    Fresh install but pm2 error
    37 Posts 2 Posters 11.2k Views 2 Watching
    • H Offline
      Hubschra01 @sdetweil
      Strange…
      I flushed the log and i remove the -x from the run-start.sh.
      after reboot i see this in the log again.
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir | npm ERR! code ELIFECYCLE
      0|MagicMir | npm ERR! errno 1
      0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
      0|MagicMir | npm ERR! Exit status 1
      0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|MagicMir |
      0|MagicMir | npm ERR! A complete log of this run can be found in:
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.13.4
      3 info using node@v10.18.1
      5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
      6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
      7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
      11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.10.1
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.75-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v10.18.1
      19 verbose npm  v6.13.4
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.10.1 start: `./run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.10.1 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      weird:pouting_face:
        sdetweil @Hubschra01
        @Hubschra01 and the mirror did not start?
        • H Offline
          The Mirror start an work fine now. :-) Thanks to you
          So i have to consider the error in the log as normal?
            @Hubschra01 i wonder if that is the shutdown log, on the reboot…
            but there should be more on restart
            • H Offline
              if i understand you right your oppinion is that this error meassage is the shutdown message and not a start up error?
                @Hubschra01 yes
                do
                pm2 logs --lines=100
                • H Offline
                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                  0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                  0|MagicMir |
                  /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                  0|MagicMir |
                  0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                  0|MagicMir | > ./run-start.sh
                  0|MagicMir |
                  0|MagicMir |
                  0|MagicMir |
                  0|MagicMir | [17:37:28.657] [LOG] Starting MagicMirror: v2.10.1
                  0|MagicMir | [17:37:28.673] [LOG] Loading config …
                  0|MagicMir | [17:37:28.686] [LOG] Loading module helpers …
                  0|MagicMir | [17:37:28.689] [LOG] No helper found for module: alert.
                  0|MagicMir | [17:37:28.825] [LOG] Initializing new module helper …
                  0|MagicMir | [17:37:28.827] [LOG] Module helper loaded: updatenotification
                  0|MagicMir | [17:37:28.829] [LOG] No helper found for module: clock.
                  0|MagicMir | [17:37:30.081] [LOG] Initializing new module helper …
                  0|MagicMir | [17:37:30.082] [LOG] Module helper loaded: calendar
                  0|MagicMir | [17:37:30.083] [LOG] No helper found for module: currentweather.
                  0|MagicMir | [17:37:30.084] [LOG] No helper found for module: weatherforecast.
                  0|MagicMir | [17:37:30.172] [LOG] Initializing new module helper …
                  0|MagicMir | [17:37:30.173] [LOG] Module helper loaded: newsfeed
                  0|MagicMir | [17:37:30.173] [LOG] All module helpers loaded.
                  0|MagicMir | [17:37:30.175] [LOG] Starting server on port 8080 …
                  0|MagicMir | [17:37:30.199] [LOG] Server started …
                  0|MagicMir | [17:37:30.201] [LOG] Connecting socket for: updatenotification
                  0|MagicMir | [17:37:30.202] [LOG] Connecting socket for: calendar
                  0|MagicMir | [17:37:30.204] [LOG] Starting node helper for: calendar
                  0|MagicMir | [17:37:30.205] [LOG] Connecting socket for: newsfeed
                  0|MagicMir | [17:37:30.206] [LOG] Starting module: newsfeed
                  0|MagicMir | [17:37:30.207] [LOG] Sockets connected & modules started …
                  0|MagicMir | [17:37:30.821] [LOG] Launching application.
                    @Hubschra01 said in Fresh install but pm2 error:
                    yeh,
                    there are two launches,
                    1 ended at 2020-01-21T16_37_02_810Z
                    1 still running,
                    • H Offline
                      I restart the Mirror again an no there are no Errors in the Log. :-)
                      I can´t post the log because Akismet mark this as span… wierd
                      Thanks Sam
                        @Hubschra01 no problem… glad we got it working…
                        –lines=nnn only shows the last nnn lines, so old errors could be above that
                        • 3 / 4
