    Config help please
    15 Posts 3 Posters 8.6k Views 3 Watching
      snotrocket
      Yay! It works! I added the NFL module and tweaked the compliments.
      Thank you so much!!! Working code is below.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: 'en',
      	timeFormat: 12,
      	units: 'imperial',
      			module: 'alert',
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar',
      			header: 'US Holidays',
      			position: 'top_left',
      						symbol: 'calendar-check-o ',
              module: 'compliments',
              position: 'bottom_center',
                      updateInterval: 30000,
                      compliments: {
                              morning: [
                              "Good morning!",
      						"Lets go tackle today"
                              afternoon: [
                              "What an awesome day!"
                              evening: [
                                      "Did you do everything you wanted today?",
                                      "Wasn't the day just spectacular?"
      			module: 'currentweather',
      			position: 'top_right',
      				locationID: '',  //ID from http://www.openweathermap.org
      				appid: '#######################'
      			module: 'weatherforecast',
      			header: 'Weather Forecast',
      				appid: '############################'
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "ESPN",
      						url: "http://www.espn.com/espn/rss/news"
      						title: "Reuters Sports",
      						url: "http://feeds.reuters.com/reuters/sportsNews"
      				showSourceTitle: false,
      				showPublishDate: false
      			module: 'MMM-NFL',
      			position: 'middle_center',
      			colored: true,
      			helmets: true,
      			reloadInterval: 10000,
      			focus_on: ['CHI']
      strawberry 3.141S L 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @snotrocket
        @snotrocket there is no need to let the nfl module reload every 10 seconds, it will detect itself if there is a live match and during live matches it will refresh data more frequently
          snotrocket
          So set it to an hour or two?
            @snotrocket if you want to use the default of 30mins you can remove it from your config.js completely
              snotrocket
              even better! Thanks.
                snotrocket
                Can i set the size of the NFL module? in the middle it takes up a huge amount of the screen when it shows all upcoming matches.
                  @snotrocket you can either limit with focus_on option the amount of matches displayed or use custom.css to make personal changes to the style
                  • L Offline
                    l8kerjuan @snotrocket
                    @snotrocket any chance you have a photo of what your mirror looks like… as far as layout… havent been able to see a functioning nfl or nhl module up on screen. just curios if i even want to tinker and add to mine… im so close to being done!! thanks
                      snotrocket @l8kerjuan
                      @l8kerjuan Here is the base config on a monitor, not the mirror when I was!testing it. I removed the module before the mirror was finished because the Bears were well… Da Bears. ! I think I have a copy of the config file as well. I’ll go look for it.
                      • L Offline
                        @snotrocket that looks cool. thanks
