Config help please
15 Posts 3 Posters 7.8k Views 3 Watching
    snotrocket
    Hello all. Pretty new to this and just love it. Making some mirrors for xmas and just can’t get the config file correct. what am i missing?
    Thanks in advance!
    /* Magic Mirror Config Sample
     * MIT Licensed.
    var config = {
    	port: 8080,
    	language: 'en',
    	timeFormat: 12,
    	units: 'imperial',
    			module: 'alert',
    			module: 'clock',
    			position: 'top_left'
    			module: 'calendar',
    			header: 'US Holidays',
    			position: 'top_left',
    						symbol: 'calendar-check-o ',
    			module: 'compliments',
    			position: 'lower_third'
    			module: 'currentweather',
    			position: 'top_right',
    				locationID: '',  //ID from http://www.openweathermap.org
    				appid: '#########################'
    			module: 'weatherforecast',
    			header: 'Weather Forecast',
    				appid: '##########################'
    			module: 'newsfeed',
    			position: 'bottom_bar',
    				feeds: [
    						title: "ESPN",
    						url: “http://www.espn.com/espn/rss/news”
    						title: “Reuters Sports”,
    						url: “http://feeds.reuters.com/reuters/sportsNews”
    						title: "Yahoo NFL"
    					https://sports.yahoo.com/nfl/rss.xml
    				showSourceTitle: false,
    				showPublishDate: false
    S 1 Reply Last reply Dec 21, 2016, 6:39 PM Reply Quote 0
      snotrocket
      Yay! It works! I added the NFL module and tweaked the compliments.
      Thank you so much!!! Working code is below.
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: 'en',
      	timeFormat: 12,
      	units: 'imperial',
      			module: 'alert',
      			module: 'clock',
      			module: 'calendar',
              position: 'bottom_center',
                      updateInterval: 30000,
                      compliments: {
                              morning: [
                              "Good morning!",
      						"Lets go tackle today"
                              afternoon: [
                              "What an awesome day!"
                              evening: [
                                      "Did you do everything you wanted today?",
                                      "Wasn't the day just spectacular?"
      				appid: '#######################'
      				appid: '############################'
      			module: 'newsfeed',
      				feeds: [
      						title: "ESPN",
      						url: "http://www.espn.com/espn/rss/news"
      						title: "Reuters Sports",
      						url: "http://feeds.reuters.com/reuters/sportsNews"
      			module: 'MMM-NFL',
      			position: 'middle_center',
      			colored: true,
      			helmets: true,
      			reloadInterval: 10000,
      			focus_on: ['CHI']
      S L 2 Replies Last reply Dec 21, 2016, 8:19 PM Reply Quote 0
        strawberry 3.141 Project Sponsor Module Developer @snotrocket
        @snotrocket you used the wrong quotes in the newsfeed section and for the last feed you missed to specify url:
        		module: 'newsfeed',
        			feeds: [
        					title: "ESPN",
        					title: "Yahoo NFL",
                                                url: "https://sports.yahoo.com/nfl/rss.xml"
          snotrocket
          Fixed it. Still a no go.
          Thanks in advance.
          Config:
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'en',
          	timeFormat: 12,
          	units: 'imperial',
          			module: 'alert',
          			module: 'clock',
          			module: 'calendar',
          			module: 'newsfeed',
          				feeds: [
          						title: "ESPN",
          						title: "Yahoo NFL"
          S 1 Reply Last reply Dec 21, 2016, 6:48 PM Reply Quote 0
            @snotrocket you are still using the wrong quotes use " or ' instead of “
              snotrocket
              Oooooh. Would the different quotes come from notepad++ or something? I think I edited in that and copied via SSH.
              Fixing now.
                snotrocket
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: 'en',
                	timeFormat: 12,
                	units: 'imperial',
                			module: 'alert',
                			module: 'clock',
                			module: 'calendar',
                                compliments: {
                                        morning: [
                                        "Good morning!",
                                        afternoon: [
                                        evening: [
                			module: 'newsfeed',
                				feeds: [
                						title: "ESPN",
                			module: 'MMM-NFL',
                			colored: true,
                			helmets: true,
                			focus_on: ['CHI']
                  @snotrocket there is no need to let the nfl module reload every 10 seconds, it will detect itself if there is a live match and during live matches it will refresh data more frequently
                    snotrocket
                    So set it to an hour or two?
                    S 1 Reply Last reply Dec 21, 2016, 8:51 PM Reply Quote 0
                      @snotrocket if you want to use the default of 30mins you can remove it from your config.js completely
                        snotrocket
                        even better! Thanks.
