
        0|MagicMir | + '[' 429. == . -a Linux '!=' Darwin ']'
        0|MagicMir | + electron js/electron.js
        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|MagicMir | [11:38:49.100] [LOG]    Module helper loaded: calendar
        0|MagicMir | [11:38:49.101] [LOG]    No helper found for module: currentweather.
        0|MagicMir | [11:38:49.103] [LOG]    No helper found for module: weatherforecast.
        0|MagicMir | [11:38:49.191] [LOG]    Initializing new module helper ...
        0|MagicMir | [11:38:49.192] [LOG]    Module helper loaded: newsfeed
        0|MagicMir | [11:38:49.193] [LOG]    All module helpers loaded.
        0|MagicMir | [11:38:49.195] [LOG]    Starting server on port 8080 ...
        0|MagicMir | [11:38:49.218] [LOG]    Server started ...
        0|MagicMir | [11:38:49.220] [LOG]    Connecting socket for: updatenotification
        0|MagicMir | [11:38:49.222] [LOG]    Connecting socket for: calendar
        0|MagicMir | [11:38:49.223] [LOG]    Starting node helper for: calendar
        0|MagicMir | [11:38:49.225] [LOG]    Connecting socket for: newsfeed
        0|MagicMir | [11:38:49.226] [LOG]    Starting module: newsfeed
        0|MagicMir | [11:38:49.227] [LOG]    Sockets connected & modules started ...
        0|MagicMir | [11:38:49.889] [LOG]    Launching application.
        0|MagicMirror  | [11:38:53.980] [LOG]
        0|MagicMirror  | Create new calendar fetcher for url
          @Hubschra01 that looks good now, right?
          • H Offline
            I think so, if this below is not an Error.
            But what caused the error or what was the mistake?
              @Hubschra01 u can remove the -x from run-start.sh 1st line.
              That is just debugging
              • H Offline
                Strange…
                I flushed the log and i remove the -x from the run-start.sh.
                after reboot i see this in the log again.
                0|MagicMir | npm ERR! code ELIFECYCLE
                0|MagicMir | npm ERR! errno 1
                0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                0|MagicMir | npm ERR! Exit status 1
                0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
                0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                0|MagicMir |
                0|MagicMir | npm ERR! A complete log of this run can be found in:
                0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log
                1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                2 info using npm@6.13.4
                3 info using node@v10.18.1
                5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
                10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
                11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
                12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
                13 verbose stack Exit status 1
                13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                13 verbose stack     at EventEmitter.emit (events.js:198:13)
                13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                13 verbose stack     at ChildProcess.emit (events.js:198:13)
                13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                14 verbose pkgid magicmirror@2.10.1
                15 verbose cwd /home/pi/MagicMirror
                16 verbose Linux 4.19.75-v7+
                17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                18 verbose node v10.18.1
                19 verbose npm  v6.13.4
                20 error code ELIFECYCLE
                21 error errno 1
                22 error magicmirror@2.10.1 start: `./run-start.sh`
                22 error Exit status 1
                23 error Failed at the magicmirror@2.10.1 start script.
                23 error This is probably not a problem with npm. There is likely additional logging output above.
                24 verbose exit [ 1, true ]
                weird:pouting_face:
                  @Hubschra01 and the mirror did not start?
                  • H Offline
                    The Mirror start an work fine now. :-) Thanks to you
                    So i have to consider the error in the log as normal?
                      @Hubschra01 i wonder if that is the shutdown log, on the reboot…
                      but there should be more on restart
                      • H Offline
                        if i understand you right your oppinion is that this error meassage is the shutdown message and not a start up error?
                        • 3 / 4
