    txt-file-include doesn´t work
    txtfileinclude
    4 Posts 2 Posters 2.5k Views 2 Watching
    • K Offline
      k3rn3lpanic
      Re: .txt file include
      Hi strawberry 3.141,
      i´ve read your interesting threat with regard to including textfiles.
      Your posted solution doesn´t work for me, and im searching why and i don´t find any failure…
      MMM-OEBBv2.js:
      Module.register("MMM-OEBBv2",{
              defaults: {
                      updateInterval: 30 * 60 * 1000 //reads the file every 30 mins
              start: function(){
                      this.sendSocketNotification("START", this.config);
                      if(notification === "DATA"){
                              this.dataFile = payload;
                              this.updateDom();
              getDom: function(){
                      if(this.dataFile){
                              wrapper.innerHTML = this.dataFile;
                      } else {
                              wrapper.innerHTML = "No Data!";
                      return wrapper;
      node-helper.js:
      const NodeHelper = require("node_helper");
      const fs= require("fs");
      //here comes the part of the nodehelper after the 3 dots as posted above
                      if(notification === "START"){
                              this.config = payload;
                              this.readData();
                              setInterval(() => {
                                      this.readData();
                              }, this.config.updateInterval);
              readData: function(){
                      //to read a file to do the following
                      fs.readFile("daten.txt", "utf8", (err, data) => {
                              if (err) throw err;
                              this.sendSocketNotification("DATA", data);
      daten.txt:
      WB 912 um 13:00 von Bahnsteig 6A-C
      S 2 um 13:04 von Bahnsteig 5A-C
      REX 4410 um 13:04 von Bahnsteig 8A-C
      On the mirror always “No Data!” is shown.
      Please help me…
      Kind regards
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @k3rn3lpanic
        @k3rn3lpanic
            fs.readFile("modules/MMM-OEBBv2/daten.txt", "utf8", (err, data) => {
                if (err) throw err;
        • K Offline
          k3rn3lpanic
          @strawberry-3-141 i´ve changed the path in the node-helper.js, but it doesn´t solve my problem…
          Are there any other opportunities?
                                  this.readData();
                                  setInterval(() => {
                                          this.readData();
                                  if (err) throw err;
          kind regards
          k3rn3lpanic
            problem was he named node_helper.js as node-helper.js
