    Basic Calendar log errors
    9 Posts 2 Posters 2.2k Views 2 Watching
      johntech
      Noob here trying to get the basic calendar to work. I tried several ics links and none work. The screen shows US HOLIDAYS and under that it says No upcoming events. I did a lot of searching on the internet and through the forums. I ended up finding some information on how to check the log files. In here I found the following when restarting MagicMirror:
      0|MagicMirror  | Launching application.
      0|MagicMirror  | [23:19:49.314] [LOG]
      0|MagicMirror  | Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      0|MagicMirror  | [23:19:49.325] [LOG]
      0|MagicMirror  | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      0|MagicMirror  | [23:19:50.208] [LOG]
      0|MagicMirror  | Whoops! There was an uncaught exception...
      0|MagicMirror  | [23:19:50.209] [ERROR]
      0|MagicMirror  | Error: Unknown RRULE property ''
      0|MagicMirror  |     at /home/pi/MagicMirror/node_modules/rrule/dist/es5/rrule.js:1191:23
      0|MagicMirror  |     at Array.forEach (<anonymous>)
      0|MagicMirror  |     at parseRrule (/home/pi/MagicMirror/node_modules/rrule/dist/es5/rrule.js:1149:11)
      0|MagicMirror  |     at parseLine (/home/pi/MagicMirror/node_modules/rrule/dist/es5/rrule.js:1132:16)
      0|MagicMirror  |     at Array.map (<anonymous>)
      0|MagicMirror  |     at Function.parseString (/home/pi/MagicMirror/node_modules/rrule/dist/es5/rrule.js:1110:41)
      0|MagicMirror  |     at Function.RRule.fromString (/home/pi/MagicMirror/node_modules/rrule/dist/es5/rrule.js:2135:32)
      0|MagicMirror  |     at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:62:23)
      0|MagicMirror  |     at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:400:41)
      0|MagicMirror  |     at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:441:20)
      0|MagicMirror  | [23:19:50.218] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMirror  | [23:19:50.219] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      The next to the last line says “Maybe no internet connection.” That is not a problem as everything else on the screen is updating just fine.
      This is the link I’m using from the latest calendar config file:
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      All of the settings in the calendar.js file are unchanged.
      UPDATE:
      I grabbed another sd card and and loaded MM on it and am getting the similar errors on a new install as follows:
      0|MagicMirror  | [00:23:01.865] [LOG]
      0|MagicMirror  | [00:23:01.911] [LOG]
      0|MagicMirror  | [00:23:02.474] [LOG]
      0|MagicMirror  | [00:23:02.475] [ERROR]
      0|MagicMirror  | [00:23:02.485] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMirror  | [00:23:02.486] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Any idea what this error is and possibly how to fix it so I can get the calendar working again? Thanks for any info!!
      John
        sdetweil @johntech
        @johntech yes, looks like the calendar data has an empty repeating rule and the library code we use
        can’t handle that
        edit (nano) the MagicMirror/node_modules/rrule/dist/es5/rrule.js
        find (ctrl w)
        options.byeaster = Number(value);
        and add these two lines
             case '':
                break;
        so it looks like this
                    case 'BYEASTER':
                        break;
                   case '':
        		break;
          johntech @sdetweil
          @sdetweil said in Basic Calendar log errors:
          >  case '':
          > 		break;
          Good!! That fixed the issue of the calendar not displaying , but now it is showing double entries in the list. 2 - Easters, Mother’s Day, President’s day etc.
            sdetweil @johntech
            @johntech said in Basic Calendar log errors:
            cause there are two entries in the file
            looks like calendarlabs.com is having trouble
              johntech @sdetweil
              Ok. Is it possible to download the file, edit it and use is locally?
              Thank you for the help!!
              John
                sdetweil @johntech
                @johntech sure… use the url (change webcal to https)
                edit the downloaded file (there are multiples of all the entries)
                copy the file to the MagixMirror/modules folder (thats where the MM web server is pointing)
                then edit the url in the config entry to
                “modules/???” // ics filename
                  johntech @sdetweil
                  Sorry for the misunderstanding but is this what you meant?
                  url: “https://modules/US_Holidays.ics”
                    sdetweil @johntech
                    @johntech http://localhost:8080/…
                      johntech @sdetweil
                      Thank you !!! I wasn’t thinking localhost. Still learning!!
