    Fresh install but pm2 error
    37 Posts 2 Posters 13.3k Views 2 Watching
    • H Offline
      Hubschra01 @sdetweil
      here is the run-start.sh
      #!/bin/bash -x
        # use bash instead of sh
      ./untrack-css.sh
      if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
      	export DISPLAY=:0 # Set by default display
      fi
      # get the processor architecture
      arch=$(uname -m)
      false='false'
      # get the config option, if any
      # only check non comment lines
      serveronly=$(grep -v '^\s//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\')
      # set default if not defined in config
      serveronly=${serveronly:-false}
      # check for xwindows running
      xorg=$(pgrep Xorg)
      #check for macOS
      mac=$(uname)
      # if the user requested serveronly OR
      #    electron support for armv6l has been dropped OR
      #    system is in text mode
      if [ "$serveronly." != "false." -o  "$arch" == "armv6l" ] ||  [ "$xorg." == "." -a $mac != 'Darwin' ]; then
      	# if user explicitly configured to run server only (no ui local)
      	# OR there is no xwindows running, so no support for browser graphics
      	if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
      	  # start server mode,
      	  node serveronly
      	else
      		# start the server in the background
      		# wait for server to be ready
      		# need bash for this
      		exec 3< <(node serveronly)
      		# Read the output of server line by line until one line 'point your browser'
      		while read line; do
      			 case "$line" in
      			 *point\ your\ browser*)
      					echo $line
      					break
      					echo $line
      					#sleep .25
      			 esac
      		done <&3
      		# Close the file descriptor
      		exec 3<&-
      		# lets use chrome to display here now
      		# get the server port address from the ready message
      		port=$(echo $line | awk -F\: '{print $4}')
      		# start chromium
      		echo "Starting chromium browser now, have patience, it takes a minute"
      		chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
      		exit
      	fi
      else
      	# we can use electron directly
      	electron js/electron.js $1;
      fi
        sdetweil @Hubschra01
        @Hubschra01 i don’t know… weird… don’t have more time today
          Are u running two copies?
          pm2 status
          • H Offline
            Hubschra01
            No it is only one to see…
            pi@raspberrypi:~/MagicMirror $ pm2 status
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
              @Hubschra01 weird… delete that instance
              pm2 delete 0
              then run my fixup script
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
              • H Offline
                PM2        | 2020-01-21T11:38:39: PM2 log: Node.js version      : 10.18.1
                PM2        | 2020-01-21T11:38:39: PM2 log: Current arch         : arm
                PM2        | 2020-01-21T11:38:39: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2020-01-21T11:38:39: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2020-01-21T11:38:39: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2020-01-21T11:38:39: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2020-01-21T11:38:39: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2020-01-21T11:38:39: PM2 log: Worker Interval      : 30000
                PM2        | 2020-01-21T11:38:39: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2020-01-21T11:38:39: PM2 log: Concurrent actions   : 2
                PM2        | 2020-01-21T11:38:39: PM2 log: SIGTERM timeout      : 1600
                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                0|MagicMir | + arch=armv7l
                0|MagicMir | + false=false
                0|MagicMir | ++ grep -i serveronly:
                0|MagicMir | ++ awk '{print tolower($2)}'
                0|MagicMir | ++ tr -d ',"'\'''
                0|MagicMir | ++ grep -v '^\s//' config/config.js
                0|MagicMir | + serveronly=
                0|MagicMir | + serveronly=false
                0|MagicMir | ++ pgrep Xorg
                0|MagicMir | + xorg=429
                0|MagicMir | ++ uname
                0|MagicMir | + mac=Linux
                0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']'
                0|MagicMir | + '[' 429. == . -a Linux '!=' Darwin ']'
                0|MagicMir | + electron js/electron.js
                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|MagicMir | [11:38:49.100] [LOG]    Module helper loaded: calendar
                0|MagicMir | [11:38:49.101] [LOG]    No helper found for module: currentweather.
                0|MagicMir | [11:38:49.103] [LOG]    No helper found for module: weatherforecast.
                0|MagicMir | [11:38:49.191] [LOG]    Initializing new module helper ...
                0|MagicMir | [11:38:49.192] [LOG]    Module helper loaded: newsfeed
                0|MagicMir | [11:38:49.193] [LOG]    All module helpers loaded.
                0|MagicMir | [11:38:49.195] [LOG]    Starting server on port 8080 ...
                0|MagicMir | [11:38:49.218] [LOG]    Server started ...
                0|MagicMir | [11:38:49.220] [LOG]    Connecting socket for: updatenotification
                0|MagicMir | [11:38:49.222] [LOG]    Connecting socket for: calendar
                0|MagicMir | [11:38:49.223] [LOG]    Starting node helper for: calendar
                0|MagicMir | [11:38:49.225] [LOG]    Connecting socket for: newsfeed
                0|MagicMir | [11:38:49.226] [LOG]    Starting module: newsfeed
                0|MagicMir | [11:38:49.227] [LOG]    Sockets connected & modules started ...
                0|MagicMir | [11:38:49.889] [LOG]    Launching application.
                0|MagicMirror  | [11:38:53.980] [LOG]
                0|MagicMirror  | Create new calendar fetcher for url
                  @Hubschra01 that looks good now, right?
                  • H Offline
                    I think so, if this below is not an Error.
                    But what caused the error or what was the mistake?
                      @Hubschra01 u can remove the -x from run-start.sh 1st line.
                      That is just debugging
                      • H Offline
                        Strange…
                        I flushed the log and i remove the -x from the run-start.sh.
                        after reboot i see this in the log again.
                        0|MagicMir | npm ERR! code ELIFECYCLE
                        0|MagicMir | npm ERR! errno 1
                        0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                        0|MagicMir | npm ERR! Exit status 1
                        0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
                        0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        0|MagicMir |
                        0|MagicMir | npm ERR! A complete log of this run can be found in:
                        0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log
                        1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                        2 info using npm@6.13.4
                        3 info using node@v10.18.1
                        5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                        6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                        7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                        8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                        9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
                        10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
                        11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
                        12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                        13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
                        13 verbose stack Exit status 1
                        13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                        13 verbose stack     at EventEmitter.emit (events.js:198:13)
                        13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                        13 verbose stack     at ChildProcess.emit (events.js:198:13)
                        13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                        13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                        14 verbose pkgid magicmirror@2.10.1
                        15 verbose cwd /home/pi/MagicMirror
                        16 verbose Linux 4.19.75-v7+
                        17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                        18 verbose node v10.18.1
                        19 verbose npm  v6.13.4
                        20 error code ELIFECYCLE
                        21 error errno 1
                        22 error magicmirror@2.10.1 start: `./run-start.sh`
                        22 error Exit status 1
                        23 error Failed at the magicmirror@2.10.1 start script.
                        23 error This is probably not a problem with npm. There is likely additional logging output above.
                        24 verbose exit [ 1, true ]
                        weird:pouting_face:
                          @Hubschra01 and the mirror did not start?
                          • H Offline
                            The Mirror start an work fine now. :-) Thanks to you
                            So i have to consider the error in the log as normal?
                              @Hubschra01 i wonder if that is the shutdown log, on the reboot…
                              but there should be more on restart
                              • H Offline
                                if i understand you right your oppinion is that this error meassage is the shutdown message and not a start up error?
                                  @Hubschra01 yes
                                  do
                                  pm2 logs --lines=100
                                  • H Offline
                                    /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                                    0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                                    0|MagicMir |
                                    /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                    0|MagicMir |
                                    0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                                    0|MagicMir | > ./run-start.sh
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir | [17:37:28.657] [LOG] Starting MagicMirror: v2.10.1
                                    0|MagicMir | [17:37:28.673] [LOG] Loading config …
                                    0|MagicMir | [17:37:28.686] [LOG] Loading module helpers …
                                    0|MagicMir | [17:37:28.689] [LOG] No helper found for module: alert.
                                    0|MagicMir | [17:37:28.825] [LOG] Initializing new module helper …
                                    0|MagicMir | [17:37:28.827] [LOG] Module helper loaded: updatenotification
                                    0|MagicMir | [17:37:28.829] [LOG] No helper found for module: clock.
                                    0|MagicMir | [17:37:30.081] [LOG] Initializing new module helper …
                                    0|MagicMir | [17:37:30.082] [LOG] Module helper loaded: calendar
                                    0|MagicMir | [17:37:30.083] [LOG] No helper found for module: currentweather.
                                    0|MagicMir | [17:37:30.084] [LOG] No helper found for module: weatherforecast.
                                    0|MagicMir | [17:37:30.172] [LOG] Initializing new module helper …
                                    0|MagicMir | [17:37:30.173] [LOG] Module helper loaded: newsfeed
                                    0|MagicMir | [17:37:30.173] [LOG] All module helpers loaded.
                                    0|MagicMir | [17:37:30.175] [LOG] Starting server on port 8080 …
                                    0|MagicMir | [17:37:30.199] [LOG] Server started …
                                    0|MagicMir | [17:37:30.201] [LOG] Connecting socket for: updatenotification
                                    0|MagicMir | [17:37:30.202] [LOG] Connecting socket for: calendar
                                    0|MagicMir | [17:37:30.204] [LOG] Starting node helper for: calendar
                                    0|MagicMir | [17:37:30.205] [LOG] Connecting socket for: newsfeed
                                    0|MagicMir | [17:37:30.206] [LOG] Starting module: newsfeed
                                    0|MagicMir | [17:37:30.207] [LOG] Sockets connected & modules started …
                                    0|MagicMir | [17:37:30.821] [LOG] Launching application.
                                      @Hubschra01 said in Fresh install but pm2 error:
                                      yeh,
                                      there are two launches,
                                      1 ended at 2020-01-21T16_37_02_810Z
                                      1 still running,
                                      • H Offline
                                        I restart the Mirror again an no there are no Errors in the Log. :-)
                                        I can´t post the log because Akismet mark this as span… wierd
                                        Thanks Sam
                                          @Hubschra01 no problem… glad we got it working…
                                          –lines=nnn only shows the last nnn lines, so old errors could be above that
                                          • H Offline
                                            I Think the errors come if i reboot the Mirror by
                                            sudo reboot
                                            without to stop the mirror.
                                            the log show
                                            PM2| 2020-01-22T17:48:05: PM2 log: Stop watching MagicMirror
                                            PM2| 2020-01-22T17:48:05: PM2 log: Stopping app:MagicMirror id:0
                                            PM2| 2020-01-22T17:48:05: PM2 log: pid=802 msg=failed to kill - retrying in 100ms
                                            PM2| 2020-01-22T17:48:05: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                            PM2| 2020-01-22T17:48:05: PM2 log: pid=802 msg=process killed
                                            PM2| 2020-01-22T17:48:06: PM2 log: PM2 successfully stopped
                                            If i do this
                                            pm2 stop MagicMirror
                                            sudo reboot
                                            after reboot the log show this
                                            PM2| 2020-01-22T17:51:13: PM2 log: pm2 has been killed by signal, dumping process list before exit...
                                            PM2| 2020-01-22T17:51:13: PM2 log: Exited peacefully
                                            I can´t post the log because Akismet mark this as spam… wierd
