    Fresh install but pm2 error
    37 Posts 2 Posters 14.8k Views 2 Watching
      sdetweil @Hubschra01
      @Hubschra01 weird…
      can u change line 1 of run-start.sh to
      #!/bin/bash -x
      do pm2 flush
      and then reboot
      then show the pm2 logs --lines=100
      this has got to be a permissions error
      • H
        Hubschra01 @sdetweil
        here it is…
        PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] exited with code                      [2] via signal [SIGINT]
        PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
        PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] online
        PM2        | 2020-01-20T16:05:31: PM2 log: Stopping app:MagicMirror id:0
        PM2        | 2020-01-20T16:05:31: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
        PM2        | 2020-01-20T16:05:32: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
        PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
        PM2        | 2020-01-20T16:05:33: PM2 log: Process with pid 1305 still alive aft                     er 1600ms, sending it SIGKILL now...
        PM2        | 2020-01-20T16:05:33: PM2 log: App [MagicMirror:0] exited with code                      [0] via signal [SIGKILL]
        PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=process killed
        PM2        | 2020-01-20T16:05:33: PM2 log: PM2 successfully stopped
        PM2        | 2020-01-20T16:05:48: PM2 log: =====================================                     ==========================================
        PM2        | 2020-01-20T16:05:48: PM2 log: --- New PM2 Daemon started ----------                     ------------------------------------------
        PM2        | 2020-01-20T16:05:48: PM2 log: Time                 : Mon Jan 20 202                     0 16:05:48 GMT+0100 (GMT+01:00)
        PM2        | 2020-01-20T16:05:48: PM2 log: PM2 version          : 4.2.1
        PM2        | 2020-01-20T16:05:48: PM2 log: Node.js version      : 10.18.1
        PM2        | 2020-01-20T16:05:48: PM2 log: Current arch         : arm
        PM2        | 2020-01-20T16:05:48: PM2 log: PM2 home             : /home/pi/.pm2
        PM2        | 2020-01-20T16:05:48: PM2 log: PM2 PID file         : /home/pi/.pm2/                     pm2.pid
        PM2        | 2020-01-20T16:05:48: PM2 log: RPC socket file      : /home/pi/.pm2/                     rpc.sock
        PM2        | 2020-01-20T16:05:48: PM2 log: BUS socket file      : /home/pi/.pm2/                     pub.sock
        PM2        | 2020-01-20T16:05:48: PM2 log: Application log path : /home/pi/.pm2/                     logs
        PM2        | 2020-01-20T16:05:48: PM2 log: Worker Interval      : 30000
        PM2        | 2020-01-20T16:05:48: PM2 log: Process dump file    : /home/pi/.pm2/                     dump.pm2
        PM2        | 2020-01-20T16:05:48: PM2 log: Concurrent actions   : 2
        PM2        | 2020-01-20T16:05:48: PM2 log: SIGTERM timeout      : 1600
        PM2        | 2020-01-20T16:05:48: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
        PM2        | 2020-01-20T16:05:49: PM2 log: App [MagicMirror:0] online
        /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
        0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi'
        0|MagicMir | ./run-start.sh: Zeile 68: `fi'
        0|MagicMir | npm ERR! code ELIFECYCLE
        0|MagicMir | npm ERR! errno 2
        0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
        0|MagicMir | npm ERR! Exit status 2
        0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
        0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely a                     dditional logging output above.
        0|MagicMir |
        0|MagicMir | npm ERR! A complete log of this run can be found in:
        0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T15_05_29_835Z-debug.log
        0|MagicMir | + ./untrack-css.sh
        0|MagicMir | + '[' -z :0 ']'
        0|MagicMir | ++ uname -m
        0|MagicMir | + arch=armv7l
        0|MagicMir | + false=false
        0|MagicMir | ++ grep -v '^\s//' config/config.js
        0|MagicMir | ++ grep -i serveronly:
        0|MagicMir | ++ tr -d ',"'\'''
        0|MagicMir | ++ awk '{print tolower($2)}'
        0|MagicMir | + serveronly=
        0|MagicMir | + serveronly=false
        0|MagicMir | ++ pgrep Xorg
        0|MagicMir | + xorg=
        0|MagicMir | + mac=Linux
        0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']'
        0|MagicMir | + '[' . == . -a Linux '!=' Darwin ']'
        0|MagicMir | + '[' false. == true. -o . == . ']'
        0|MagicMir | + node serveronly
        0|MagicMir | + xorg=437
        0|MagicMir | + '[' 437. == . -a Linux '!=' Darwin ']'
        0|MagicMir | + electron js/electron.js
        /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
        0|MagicMir |
        0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
        0|MagicMir | > ./run-start.sh
        0|MagicMir |
        0|MagicMir | [16:05:33.029] [LOG]    Starting MagicMirror: v2.10.1
        0|MagicMir | [16:05:33.045] [LOG]    Loading config ...
        0|MagicMir | [16:05:33.054] [LOG]    Loading module helpers ...
        0|MagicMir | [16:05:33.057] [LOG]    No helper found for module: alert.
        0|MagicMir | [16:05:33.129] [LOG]    Initializing new module helper ...
        0|MagicMir | [16:05:33.131] [LOG]    Module helper loaded: updatenotification
        0|MagicMir | [16:05:33.132] [LOG]    No helper found for module: clock.
        0|MagicMir |
        0|MagicMir |
        0|MagicMir | [16:05:56.837] [LOG]    Starting MagicMirror: v2.10.1
        0|MagicMir | [16:05:56.853] [LOG]    Loading config ...
        0|MagicMir | [16:05:56.872] [LOG]    Loading module helpers ...
        0|MagicMir | [16:05:56.875] [LOG]    No helper found for module: alert.
        0|MagicMir | [16:05:57.006] [LOG]    Initializing new module helper ...
        0|MagicMir | [16:05:57.012] [LOG]    Module helper loaded: updatenotification
        0|MagicMir | [16:05:57.014] [LOG]    No helper found for module: clock.
        0|MagicMir | [16:05:58.224] [LOG]    Initializing new module helper ...
        0|MagicMir | [16:05:58.225] [LOG]    Module helper loaded: calendar
        0|MagicMir | [16:05:58.226] [LOG]    No helper found for module: currentweather.
        0|MagicMir | [16:05:58.227] [LOG]    No helper found for module: weatherforecast                     .
        0|MagicMir | [16:05:58.315] [LOG]    Initializing new module helper ...
        0|MagicMir | [16:05:58.316] [LOG]    Module helper loaded: newsfeed
        0|MagicMir | [16:05:58.316] [LOG]    All module helpers loaded.
        0|MagicMir | [16:05:58.318] [LOG]    Starting server on port 8080 ...
        0|MagicMir | [16:05:58.341] [LOG]    Server started ...
        0|MagicMir | [16:05:58.343] [LOG]    Connecting socket for: updatenotification
        0|MagicMir | [16:05:58.345] [LOG]    Connecting socket for: calendar
        0|MagicMir | [16:05:58.346] [LOG]    Starting node helper for: calendar
        0|MagicMir | [16:05:58.347] [LOG]    Connecting socket for: newsfeed
        0|MagicMir | [16:05:58.349] [LOG]    Starting module: newsfeed
        0|MagicMir | [16:05:58.349] [LOG]    Sockets connected & modules started ...
        0|MagicMir | [16:05:59.000] [LOG]    Launching application.
        0|MagicMir | [16:06:02.809] [LOG]    Create new calendar fetcher for url: https:
          @Hubschra01 said in Fresh install but pm2 error:
          0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi’
          there is the problem, syntax error…
          can show the run-start.sh
          I have to leave in about 15 minutes for the rest of the day
          • H
            here is the run-start.sh
            #!/bin/bash -x
              # use bash instead of sh
            ./untrack-css.sh
            if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
            	export DISPLAY=:0 # Set by default display
            fi
            # get the processor architecture
            arch=$(uname -m)
            false='false'
            # get the config option, if any
            # only check non comment lines
            serveronly=$(grep -v '^\s//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\')
            # set default if not defined in config
            serveronly=${serveronly:-false}
            # check for xwindows running
            xorg=$(pgrep Xorg)
            #check for macOS
            mac=$(uname)
            # if the user requested serveronly OR
            #    electron support for armv6l has been dropped OR
            #    system is in text mode
            if [ "$serveronly." != "false." -o  "$arch" == "armv6l" ] ||  [ "$xorg." == "." -a $mac != 'Darwin' ]; then
            	# if user explicitly configured to run server only (no ui local)
            	# OR there is no xwindows running, so no support for browser graphics
            	if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
            	  # start server mode,
            	  node serveronly
            	else
            		# start the server in the background
            		# wait for server to be ready
            		# need bash for this
            		exec 3< <(node serveronly)
            		# Read the output of server line by line until one line 'point your browser'
            		while read line; do
            			 case "$line" in
            			 *point\ your\ browser*)
            					echo $line
            					break
            					echo $line
            					#sleep .25
            			 esac
            		done <&3
            		# Close the file descriptor
            		exec 3<&-
            		# lets use chrome to display here now
            		# get the server port address from the ready message
            		port=$(echo $line | awk -F\: '{print $4}')
            		# start chromium
            		echo "Starting chromium browser now, have patience, it takes a minute"
            		chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
            		exit
            	fi
            else
            	# we can use electron directly
            	electron js/electron.js $1;
            fi
              @Hubschra01 i don’t know… weird… don’t have more time today
                Are u running two copies?
                pm2 status
                • H
                  Hubschra01
                  No it is only one to see…
                  pi@raspberrypi:~/MagicMirror $ pm2 status
                  │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                  │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                    @Hubschra01 weird… delete that instance
                    pm2 delete 0
                    then run my fixup script
                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                    • H
                      PM2        | 2020-01-21T11:38:39: PM2 log: Node.js version      : 10.18.1
                      PM2        | 2020-01-21T11:38:39: PM2 log: Current arch         : arm
                      PM2        | 2020-01-21T11:38:39: PM2 log: PM2 home             : /home/pi/.pm2
                      PM2        | 2020-01-21T11:38:39: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                      PM2        | 2020-01-21T11:38:39: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                      PM2        | 2020-01-21T11:38:39: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                      PM2        | 2020-01-21T11:38:39: PM2 log: Application log path : /home/pi/.pm2/logs
                      PM2        | 2020-01-21T11:38:39: PM2 log: Worker Interval      : 30000
                      PM2        | 2020-01-21T11:38:39: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                      PM2        | 2020-01-21T11:38:39: PM2 log: Concurrent actions   : 2
                      PM2        | 2020-01-21T11:38:39: PM2 log: SIGTERM timeout      : 1600
                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                      0|MagicMir | + xorg=429
                      0|MagicMir | + '[' 429. == . -a Linux '!=' Darwin ']'
                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | [11:38:49.100] [LOG]    Module helper loaded: calendar
                      0|MagicMir | [11:38:49.101] [LOG]    No helper found for module: currentweather.
                      0|MagicMir | [11:38:49.103] [LOG]    No helper found for module: weatherforecast.
                      0|MagicMir | [11:38:49.191] [LOG]    Initializing new module helper ...
                      0|MagicMir | [11:38:49.192] [LOG]    Module helper loaded: newsfeed
                      0|MagicMir | [11:38:49.193] [LOG]    All module helpers loaded.
                      0|MagicMir | [11:38:49.195] [LOG]    Starting server on port 8080 ...
                      0|MagicMir | [11:38:49.218] [LOG]    Server started ...
                      0|MagicMir | [11:38:49.220] [LOG]    Connecting socket for: updatenotification
                      0|MagicMir | [11:38:49.222] [LOG]    Connecting socket for: calendar
                      0|MagicMir | [11:38:49.223] [LOG]    Starting node helper for: calendar
                      0|MagicMir | [11:38:49.225] [LOG]    Connecting socket for: newsfeed
                      0|MagicMir | [11:38:49.226] [LOG]    Starting module: newsfeed
                      0|MagicMir | [11:38:49.227] [LOG]    Sockets connected & modules started ...
                      0|MagicMir | [11:38:49.889] [LOG]    Launching application.
                      0|MagicMirror  | [11:38:53.980] [LOG]
                      0|MagicMirror  | Create new calendar fetcher for url
                        @Hubschra01 that looks good now, right?
                        • H
                          I think so, if this below is not an Error.
                          But what caused the error or what was the mistake?
                            @Hubschra01 u can remove the -x from run-start.sh 1st line.
                            That is just debugging
                            • H
                              Strange…
                              I flushed the log and i remove the -x from the run-start.sh.
                              after reboot i see this in the log again.
                              0|MagicMir | npm ERR! errno 1
                              0|MagicMir | npm ERR! Exit status 1
                              0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                              0|MagicMir |
                              0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log
                              1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                              2 info using npm@6.13.4
                              3 info using node@v10.18.1
                              5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                              6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                              7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                              8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                              9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
                              10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
                              11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
                              12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                              13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
                              13 verbose stack Exit status 1
                              13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                              13 verbose stack     at EventEmitter.emit (events.js:198:13)
                              13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                              13 verbose stack     at ChildProcess.emit (events.js:198:13)
                              13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                              13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                              14 verbose pkgid magicmirror@2.10.1
                              15 verbose cwd /home/pi/MagicMirror
                              16 verbose Linux 4.19.75-v7+
                              17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                              18 verbose node v10.18.1
                              19 verbose npm  v6.13.4
                              20 error code ELIFECYCLE
                              21 error errno 1
                              22 error magicmirror@2.10.1 start: `./run-start.sh`
                              22 error Exit status 1
                              23 error Failed at the magicmirror@2.10.1 start script.
                              23 error This is probably not a problem with npm. There is likely additional logging output above.
                              24 verbose exit [ 1, true ]
                              weird:pouting_face:
                                @Hubschra01 and the mirror did not start?
                                • H
                                  The Mirror start an work fine now. :-) Thanks to you
                                  So i have to consider the error in the log as normal?
                                    @Hubschra01 i wonder if that is the shutdown log, on the reboot…
                                    but there should be more on restart
                                    • H
                                      if i understand you right your oppinion is that this error meassage is the shutdown message and not a start up error?
                                        @Hubschra01 yes
                                        do
                                        • H
                                          0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir | [17:37:28.657] [LOG] Starting MagicMirror: v2.10.1
                                          0|MagicMir | [17:37:28.673] [LOG] Loading config …
                                          0|MagicMir | [17:37:28.686] [LOG] Loading module helpers …
                                          0|MagicMir | [17:37:28.689] [LOG] No helper found for module: alert.
                                          0|MagicMir | [17:37:28.825] [LOG] Initializing new module helper …
                                          0|MagicMir | [17:37:28.827] [LOG] Module helper loaded: updatenotification
                                          0|MagicMir | [17:37:28.829] [LOG] No helper found for module: clock.
                                          0|MagicMir | [17:37:30.081] [LOG] Initializing new module helper …
                                          0|MagicMir | [17:37:30.082] [LOG] Module helper loaded: calendar
                                          0|MagicMir | [17:37:30.083] [LOG] No helper found for module: currentweather.
                                          0|MagicMir | [17:37:30.084] [LOG] No helper found for module: weatherforecast.
                                          0|MagicMir | [17:37:30.172] [LOG] Initializing new module helper …
                                          0|MagicMir | [17:37:30.173] [LOG] Module helper loaded: newsfeed
                                          0|MagicMir | [17:37:30.173] [LOG] All module helpers loaded.
                                          0|MagicMir | [17:37:30.175] [LOG] Starting server on port 8080 …
                                          0|MagicMir | [17:37:30.199] [LOG] Server started …
                                          0|MagicMir | [17:37:30.201] [LOG] Connecting socket for: updatenotification
                                          0|MagicMir | [17:37:30.202] [LOG] Connecting socket for: calendar
                                          0|MagicMir | [17:37:30.204] [LOG] Starting node helper for: calendar
                                          0|MagicMir | [17:37:30.205] [LOG] Connecting socket for: newsfeed
                                          0|MagicMir | [17:37:30.206] [LOG] Starting module: newsfeed
                                          0|MagicMir | [17:37:30.207] [LOG] Sockets connected & modules started …
                                          0|MagicMir | [17:37:30.821] [LOG] Launching application.
                                            yeh,
                                            there are two launches,
                                            1 ended at 2020-01-21T16_37_02_810Z
                                            1 still running,
