    Which web server is installed with Magic Mirror 2?
    3 Posts 2 Posters 939 Views 2 Watching
    • P Offline
      pi-user
      Which web server is installed with Magic Mirror 2 so that it can be accessed via http? Is a Node.js service running in the background? Can you use the Magic Mirror 2 web server for other purposes so that you don’t have to install a second web server?
      Many thanks for the help
      • ? Offline
        A Former User @pi-user
        @pi-user
        MM has its own express to serve front. And some modules also implement its own express in node_helper.js.
        You don’t need any additional webserver but, If you need port forwarding or additional tricks, you might need nginx or apache, but that is not related to MM directly.
        • P Offline
          pi-user
          Thank you very much.
