    Fresh install but pm2 error
    37 Posts 2 Posters 13.9k Views 2 Watching
    • H Offline
      Hubschra01
      No it is only one to see…
      pi@raspberrypi:~/MagicMirror $ pm2 status
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
        sdetweil @Hubschra01
        @Hubschra01 weird… delete that instance
        pm2 delete 0
        then run my fixup script
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
        • H Offline
          Hubschra01 @sdetweil
          PM2        | 2020-01-21T11:38:39: PM2 log: Node.js version      : 10.18.1
          PM2        | 2020-01-21T11:38:39: PM2 log: Current arch         : arm
          PM2        | 2020-01-21T11:38:39: PM2 log: PM2 home             : /home/pi/.pm2
          PM2        | 2020-01-21T11:38:39: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
          PM2        | 2020-01-21T11:38:39: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
          PM2        | 2020-01-21T11:38:39: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
          PM2        | 2020-01-21T11:38:39: PM2 log: Application log path : /home/pi/.pm2/logs
          PM2        | 2020-01-21T11:38:39: PM2 log: Worker Interval      : 30000
          PM2        | 2020-01-21T11:38:39: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
          PM2        | 2020-01-21T11:38:39: PM2 log: Concurrent actions   : 2
          PM2        | 2020-01-21T11:38:39: PM2 log: SIGTERM timeout      : 1600
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | + arch=armv7l
          0|MagicMir | + false=false
          0|MagicMir | ++ grep -i serveronly:
          0|MagicMir | ++ awk '{print tolower($2)}'
          0|MagicMir | ++ tr -d ',"'\'''
          0|MagicMir | ++ grep -v '^\s//' config/config.js
          0|MagicMir | + serveronly=
          0|MagicMir | + serveronly=false
          0|MagicMir | ++ pgrep Xorg
          0|MagicMir | + xorg=429
          0|MagicMir | ++ uname
          0|MagicMir | + mac=Linux
          0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']'
          0|MagicMir | + '[' 429. == . -a Linux '!=' Darwin ']'
          0|MagicMir | + electron js/electron.js
          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
          0|MagicMir | [11:38:49.100] [LOG]    Module helper loaded: calendar
          0|MagicMir | [11:38:49.101] [LOG]    No helper found for module: currentweather.
          0|MagicMir | [11:38:49.103] [LOG]    No helper found for module: weatherforecast.
          0|MagicMir | [11:38:49.191] [LOG]    Initializing new module helper ...
          0|MagicMir | [11:38:49.192] [LOG]    Module helper loaded: newsfeed
          0|MagicMir | [11:38:49.193] [LOG]    All module helpers loaded.
          0|MagicMir | [11:38:49.195] [LOG]    Starting server on port 8080 ...
          0|MagicMir | [11:38:49.218] [LOG]    Server started ...
          0|MagicMir | [11:38:49.220] [LOG]    Connecting socket for: updatenotification
          0|MagicMir | [11:38:49.222] [LOG]    Connecting socket for: calendar
          0|MagicMir | [11:38:49.223] [LOG]    Starting node helper for: calendar
          0|MagicMir | [11:38:49.225] [LOG]    Connecting socket for: newsfeed
          0|MagicMir | [11:38:49.226] [LOG]    Starting module: newsfeed
          0|MagicMir | [11:38:49.227] [LOG]    Sockets connected & modules started ...
          0|MagicMir | [11:38:49.889] [LOG]    Launching application.
          0|MagicMirror  | [11:38:53.980] [LOG]
          0|MagicMirror  | Create new calendar fetcher for url
            @Hubschra01 that looks good now, right?
            • H Offline
              I think so, if this below is not an Error.
              But what caused the error or what was the mistake?
                @Hubschra01 u can remove the -x from run-start.sh 1st line.
                That is just debugging
                • H Offline
                  Strange…
                  I flushed the log and i remove the -x from the run-start.sh.
                  after reboot i see this in the log again.
                  0|MagicMir | npm ERR! code ELIFECYCLE
                  0|MagicMir | npm ERR! errno 1
                  0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                  0|MagicMir | npm ERR! Exit status 1
                  0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
                  0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  0|MagicMir |
                  0|MagicMir | npm ERR! A complete log of this run can be found in:
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log
                  1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                  2 info using npm@6.13.4
                  3 info using node@v10.18.1
                  5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                  6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                  7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                  8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                  9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
                  10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
                  11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
                  12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                  13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
                  13 verbose stack Exit status 1
                  13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                  13 verbose stack     at EventEmitter.emit (events.js:198:13)
                  13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  13 verbose stack     at ChildProcess.emit (events.js:198:13)
                  13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                  13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                  14 verbose pkgid magicmirror@2.10.1
                  15 verbose cwd /home/pi/MagicMirror
                  16 verbose Linux 4.19.75-v7+
                  17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                  18 verbose node v10.18.1
                  19 verbose npm  v6.13.4
                  20 error code ELIFECYCLE
                  21 error errno 1
                  22 error magicmirror@2.10.1 start: `./run-start.sh`
                  22 error Exit status 1
                  23 error Failed at the magicmirror@2.10.1 start script.
                  23 error This is probably not a problem with npm. There is likely additional logging output above.
                  24 verbose exit [ 1, true ]
                  weird:pouting_face:
                    @Hubschra01 and the mirror did not start?
                    • H Offline
                      The Mirror start an work fine now. :-) Thanks to you
                      So i have to consider the error in the log as normal?
                        @Hubschra01 i wonder if that is the shutdown log, on the reboot…
                        but there should be more on restart
                        • H Offline
                          if i understand you right your oppinion is that this error meassage is the shutdown message and not a start up error?
                            @Hubschra01 yes
                            do
                            pm2 logs --lines=100
                            • H Offline
                              /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                              0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                              0|MagicMir |
                              /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                              0|MagicMir |
                              0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                              0|MagicMir | > ./run-start.sh
                              0|MagicMir |
                              0|MagicMir |
                              0|MagicMir |
                              0|MagicMir | [17:37:28.657] [LOG] Starting MagicMirror: v2.10.1
                              0|MagicMir | [17:37:28.673] [LOG] Loading config …
                              0|MagicMir | [17:37:28.686] [LOG] Loading module helpers …
                              0|MagicMir | [17:37:28.689] [LOG] No helper found for module: alert.
                              0|MagicMir | [17:37:28.825] [LOG] Initializing new module helper …
                              0|MagicMir | [17:37:28.827] [LOG] Module helper loaded: updatenotification
                              0|MagicMir | [17:37:28.829] [LOG] No helper found for module: clock.
                              0|MagicMir | [17:37:30.081] [LOG] Initializing new module helper …
                              0|MagicMir | [17:37:30.082] [LOG] Module helper loaded: calendar
                              0|MagicMir | [17:37:30.083] [LOG] No helper found for module: currentweather.
                              0|MagicMir | [17:37:30.084] [LOG] No helper found for module: weatherforecast.
                              0|MagicMir | [17:37:30.172] [LOG] Initializing new module helper …
                              0|MagicMir | [17:37:30.173] [LOG] Module helper loaded: newsfeed
                              0|MagicMir | [17:37:30.173] [LOG] All module helpers loaded.
                              0|MagicMir | [17:37:30.175] [LOG] Starting server on port 8080 …
                              0|MagicMir | [17:37:30.199] [LOG] Server started …
                              0|MagicMir | [17:37:30.201] [LOG] Connecting socket for: updatenotification
                              0|MagicMir | [17:37:30.202] [LOG] Connecting socket for: calendar
                              0|MagicMir | [17:37:30.204] [LOG] Starting node helper for: calendar
                              0|MagicMir | [17:37:30.205] [LOG] Connecting socket for: newsfeed
                              0|MagicMir | [17:37:30.206] [LOG] Starting module: newsfeed
                              0|MagicMir | [17:37:30.207] [LOG] Sockets connected & modules started …
                              0|MagicMir | [17:37:30.821] [LOG] Launching application.
                                @Hubschra01 said in Fresh install but pm2 error:
                                yeh,
                                there are two launches,
                                1 ended at 2020-01-21T16_37_02_810Z
                                1 still running,
                                • H Offline
                                  I restart the Mirror again an no there are no Errors in the Log. :-)
                                  I can´t post the log because Akismet mark this as span… wierd
                                  Thanks Sam
                                    @Hubschra01 no problem… glad we got it working…
                                    –lines=nnn only shows the last nnn lines, so old errors could be above that
                                    • H Offline
                                      I Think the errors come if i reboot the Mirror by
                                      sudo reboot
                                      without to stop the mirror.
                                      the log show
                                      PM2| 2020-01-22T17:48:05: PM2 log: Stop watching MagicMirror
                                      PM2| 2020-01-22T17:48:05: PM2 log: Stopping app:MagicMirror id:0
                                      PM2| 2020-01-22T17:48:05: PM2 log: pid=802 msg=failed to kill - retrying in 100ms
                                      PM2| 2020-01-22T17:48:05: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                      PM2| 2020-01-22T17:48:05: PM2 log: pid=802 msg=process killed
                                      PM2| 2020-01-22T17:48:06: PM2 log: PM2 successfully stopped
                                      If i do this
                                      pm2 stop MagicMirror
                                      sudo reboot
                                      after reboot the log show this
                                      PM2| 2020-01-22T17:51:13: PM2 log: pm2 has been killed by signal, dumping process list before exit...
                                      PM2| 2020-01-22T17:51:13: PM2 log: Exited peacefully
                                      I can´t post the log because Akismet mark this as spam… wierd
                                        @Hubschra01 yes, askimet is a pain…
                                        thanks for your information…
                                        I suspect the other bad failure info is reboot after just npm start
