    MM to periodically run a python or JS script?
    4 Posts 2 Posters 3.1k Views 2 Watching
    • Z Offline
      zichao92
      Hi there,
      Im still relatively new to the world of Magic Mirror and programming as well. As per topic, I have created a script that generates a JSON file as an output and i would like MM to make use of this output in one of my modules.
      is this possible?
      • T Offline
        tosti007 Module Developer
        I am not sure if you still need it, but just in case:
        As far as I know there is the “python-shell” library which lets you do exactly that.
        Paul-Vincent Roll used it in his facial recognition module, that’s how I found out.
        link: https://github.com/paviro/MMM-Facial-Recognition
        If there is anything don't hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        • Z Offline
          zichao92
          Hi @tosti007 ,
          I found out that by making use of the “exec” command works too. I came across this command while i was looking at the PIR sensor module ( https://github.com/paviro/MMM-PIR-Sensor ) . Thanks for sharing anyway!
          • T Offline
            tosti007 Module Developer @zichao92
            @zichao92 ah nice, that’s way easier aswell. Thanks for letting me know, might come in handy once!
