    Config help please
    15 Posts 3 Posters 8.5k Views 3 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @snotrocket
      @snotrocket you are still using the wrong quotes use " or ' instead of “
        snotrocket
        Oooooh. Would the different quotes come from notepad++ or something? I think I edited in that and copied via SSH.
        Fixing now.
          snotrocket
          Yay! It works! I added the NFL module and tweaked the compliments.
          Thank you so much!!! Working code is below.
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'en',
          	timeFormat: 12,
          	units: 'imperial',
          			module: 'alert',
          			module: 'clock',
          			position: 'top_left'
          			module: 'calendar',
          			header: 'US Holidays',
          			position: 'top_left',
          						symbol: 'calendar-check-o ',
                  module: 'compliments',
                  position: 'bottom_center',
                          updateInterval: 30000,
                          compliments: {
                                  morning: [
                                  "Good morning!",
          						"Lets go tackle today"
                                  afternoon: [
                                  "What an awesome day!"
                                  evening: [
                                          "Did you do everything you wanted today?",
                                          "Wasn't the day just spectacular?"
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '',  //ID from http://www.openweathermap.org
          				appid: '#######################'
          			module: 'weatherforecast',
          			header: 'Weather Forecast',
          				appid: '############################'
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "ESPN",
          						url: "http://www.espn.com/espn/rss/news"
          						title: "Reuters Sports",
          						url: "http://feeds.reuters.com/reuters/sportsNews"
          				showSourceTitle: false,
          				showPublishDate: false
          			module: 'MMM-NFL',
          			position: 'middle_center',
          			colored: true,
          			helmets: true,
          			reloadInterval: 10000,
          			focus_on: ['CHI']
          strawberry 3.141S L 2 Replies Last reply Reply Quote 0
            @snotrocket there is no need to let the nfl module reload every 10 seconds, it will detect itself if there is a live match and during live matches it will refresh data more frequently
              snotrocket
              So set it to an hour or two?
                @snotrocket if you want to use the default of 30mins you can remove it from your config.js completely
                  snotrocket
                  even better! Thanks.
                    snotrocket
                    Can i set the size of the NFL module? in the middle it takes up a huge amount of the screen when it shows all upcoming matches.
                      @snotrocket you can either limit with focus_on option the amount of matches displayed or use custom.css to make personal changes to the style
                      • L Offline
                        l8kerjuan @snotrocket
                        @snotrocket any chance you have a photo of what your mirror looks like… as far as layout… havent been able to see a functioning nfl or nhl module up on screen. just curios if i even want to tinker and add to mine… im so close to being done!! thanks
