    MMM-GroveGestures / Python script is terminated
    25 Posts 5 Posters 8.2k Views 5 Watching
      MagicStarthilfe @Guest
      @Sean
      Thanks for the quick answer.
      Last night it started correctly for once. That was after several restarts, no idea why it suddenly worked. Then I let the system run overnight, that was no problem.
      I rebooted it earlier for a test. The error did not occur then, but the module does not react now. Therefore all modules are on the first page (use MMM-GroveGestures for the page change together with MMM-pages, MMM-page-indicator and MMM notification trigger which worked otherwise). Even a restart does not help at the moment. I have increased the speed of i2c.
      python gesture_print.py works.
      All modules seem to be loaded correctly. (see MagicMirror-out.log
      below)
      Is it maybe more a problem of MMM-pages?
      Today I will test the system without MMM-pages and only with the clock, if MMM-GroveGestures works I will start the other modules bit by bit. Maybe I can identify a module that causes problems.
      [11:32:16.198] [LOG]    Starting MagicMirror: v2.10.1
      [11:32:16.215] [LOG]    Loading config ...
      [11:32:16.234] [LOG]    Loading module helpers ...
      [11:32:16.236] [LOG]    No helper found for module: alert.
      [11:32:16.371] [LOG]    Initializing new module helper ...
      [11:32:16.372] [LOG]    Module helper loaded: updatenotification
      [11:32:16.374] [LOG]    No helper found for module: clock.
      [11:32:16.544] [LOG]    Initializing new module helper ...
      [11:32:16.545] [LOG]    Module helper loaded: MMM-Remote-Control
      [11:32:16.561] [LOG]    Initializing new module helper ...
      [11:32:16.562] [LOG]    Module helper loaded: MMM-GroveGestures
      [11:32:16.570] [LOG]    Initializing new module helper ...
      [11:32:16.571] [LOG]    Module helper loaded: MMM-NotificationTrigger
      [11:32:16.572] [LOG]    No helper found for module: MMM-page-indicator.
      [11:32:16.574] [LOG]    No helper found for module: MMM-pages.
      [11:32:16.648] [LOG]    Initializing new module helper ...
      [11:32:16.649] [LOG]    Module helper loaded: MMM-PIR-Sensor
      [11:32:17.647] [LOG]    Initializing new module helper ...
      [11:32:17.648] [LOG]    Module helper loaded: MMM-SystemStats
      [11:32:18.339] [LOG]    Initializing new module helper ...
      [11:32:18.339] [LOG]    Module helper loaded: MMM-PublicTransportHafas
      [11:32:18.345] [LOG]    Initializing new module helper ...
      [11:32:18.346] [LOG]    Module helper loaded: MMM-NASA
      [11:32:18.575] [LOG]    Initializing new module helper ...
      [11:32:18.576] [LOG]    Module helper loaded: MMM-NOAA
      [11:32:19.573] [LOG]    Initializing new module helper ...
      [11:32:19.576] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
      [11:32:19.664] [LOG]    Initializing new module helper ...
      [11:32:19.664] [LOG]    Module helper loaded: newsfeed
      [11:32:19.665] [LOG]    All module helpers loaded.
      [11:32:19.667] [LOG]    Starting server on port 8080 ...
      [11:32:19.691] [LOG]    Server started ...
      [11:32:19.693] [LOG]    Connecting socket for: updatenotification
      [11:32:19.695] [LOG]    Connecting socket for: MMM-Remote-Control
      [11:32:19.697] [LOG]    Starting node helper for: MMM-Remote-Control
      [11:32:19.714] [LOG]    Connecting socket for: MMM-GroveGestures
      [11:32:19.716] [LOG]    Connecting socket for: MMM-NotificationTrigger
      [11:32:19.763] [LOG]    Connecting socket for: MMM-PIR-Sensor
      [11:32:19.766] [LOG]    Connecting socket for: MMM-SystemStats
      [11:32:19.768] [LOG]    Connecting socket for: MMM-PublicTransportHafas
      [11:32:19.770] [LOG]    Connecting socket for: MMM-NASA
      [11:32:19.772] [LOG]    Starting node_helper for: MMM-NASA
      [11:32:19.774] [LOG]    Connecting socket for: MMM-NOAA
      [11:32:19.776] [LOG]    Starting module: MMM-NOAA
      [11:32:19.801] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
      [11:32:19.802] [LOG]    MMM-DWD-WarnWeather helper started...
      [11:32:19.803] [LOG]    Connecting socket for: newsfeed
      [11:32:19.805] [LOG]    Starting module: newsfeed
      [11:32:19.805] [LOG]    Sockets connected & modules started ...
      [11:32:20.114] [LOG]    Launching application.
      [11:32:25.625] [LOG]    Transportation fetcher for station with id '008000263' created.
      [11:32:26.201] [LOG]    Transportation fetcher for station with id '000625258' created.
      [11:32:26.356] [LOG]    Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
      • ? Offline
        A Former User @MagicStarthilfe
        @MagicStarthilfe
        I don’t know whether MMM-Pages would be reason or not at this moment. Your last log seems so quite normal anyway (or saying nothing important really. :D)
        If you are using MMM-Pages, keep this kind of module is valid on each page. I think it’s better to keep it globally out of those kinds of suspending/resuming control.
          @Sean Hello,
          the error " Python script is terminated" I could actually fix by adjusting the i2c speed. Thanks for the tip.
          The subsequent errors were caused by the NOAA module.
          Thanks for the help.
          • E Offline
            Egnos @MagicStarthilfe
            Hi @MagicStarthilfe I have the same problem as you:
            [04.09.2023 12:50.18.499] [LOG]   [GESTURE] Gesture script is finished.
            [04.09.2023 12:50.19.072] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
            [04.09.2023 12:50.19.270] [LOG]   [GESTURE] ORIGIN:wake-up finish.
            [04.09.2023 12:50.19.393] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
            [04.09.2023 12:59.32.764] [LOG]   Keyboard Interrupted
            I use a Raspberry Pi 4 4GB with MagicMirror² v2.24.0 (the latest version…).
            Do you remeber wich “i2c” speed you have used for fix the problem?
            Thanks.
              MMRIZE @Egnos
              @Egnos
              Try 10000 or 32000.
                MMRIZE @Egnos
                @Egnos
                However the “terminated” message itself is nothing wrong.
                “Too often without any gesture triggered” cases only be the issue.
                • E Offline
                  Egnos @MMRIZE
                  @MMRIZE said in MMM-GroveGestures / Python script is terminated:
                  Try 10000 or 32000.
                  I think I tried 10000 and nothing changed, I’ll try 32000
                  Like in my case:
                  [04.09.2023 08:52.13.012] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 08:52.13.514] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 08:52.13.706] [LOG]   Keyboard Interrupted
                  [04.09.2023 08:52.13.707] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 08:52.14.208] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 08:52.14.414] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 08:52.14.547] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 09:00.23.783] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 09:02.38.447] [LOG]   Keyboard Interrupted
                  [04.09.2023 09:02.38.448] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 09:02.38.951] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 09:02.39.143] [LOG]   Keyboard Interrupted
                  [04.09.2023 09:02.39.147] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 09:02.39.650] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 09:02.39.811] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 09:02.39.932] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 09:08.15.627] [LOG]   Keyboard Interrupted
                  [04.09.2023 09:08.15.629] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 09:08.16.131] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 09:08.16.345] [LOG]   Keyboard Interrupted
                  [04.09.2023 09:08.16.348] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 09:08.16.852] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 09:08.17.038] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 09:08.17.158] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 09:31.42.854] [LOG]   Keyboard Interrupted
                  [04.09.2023 09:31.42.859] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 09:31.43.364] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 09:31.43.517] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 09:31.43.638] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 10:00.24.425] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 10:17.30.788] [LOG]   Keyboard Interrupted
                  [04.09.2023 10:17.30.792] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 10:17.31.298] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 10:17.31.451] [LOG]   Keyboard Interrupted
                  [04.09.2023 10:17.31.452] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 10:17.31.953] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 10:17.32.137] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 10:17.32.252] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 10:17.38.740] [LOG]   Keyboard Interrupted
                  [04.09.2023 10:17.38.741] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 10:17.39.243] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 10:17.39.462] [LOG]   Keyboard Interrupted
                  [04.09.2023 10:17.39.464] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 10:17.39.973] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 10:17.40.117] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 10:17.40.242] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 11:00.24.921] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 11:09.56.054] [LOG]   Keyboard Interrupted
                  [04.09.2023 11:09.56.059] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 11:09.56.573] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 11:09.56.793] [LOG]   Keyboard Interrupted
                  [04.09.2023 11:09.56.802] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 11:09.57.364] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 11:09.57.631] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 11:09.57.754] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 12:00.25.300] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 12:50.17.726] [LOG]   Keyboard Interrupted
                  [04.09.2023 12:50.17.736] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 12:50.18.243] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 12:50.18.496] [LOG]   Keyboard Interrupted
                  [04.09.2023 12:59.32.765] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 12:59.33.269] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 12:59.33.470] [LOG]   Keyboard Interrupted
                  [04.09.2023 12:59.33.479] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 12:59.33.987] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 12:59.34.190] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 12:59.34.340] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 13:00.25.675] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 13:11.28.559] [LOG]   [SPOTIFY - Daniele] Will retry in 5 seconds ...
                  [04.09.2023 13:41.29.947] [LOG]   Keyboard Interrupted
                  [04.09.2023 13:41.29.948] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 13:41.30.452] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 13:41.30.681] [LOG]   Keyboard Interrupted
                  [04.09.2023 13:41.30.686] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 13:41.31.188] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 13:41.31.384] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 13:41.31.487] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 14:00.26.016] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 14:06.09.575] [LOG]   Keyboard Interrupted
                  [04.09.2023 14:06.09.576] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 14:06.10.364] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 14:06.10.574] [LOG]   Keyboard Interrupted
                  [04.09.2023 14:06.10.575] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 14:06.11.078] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 14:06.11.259] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 14:06.11.398] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 14:39.19.948] [LOG]   Keyboard Interrupted
                  [04.09.2023 14:39.19.957] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 14:39.20.460] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 14:39.20.983] [LOG]   Keyboard Interrupted
                  [04.09.2023 14:39.20.985] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 14:39.21.488] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 14:39.21.704] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 14:39.21.806] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 14:46.27.234] [LOG]   [SPOTIFY - Daniele] Will retry in 5 seconds ...
                  [04.09.2023 15:00.26.370] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 15:42.11.128] [LOG]   Keyboard Interrupted
                  [04.09.2023 15:42.11.130] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 15:42.11.634] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 15:42.12.259] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 15:42.12.268] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 15:51.34.615] [LOG]   Keyboard Interrupted
                  [04.09.2023 15:51.34.616] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 15:51.35.118] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 15:51.35.314] [LOG]   Keyboard Interrupted
                  [04.09.2023 15:51.35.315] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 15:51.35.820] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 15:51.35.999] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 15:51.36.125] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 15:53.18.947] [LOG]   Keyboard Interrupted
                  [04.09.2023 15:53.18.950] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 15:53.19.465] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 15:53.19.733] [LOG]   Keyboard Interrupted
                  [04.09.2023 15:53.19.736] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 15:53.20.241] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 15:53.20.474] [LOG]   Keyboard Interrupted
                  [04.09.2023 15:53.20.475] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 15:53.20.980] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 15:53.21.250] [LOG]   Keyboard Interrupted
                  [04.09.2023 15:53.21.253] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 15:53.21.760] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 15:53.22.249] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 15:53.22.250] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 16:00.26.809] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                  [04.09.2023 16:07.05.688] [LOG]   Keyboard Interrupted
                  [04.09.2023 16:07.05.690] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 16:07.06.193] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 16:07.06.363] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 16:07.06.474] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                  [04.09.2023 16:07.55.429] [LOG]   Keyboard Interrupted
                  [04.09.2023 16:07.55.432] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 16:07.55.935] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 16:07.56.121] [LOG]   Keyboard Interrupted
                  [04.09.2023 16:07.56.122] [LOG]   [GESTURE] Gesture script is finished.
                  [04.09.2023 16:07.56.626] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                  [04.09.2023 16:07.56.815] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                  [04.09.2023 16:07.56.969] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                    MMRIZE @Egnos
                    @Egnos
                    By spec, PAJ7620’s MAX i2c speed is 400Kbit/s (400,000) But sometimes Raspberry PI i2c cannot handle fast devices.
                    Have you tried testing the sensor?
                    cd ~/MagicMirror/modules/MMM-GroveGestures/py
                    And there could be other possible causes;
                    • Pins are not stably connected
                    • Too long cabling, > 30cm. The signal would be weaker or noisy.
                    • I2C frequency is still too high. Set slower (lesser number than your trials)
                    • I2C Bus overloaded, if you are connecting other i2c connections. (maybe more than 3 or 4s)
                    • E Offline
                      Egnos @MMRIZE
                      Yes, and also when appear [GESTURE] Python script is terminated. It will restart soon. the gesture works well.
                      I exclude it.
                      It will surely be longer, 40 or 50 cm
                      I tried all speeds, maybe with 32000 seems better.
                      From this value (32000) do I go down or up?
                      I exclude it. I have only Paj7620 and PIR sensor on GPIO…
                      I’m sure with the old version v2.23 of MM I always had the error messages but the gesture sensor always worked, with the new version v2.24.0 of MM sometimes the sensor stops working and I have to redo this procedure
                      https://github.com/MMRIZE/MMM-GroveGestures#install-hw
                      @MMRIZE Thanks for your precious advises.
                        MMRIZE @Egnos
                        @Egnos said in MMM-GroveGestures / Python script is terminated:
                        Hopefully not, over 30cm long cabling could be the issue. (You wrote 40~50cm, is it right?)
                        • 3 / 3
