Config help please
Hello all. Pretty new to this and just love it. Making some mirrors for xmas and just can’t get the config file correct. what am i missing?
Thanks in advance!
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, language: 'en', timeFormat: 12, units: 'imperial', modules: [ { module: 'alert', }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'US Holidays', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' } ] } }, { module: 'compliments', position: 'lower_third' }, { module: 'currentweather', position: 'top_right', config: { location: 'Chicago', locationID: '', //ID from http://www.openweathermap.org appid: '#########################' } }, { module: 'weatherforecast', position: 'top_right', header: 'Weather Forecast', config: { location: 'Chicago', locationID: '', //ID from http://www.openweathermap.org appid: '##########################' } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "ESPN", url: “http://www.espn.com/espn/rss/news” }, { title: “Reuters Sports”, url: “http://feeds.reuters.com/reuters/sportsNews” }, { title: "Yahoo NFL" https://sports.yahoo.com/nfl/rss.xml }, ], showSourceTitle: false, showPublishDate: false } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;} -
Yay! It works! I added the NFL module and tweaked the compliments.
Thank you so much!!! Working code is below.
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, language: 'en', timeFormat: 12, units: 'imperial', modules: [ { module: 'alert', }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'US Holidays', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' } ] } }, { module: 'compliments', position: 'bottom_center', config: { updateInterval: 30000, compliments: { morning: [ "Good morning!", "Lets go tackle today" ], afternoon: [ "What an awesome day!" ], evening: [ "Did you do everything you wanted today?", "Wasn't the day just spectacular?" ] } } }, { module: 'currentweather', position: 'top_right', config: { location: 'Chicago', locationID: '', //ID from http://www.openweathermap.org appid: '#######################' } }, { module: 'weatherforecast', position: 'top_right', header: 'Weather Forecast', config: { location: 'Chicago', locationID: '', //ID from http://www.openweathermap.org appid: '############################' } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "ESPN", url: "http://www.espn.com/espn/rss/news" }, { title: "Reuters Sports", url: "http://feeds.reuters.com/reuters/sportsNews" }, ], showSourceTitle: false, showPublishDate: false } }, { module: 'MMM-NFL', position: 'middle_center', config: { colored: true, helmets: true, reloadInterval: 10000, focus_on: ['CHI'] } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;} -
@snotrocket you used the wrong quotes in the newsfeed section and for the last feed you missed to specify
url:{ module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "ESPN", url: "http://www.espn.com/espn/rss/news" }, { title: "Reuters Sports", url: "http://feeds.reuters.com/reuters/sportsNews" }, { title: "Yahoo NFL", url: "https://sports.yahoo.com/nfl/rss.xml" }, ], showSourceTitle: false, showPublishDate: false } } -
Fixed it. Still a no go.
Thanks in advance.
Config:
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, language: 'en', timeFormat: 12, units: 'imperial', modules: [ { module: 'alert', }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'US Holidays', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' } ] } }, { module: 'compliments', position: 'lower_third' }, { module: 'currentweather', position: 'top_right', config: { location: 'Chicago', locationID: '', //ID from http://www.openweathermap.org appid: '#########################' } }, { module: 'weatherforecast', position: 'top_right', header: 'Weather Forecast', config: { location: 'Chicago', locationID: '', //ID from http://www.openweathermap.org appid: '##########################' } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "ESPN", url: “http://www.espn.com/espn/rss/news” }, { title: “Reuters Sports”, url: “http://feeds.reuters.com/reuters/sportsNews” }, { title: "Yahoo NFL" url: "https://sports.yahoo.com/nfl/rss.xml" }, ], showSourceTitle: false, showPublishDate: false } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;} -
@snotrocket you are still using the wrong quotes use
"or'instead of“ -
Oooooh. Would the different quotes come from notepad++ or something? I think I edited in that and copied via SSH.
Fixing now.
@snotrocket there is no need to let the nfl module reload every 10 seconds, it will detect itself if there is a live match and during live matches it will refresh data more frequently
So set it to an hour or two?
@snotrocket if you want to use the default of 30mins you can remove it from your config.js completely
even better! Thanks.
Can i set the size of the NFL module? in the middle it takes up a huge amount of the screen when it shows all upcoming matches.
@snotrocket you can either limit with focus_on option the amount of matches displayed or use custom.css to make personal changes to the style
@snotrocket any chance you have a photo of what your mirror looks like… as far as layout… havent been able to see a functioning nfl or nhl module up on screen. just curios if i even want to tinker and add to mine… im so close to being done!! thanks
@l8kerjuan Here is the base config on a monitor, not the mirror when I was!testing it. I removed the module before the mirror was finished because the Bears were well… Da Bears. ! I think I have a copy of the config file as well. I’ll go look for it.
@snotrocket that looks cool. thanks
