    Command line to stop MM
    11 Posts 3 Posters 12.6k Views 3 Watching
    • L Offline
      l951b951
      I have successfully created my config.js file and MM works from the terminal when I type
      npm start
      Is there a command to stop MM from the command line?
      • BKeyportB Offline
        BKeyport Module Developer
        npm stop
        • L Offline
          l951b951
          It says “Missing Script: stop”
          • BKeyportB Offline
            Did you run it from the MagicMirror directory?
            If so, then NPM is ignoring it’s own documentation. I can’t help further, as I run it through PM2, and PM2 does the magic for me.
              sdetweil @l951b951
              @l951b951 if you did it that way, ctrl-c should stop it without problem.
              If u did
              npm start &
              Then you will have to kill the processes to stop it.
              i wrote a little script to do it
              #!/bin/bash
              ps aux | grep node | grep -v "color"  | awk '{print $2}' | xargs sudo kill -9
              the script will also work from another process instance
              • L Offline
                l951b951
                I ran it from ~/MagicMirror so I was in the directory. and all I typed was npm start.
                My problem is that I want to be able to fire a script after a set time to stop the Magic Mirror. My goal is to attach a PIR motion sensor, and when someone comes close start the magic mirror, and after a few minutes with no motion, stop Magic Mirror and run another script. Maybe that helps understand my intent.
                • L Offline
                  l951b951 @sdetweil
                  @sdetweil said in Command line to stop MM:
                  ps aux | grep node | grep -v “color” | awk ‘{print $2}’ | xargs sudo kill -9
                  Thank you for that. It worked, but gives me this: is it safe to ignore these warnings?
                  ./run-start.sh: line 67:  3306 Killed                  electron js/electron.js $1
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 137
                  npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                  npm ERR! Exit status 137
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.10.1 start script.
                  npm ERR!     /home/pi/.npm/_logs/2020-02-03T20_03_35_641Z-debug.log
                    sdetweil @l951b951
                    @l951b951 yes.,… if you start mm like this
                    npm start >/dev/null 2>&1
                    you won’t get any messages
                    that means
                    send all stdout to /dev/null ( >/dev/null)
                    and send stderr to the same place as stdout (2>&1)
                    • L Offline
                      l951b951
                      Thank you, that combination is doing what I need it to do.
                      I’m marking this as solved, but I’d love to see a breakdown of what
                      is doing exactly?
                        sdetweil @l951b951
                        @l951b951
                        list all the processes , one per line
                        ps aux
                        of that list get all lines that have the word ‘node’
                        grep node
                        of that list get all lines that DO NOT have the word color
                        grep -v “color”
                        use awk to print just the process number (second space separated token) from each line
                        awk ‘{print $2}’
                        and the use sudo kill -9 to kill it, passing the process number using xargs
                        xargs sudo kill -9 ???
                        you can do each as one step
                        ps aux (partial list)
                        pi         922  0.0  0.4   6176  4208 pts/0    Ss   Feb01   0:01 -bash
                        root     14676  0.0  0.0      0     0 ?        I<   12:34   0:00 [kworker/2:0H]
                        pi       15250  0.0  0.2   4628  2644 ?        Ss   13:55   0:00 bash /home/pi/MagicMirror/run-start.sh
                        pi       15263  0.0  3.0  86264 28752 ?        Sl   13:55   0:00 node node_modules/.bin/electron js/electron.js
                        pi       15274 15.7 12.0 438576 113952 ?       Sl   13:55   5:24 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                        pi       15276  0.0  2.7 134932 26392 ?        S    13:55   0:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-sandbox
                        pi       15311  8.2 10.8 342876 103308 ?       Sl   13:55   2:49 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --autoplay-po
                        pi       15318  0.0  6.0 282764 57060 ?        Sl   13:55   0:00 /home/pi/MagicMirror/n pu-process --no-sandbox --gpu-preferences=KAAAAAAAAACAAACAAQAAA
                        root     15351  0.0  0.0      0     0 ?        I    13:55   0:00 [kworker/3:2-eve]
                        with grep node
                        pi@raspberrypi:~ $ ps aux | grep node
                        pi       15274 15.6 11.4 433072 108780 ?       Sl   13:55   5:29 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                        pi       15311  8.2 10.3 337372 97832 ?        Sl   13:55   2:52 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --autoplay-policy=no-user-gesture-required --no-sandbox --service-pipe-token=E75C637B69C4371629AED884ECD5DCA7 --lang=en-US --app-path=/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar --node-integration=false --webview-tag=false --no-sandbox --background-color=#000000 --num-raster-threads=2 --enable-main-frame-before-activation --enable-compositor-image-animations --service-request-channel-token=E75C637B69C4371629AED884ECD5DCA7 --renderer-client-id=3 --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                        pi       15546  0.0  0.0   4372   572 pts/0    S+   14:30   0:00 grep --color=auto node
                        etc
                          sdetweil
                          ps --help a
                          will show all the options for listing running processes
