    PI Zero module issues for this beginner
    24 Posts 2 Posters 8.8k Views 2 Watching
    • W Offline
      wagon40
      Hello,
      After a year of on and off trying to get a MM to work on a PI I figured it out and even changed the stock modules to work for me. I have to do everything from the command line. I have no desktop. I found a direct load and go at
      http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
      I downloaded the image and started it up.
      Issues:
      1. I cant figure out how to see what modules I currently have loaded? (what is the command line script?
      2. I loaded My-Commute followed all of the 3rd party direction. when I went into the config.js I had to manually add the configuration I found on the My-commute page so is that normal to have to enter in configuration to the config.js? when I started up the mirror it showed the default walking, flying, driving with an error at the end. So how to I edit the actual modular configuration information from the command line?
      any help would be great. I will attempt to get code for you tomorrow when im not at work.
        sdetweil @wagon40
        @wagon40 you should use my installation script… it does it all…
        see here https://github.com/sdetweil/MagicMirror_scripts/blob/master/run-start.sh
        use the desktop version of the pi 0… stretch or buster… jessie is too old
        what modules
        what is installed is folders in ~/MagicMirror/modules
        what is being used , see the ~/MagicMirror/config/config.js, and each module: statement
        where disabled is not specified or disabled: false
        nano is the commandline editor
        ctrl-o to save the file
        ctrl-x to exit
        ctrl-w to search the file
        yes. u install the code, then have to update the MM config to actually use it
        • W Offline
          wagon40 @sdetweil
          @sdetweil thank you for the quick reply. I will try your download tomorrow if I get a chance and hopefully have better luck.
            sdetweil @wagon40
            @wagon40 to install MM again, you will need to rename the current folder out of the way
            do this
            cd ~
            mv MagicMirror  MagicMirror.save
            • W Offline
              wagon40
              can you send me the direct script to place in the command line to load your script? I have tried a few bash $( bala bal bal) and im not getting much luck.
              I tried to follow this https://forum.magicmirror.builders/topic/9386/installing-on-a-pi-zero/72
              but of course it wont start. screen goes to sleep and it only starts for a minute then goes to desktop.
              I installed buster with desktop.
                sdetweil @wagon40
                @wagon40 from the page I referenced
                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                you can do that over ssh, or on the pi monitor terminal session
                it will prompt you about autostart with pm2 and turning off screensaver
                • W Offline
                  wagon40 @sdetweil
                  all was going well until the dependencies stopped it. tired to send the code using </> or :: but it blanks out the submit button?
                  • W Offline
                    wagon40 @wagon40
                    @wagon40
                    npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                    npm ERR!     /home/pi/.npm/_logs/2020-02-05T21_24_22_985Z-debug.log
                      sdetweil @wagon40
                      @wagon40 hm… I don’t see that on my pi 0…
                      And electron is optional, so there should be no need for chrome driver
                      • W Offline
                        wagon40
                        Same issue I had with the other download. any suggestion?
                        npm ERR! errno 1
                        npm ERR!
                        npm ERR!     /home/pi/.npm/_logs/2020-02-05T22_31_04_266Z-debug.log
                          sdetweil @wagon40
                          @wagon40 I will have to look. It will be a couple hours. Have grandson now
                          • W Offline
                            wagon40
                            Tried to npm start and it states that i dont have a config.js. went to the desktop and i can navigate to the magicmirror file and open the config sample. not sure why it isnt loading? did a reboot and it is not starting MM.
                              sdetweil @wagon40
                              @wagon40 because the install didn’t finish… copy config.js.sample to config.js
                              can u show me the ~/install.log?
                              other things might fail too… as it didn’t complete the install steps…
                              i am trying again right now on my pi 0, but on jessie (as thats the OS level I have installed there at the moment)
                              • W Offline
                                wagon40
                                nothing for install.log. tried a few different ways. I was able to make a copy but just a black screen on npm start up. not sure what to do.
                                • W Offline
                                  wagon40
                                  I ran this command and got that
                                  npm run config:check
                                  npm ERR! code ENOENT
                                  npm ERR! syscall open
                                  npm ERR! path /home/pi/package.json
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                  npm ERR! enoent This is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR!     /home/pi/.npm/_logs/2020-02-06T00_34_33_299Z-debug.log
                                    sdetweil @wagon40
                                    @wagon40 did u run my script? it creates a log file…
                                    gotta be IN the MagicMirror folder
                                    to get the base config
                                    cd ~/MagicMirror/config
                                    cp config.js.sample config.js
                                    but the system is a mess right now… hang on I am testing a fixed installer…
                                    • W Offline
                                      wagon40
                                      I appreciate your help and putting up with a noob
                                      pi@raspberrypi:~/MagicMirror/config $ npm run config:check
                                      > magicmirror@2.10.1 config:check /home/pi/MagicMirror
                                      > node tests/configs/check_config.js
                                      Checking file...  /home/pi/MagicMirror/config/config.js
                                      Your configuration file doesn't contain syntax errors :)
                                        sdetweil
                                        erase the current MagicMirror folder (rm -rf MagicMirror )
                                        and run the install script again , they changed some upstream library to hard fail…
                                        but we didn’t need it anyhow…
                                          sdetweil @wagon40
                                          @wagon40 said in PI Zero module issues for this beginner:
                                          we were all noobs once…
                                            @sdetweil my test of installer on buster on pi 0, comes up running fine now
