    Config help please
    15 Posts 3 Posters 8.5k Views 3 Watching
      snotrocket
      Oooooh. Would the different quotes come from notepad++ or something? I think I edited in that and copied via SSH.
      Fixing now.
        snotrocket
        Yay! It works! I added the NFL module and tweaked the compliments.
        Thank you so much!!! Working code is below.
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: 'en',
        	timeFormat: 12,
        	units: 'imperial',
        			module: 'alert',
        			module: 'clock',
        			position: 'top_left'
        			module: 'calendar',
        			header: 'US Holidays',
        			position: 'top_left',
        						symbol: 'calendar-check-o ',
        						url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                module: 'compliments',
                position: 'bottom_center',
                        updateInterval: 30000,
                        compliments: {
                                morning: [
                                "Good morning!",
        						"Lets go tackle today"
                                afternoon: [
                                "What an awesome day!"
                                evening: [
                                        "Did you do everything you wanted today?",
                                        "Wasn't the day just spectacular?"
        			module: 'currentweather',
        			position: 'top_right',
        				locationID: '',  //ID from http://www.openweathermap.org
        				appid: '#######################'
        			module: 'weatherforecast',
        			header: 'Weather Forecast',
        				appid: '############################'
        			module: 'newsfeed',
        			position: 'bottom_bar',
        				feeds: [
        						title: "ESPN",
        						url: "http://www.espn.com/espn/rss/news"
        						title: "Reuters Sports",
        						url: "http://feeds.reuters.com/reuters/sportsNews"
        				showSourceTitle: false,
        				showPublishDate: false
        			module: 'MMM-NFL',
        			position: 'middle_center',
        			colored: true,
        			helmets: true,
        			reloadInterval: 10000,
        			focus_on: ['CHI']
        strawberry 3.141S L 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @snotrocket
          @snotrocket there is no need to let the nfl module reload every 10 seconds, it will detect itself if there is a live match and during live matches it will refresh data more frequently
            snotrocket
            So set it to an hour or two?
              @snotrocket if you want to use the default of 30mins you can remove it from your config.js completely
                snotrocket
                even better! Thanks.
                  snotrocket
                  Can i set the size of the NFL module? in the middle it takes up a huge amount of the screen when it shows all upcoming matches.
                    @snotrocket you can either limit with focus_on option the amount of matches displayed or use custom.css to make personal changes to the style
                    • L Offline
                      l8kerjuan @snotrocket
                      @snotrocket any chance you have a photo of what your mirror looks like… as far as layout… havent been able to see a functioning nfl or nhl module up on screen. just curios if i even want to tinker and add to mine… im so close to being done!! thanks
                        snotrocket @l8kerjuan
                        @l8kerjuan Here is the base config on a monitor, not the mirror when I was!testing it. I removed the module before the mirror was finished because the Bears were well… Da Bears. ! I think I have a copy of the config file as well. I’ll go look for it.
