    MMM-GroveGestures / Python script is terminated
    25 Posts 5 Posters 9.5k Views 5 Watching
      MagicStarthilfe
      Hello everybody,
      I’ve recently had a problem with the MMM-GroveGestures module. Besides, a great module!
      I get the following messages in /MagicMirror-error.log.
      0|MagicMirror  | [21:22:51.860] [LOG]
      0|MagicMirror  | Keyboard Interrupted
      0|MagicMirror  | [21:22:51.862] [LOG]    [GESTURE] Gesture script is finished.
      0|MagicMirror  | [21:22:52.366] [LOG]
      0|MagicMirror  | [GESTURE] Python script is terminated. It will restart soon.
      A restart does not help.
      I use a Raspberry Pi 3 Model B Rev 1.2
      PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="9"
      VERSION="9 (stretch)"
      VERSION_CODENAME=stretch
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      I use the following modules:
      MMM-DWD weather warning; MMM NOAA; MMM-pages; MMM Remote Control; MMM buttons; MMM Grove Gestures; MMM notification trigger; MMM-PIR sensor; MMM-NASA; MMM-page-indicator; MMM-Public Transport Hafas
      I would be very thankful for help.
      Carsten
        [[global:former-user]] @MagicStarthilfe
        @MagicStarthilfe
        how often did it happen? always? randomly?
        When did it happen usually? soon after start? in some minutes or hours?
          too fast or too slow i2c speed could make this kind issue.
          try to adjust speed to 10000 - 32000 (default might be 100000 I remembered)
          https://www.raspberrypi-spy.co.uk/2018/02/change-raspberry-pi-i2c-bus-speed/
          M 2 Replies Last reply Reply Quote 1
            MagicStarthilfe @Guest
              @Sean
              Thanks for the quick answer.
              Last night it started correctly for once. That was after several restarts, no idea why it suddenly worked. Then I let the system run overnight, that was no problem.
              I rebooted it earlier for a test. The error did not occur then, but the module does not react now. Therefore all modules are on the first page (use MMM-GroveGestures for the page change together with MMM-pages, MMM-page-indicator and MMM notification trigger which worked otherwise). Even a restart does not help at the moment. I have increased the speed of i2c.
              python gesture_print.py works.
              All modules seem to be loaded correctly. (see MagicMirror-out.log
              below)
              Is it maybe more a problem of MMM-pages?
              Today I will test the system without MMM-pages and only with the clock, if MMM-GroveGestures works I will start the other modules bit by bit. Maybe I can identify a module that causes problems.
              [11:32:16.198] [LOG]    Starting MagicMirror: v2.10.1
              [11:32:16.215] [LOG]    Loading config ...
              [11:32:16.234] [LOG]    Loading module helpers ...
              [11:32:16.236] [LOG]    No helper found for module: alert.
              [11:32:16.371] [LOG]    Initializing new module helper ...
              [11:32:16.372] [LOG]    Module helper loaded: updatenotification
              [11:32:16.374] [LOG]    No helper found for module: clock.
              [11:32:16.544] [LOG]    Initializing new module helper ...
              [11:32:16.545] [LOG]    Module helper loaded: MMM-Remote-Control
              [11:32:16.561] [LOG]    Initializing new module helper ...
              [11:32:16.562] [LOG]    Module helper loaded: MMM-GroveGestures
              [11:32:16.570] [LOG]    Initializing new module helper ...
              [11:32:16.571] [LOG]    Module helper loaded: MMM-NotificationTrigger
              [11:32:16.572] [LOG]    No helper found for module: MMM-page-indicator.
              [11:32:16.574] [LOG]    No helper found for module: MMM-pages.
              [11:32:16.648] [LOG]    Initializing new module helper ...
              [11:32:16.649] [LOG]    Module helper loaded: MMM-PIR-Sensor
              [11:32:17.647] [LOG]    Initializing new module helper ...
              [11:32:17.648] [LOG]    Module helper loaded: MMM-SystemStats
              [11:32:18.339] [LOG]    Initializing new module helper ...
              [11:32:18.339] [LOG]    Module helper loaded: MMM-PublicTransportHafas
              [11:32:18.345] [LOG]    Initializing new module helper ...
              [11:32:18.346] [LOG]    Module helper loaded: MMM-NASA
              [11:32:18.575] [LOG]    Initializing new module helper ...
              [11:32:18.576] [LOG]    Module helper loaded: MMM-NOAA
              [11:32:19.573] [LOG]    Initializing new module helper ...
              [11:32:19.576] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
              [11:32:19.664] [LOG]    Initializing new module helper ...
              [11:32:19.664] [LOG]    Module helper loaded: newsfeed
              [11:32:19.665] [LOG]    All module helpers loaded.
              [11:32:19.667] [LOG]    Starting server on port 8080 ...
              [11:32:19.691] [LOG]    Server started ...
              [11:32:19.693] [LOG]    Connecting socket for: updatenotification
              [11:32:19.695] [LOG]    Connecting socket for: MMM-Remote-Control
              [11:32:19.697] [LOG]    Starting node helper for: MMM-Remote-Control
              [11:32:19.714] [LOG]    Connecting socket for: MMM-GroveGestures
              [11:32:19.716] [LOG]    Connecting socket for: MMM-NotificationTrigger
              [11:32:19.763] [LOG]    Connecting socket for: MMM-PIR-Sensor
              [11:32:19.766] [LOG]    Connecting socket for: MMM-SystemStats
              [11:32:19.768] [LOG]    Connecting socket for: MMM-PublicTransportHafas
              [11:32:19.770] [LOG]    Connecting socket for: MMM-NASA
              [11:32:19.772] [LOG]    Starting node_helper for: MMM-NASA
              [11:32:19.774] [LOG]    Connecting socket for: MMM-NOAA
              [11:32:19.776] [LOG]    Starting module: MMM-NOAA
              [11:32:19.801] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
              [11:32:19.802] [LOG]    MMM-DWD-WarnWeather helper started...
              [11:32:19.803] [LOG]    Connecting socket for: newsfeed
              [11:32:19.805] [LOG]    Starting module: newsfeed
              [11:32:19.805] [LOG]    Sockets connected & modules started ...
              [11:32:20.114] [LOG]    Launching application.
              [11:32:25.625] [LOG]    Transportation fetcher for station with id '008000263' created.
              [11:32:26.201] [LOG]    Transportation fetcher for station with id '000625258' created.
              [11:32:26.356] [LOG]    Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                @MagicStarthilfe
                I don’t know whether MMM-Pages would be reason or not at this moment. Your last log seems so quite normal anyway (or saying nothing important really. :D)
                If you are using MMM-Pages, keep this kind of module is valid on each page. I think it’s better to keep it globally out of those kinds of suspending/resuming control.
                  @Sean Hello,
                  the error " Python script is terminated" I could actually fix by adjusting the i2c speed. Thanks for the tip.
                  The subsequent errors were caused by the NOAA module.
                  Thanks for the help.
                  • E Offline
                    Egnos @MagicStarthilfe
                    Hi @MagicStarthilfe I have the same problem as you:
                    [04.09.2023 12:50.18.499] [LOG]   [GESTURE] Gesture script is finished.
                    [04.09.2023 12:50.19.072] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                    [04.09.2023 12:50.19.270] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                    [04.09.2023 12:50.19.393] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                    [04.09.2023 12:59.32.764] [LOG]   Keyboard Interrupted
                    I use a Raspberry Pi 4 4GB with MagicMirror² v2.24.0 (the latest version…).
                    Do you remeber wich “i2c” speed you have used for fix the problem?
                    Thanks.
                      MMRIZE @Egnos
                      @Egnos
                      Try 10000 or 32000.
                        MMRIZE @Egnos
                        @Egnos
                        However the “terminated” message itself is nothing wrong.
                        “Too often without any gesture triggered” cases only be the issue.
                        • E Offline
                          Egnos @MMRIZE
                          @MMRIZE said in MMM-GroveGestures / Python script is terminated:
                          Try 10000 or 32000.
                          I think I tried 10000 and nothing changed, I’ll try 32000
                          Like in my case:
                          [04.09.2023 08:52.13.012] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 08:52.13.514] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 08:52.13.706] [LOG]   Keyboard Interrupted
                          [04.09.2023 08:52.13.707] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 08:52.14.208] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 08:52.14.414] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 08:52.14.547] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 09:00.23.783] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 09:02.38.447] [LOG]   Keyboard Interrupted
                          [04.09.2023 09:02.38.448] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 09:02.38.951] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 09:02.39.143] [LOG]   Keyboard Interrupted
                          [04.09.2023 09:02.39.147] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 09:02.39.650] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 09:02.39.811] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 09:02.39.932] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 09:08.15.627] [LOG]   Keyboard Interrupted
                          [04.09.2023 09:08.15.629] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 09:08.16.131] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 09:08.16.345] [LOG]   Keyboard Interrupted
                          [04.09.2023 09:08.16.348] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 09:08.16.852] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 09:08.17.038] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 09:08.17.158] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 09:31.42.854] [LOG]   Keyboard Interrupted
                          [04.09.2023 09:31.42.859] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 09:31.43.364] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 09:31.43.517] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 09:31.43.638] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 10:00.24.425] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 10:17.30.788] [LOG]   Keyboard Interrupted
                          [04.09.2023 10:17.30.792] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 10:17.31.298] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 10:17.31.451] [LOG]   Keyboard Interrupted
                          [04.09.2023 10:17.31.452] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 10:17.31.953] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 10:17.32.137] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 10:17.32.252] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 10:17.38.740] [LOG]   Keyboard Interrupted
                          [04.09.2023 10:17.38.741] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 10:17.39.243] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 10:17.39.462] [LOG]   Keyboard Interrupted
                          [04.09.2023 10:17.39.464] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 10:17.39.973] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 10:17.40.117] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 10:17.40.242] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 11:00.24.921] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 11:09.56.054] [LOG]   Keyboard Interrupted
                          [04.09.2023 11:09.56.059] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 11:09.56.573] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 11:09.56.793] [LOG]   Keyboard Interrupted
                          [04.09.2023 11:09.56.802] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 11:09.57.364] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 11:09.57.631] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 11:09.57.754] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 12:00.25.300] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 12:50.17.726] [LOG]   Keyboard Interrupted
                          [04.09.2023 12:50.17.736] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 12:50.18.243] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 12:50.18.496] [LOG]   Keyboard Interrupted
                          [04.09.2023 12:59.32.765] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 12:59.33.269] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 12:59.33.470] [LOG]   Keyboard Interrupted
                          [04.09.2023 12:59.33.479] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 12:59.33.987] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 12:59.34.190] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 12:59.34.340] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 13:00.25.675] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 13:11.28.559] [LOG]   [SPOTIFY - Daniele] Will retry in 5 seconds ...
                          [04.09.2023 13:41.29.947] [LOG]   Keyboard Interrupted
                          [04.09.2023 13:41.29.948] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 13:41.30.452] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 13:41.30.681] [LOG]   Keyboard Interrupted
                          [04.09.2023 13:41.30.686] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 13:41.31.188] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 13:41.31.384] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 13:41.31.487] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 14:00.26.016] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 14:06.09.575] [LOG]   Keyboard Interrupted
                          [04.09.2023 14:06.09.576] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 14:06.10.364] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 14:06.10.574] [LOG]   Keyboard Interrupted
                          [04.09.2023 14:06.10.575] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 14:06.11.078] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 14:06.11.259] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 14:06.11.398] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 14:39.19.948] [LOG]   Keyboard Interrupted
                          [04.09.2023 14:39.19.957] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 14:39.20.460] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 14:39.20.983] [LOG]   Keyboard Interrupted
                          [04.09.2023 14:39.20.985] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 14:39.21.488] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 14:39.21.704] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 14:39.21.806] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 14:46.27.234] [LOG]   [SPOTIFY - Daniele] Will retry in 5 seconds ...
                          [04.09.2023 15:00.26.370] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 15:42.11.128] [LOG]   Keyboard Interrupted
                          [04.09.2023 15:42.11.130] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 15:42.11.634] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 15:42.12.259] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 15:42.12.268] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 15:51.34.615] [LOG]   Keyboard Interrupted
                          [04.09.2023 15:51.34.616] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 15:51.35.118] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 15:51.35.314] [LOG]   Keyboard Interrupted
                          [04.09.2023 15:51.35.315] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 15:51.35.820] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 15:51.35.999] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 15:51.36.125] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 15:53.18.947] [LOG]   Keyboard Interrupted
                          [04.09.2023 15:53.18.950] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 15:53.19.465] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 15:53.19.733] [LOG]   Keyboard Interrupted
                          [04.09.2023 15:53.19.736] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 15:53.20.241] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 15:53.20.474] [LOG]   Keyboard Interrupted
                          [04.09.2023 15:53.20.475] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 15:53.20.980] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 15:53.21.250] [LOG]   Keyboard Interrupted
                          [04.09.2023 15:53.21.253] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 15:53.21.760] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 15:53.22.249] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 15:53.22.250] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 16:00.26.809] [INFO]  Calendar-Fetcher: Broadcasting 12 events.
                          [04.09.2023 16:07.05.688] [LOG]   Keyboard Interrupted
                          [04.09.2023 16:07.05.690] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 16:07.06.193] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 16:07.06.363] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 16:07.06.474] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                          [04.09.2023 16:07.55.429] [LOG]   Keyboard Interrupted
                          [04.09.2023 16:07.55.432] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 16:07.55.935] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 16:07.56.121] [LOG]   Keyboard Interrupted
                          [04.09.2023 16:07.56.122] [LOG]   [GESTURE] Gesture script is finished.
                          [04.09.2023 16:07.56.626] [LOG]   [GESTURE] Python script is terminated. It will restart soon.
                          [04.09.2023 16:07.56.815] [LOG]   [GESTURE] ORIGIN:wake-up finish.
                          [04.09.2023 16:07.56.969] [LOG]   [GESTURE] ORIGIN:Paj7620 initialize register finished.
                            MMRIZE @Egnos
                            @Egnos
                            By spec, PAJ7620’s MAX i2c speed is 400Kbit/s (400,000) But sometimes Raspberry PI i2c cannot handle fast devices.
                            Have you tried testing the sensor?
                            cd ~/MagicMirror/modules/MMM-GroveGestures/py
                            And there could be other possible causes;
                            • Pins are not stably connected
                            • Too long cabling, > 30cm. The signal would be weaker or noisy.
                            • I2C frequency is still too high. Set slower (lesser number than your trials)
                            • I2C Bus overloaded, if you are connecting other i2c connections. (maybe more than 3 or 4s)
                            • E Offline
                              Egnos @MMRIZE
                              Yes, and also when appear [GESTURE] Python script is terminated. It will restart soon. the gesture works well.
                              I exclude it.
                              It will surely be longer, 40 or 50 cm
                              I tried all speeds, maybe with 32000 seems better.
                              From this value (32000) do I go down or up?
                              I exclude it. I have only Paj7620 and PIR sensor on GPIO…
                              I’m sure with the old version v2.23 of MM I always had the error messages but the gesture sensor always worked, with the new version v2.24.0 of MM sometimes the sensor stops working and I have to redo this procedure
                              https://github.com/MMRIZE/MMM-GroveGestures#install-hw
                              @MMRIZE Thanks for your precious advises.
                                MMRIZE @Egnos
                                @Egnos said in MMM-GroveGestures / Python script is terminated:
                                Hopefully not, over 30cm long cabling could be the issue. (You wrote 40~50cm, is it right?)
                                • E Offline
                                  Egnos @MMRIZE
                                  @MMRIZE Yes, from the GPIO to the sensor there will be about 40/45 cm…
                                    MMRIZE @Egnos
                                    @Egnos
                                    40~45cm seems somewhat too long. Could you build it shorter? or use a lower frequency than usual case.
                                    Ref. these;
                                    • https://learn.adafruit.com/working-with-i2c-devices/cable-length
                                    • https://www.telos.info/faq/i2c-cables-the-shorter-the-better/
                                    • E Offline
                                      Egnos @MMRIZE
                                      @MMRIZE The path of the sensor cables (Yellow, red, white and black) is this:
                                      Maybe I could shorten the wires a bit…
                                      Thanks for the links.
                                      ankonaskiff17A 1 Reply Last reply Reply Quote 0
                                      • ankonaskiff17A Offline
                                        ankonaskiff17 @Egnos
                                        @Egnos Maybe Sparkfun Midpoint and Endpoint to give you ample length. They tout over 100’ with those devices.
                                        • E Offline
                                          Egnos @ankonaskiff17
                                          @ankonaskiff17 said in MMM-GroveGestures / Python script is terminated:
                                          Endpoint
                                          Hi @ankonaskiff17, wich one of these?
                                          https://www.sparkfun.com/categories/304?page=1
                                          M ankonaskiff17A 2 Replies Last reply Reply Quote 0
                                            MMRIZE @Egnos
                                            @Egnos
                                            There are several “I2C Extenders” (Or “Active Terminator”)
                                            I haven’t tried this kind of thing, but it is worth researching.
                                            • https://sandboxelectronics.com/?product=active-i2c-long-cable-extender-p82b715-module
                                            • https://www.adafruit.com/product/4756
                                            • https://www.sparkfun.com/products/16988 (It needs QWIIC environment)
