    .txt file include
    59 Posts 6 Posters 41.0k Views 6 Watching
      dominic
      Hello, i have a .txt file,
      this file I want to embed to the mirror. So the
      Content is displayed on the mirror.
      In addition , the file should be up-dated after a time= x.
      can someone help me?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @dominic
        @dominic this should give you an idea how to solve your problem, I just wrote it down maybe you have to adjust something a little bit and it’s not a finished solution
        • nodehelper:
        const fs = require('fs');
            if(notification === 'START'){
                this.config = payload;
                this.readData();
                setInterval(() => {
                    this.readData();
                }, this.config.updateInterval);
        readData: function(){
            //to read a file to do the following
            fs.readFile('YOUR FILE PATH', (err, data) => {
                if (err) throw err;
                this.sendSocketNotification('DATA', data);
        • module:
        defaults: {
            updateInterval: 30*60*1000 //reads the file every 30 mins
        start: function(){
            this.sendSocketNotification('START', this.config);
            if(notification === 'DATA'){
                this.dataFile = payload;
                this.updateDom();
        getDom: function(){
            var wrapper = document.createElement('div');
            if(this.dataFile){
                wrapper.innerHTML = this.dataFile;
            } else {
                wrapper.innerHTML = 'No data';
            return wrapper;
          dominic @strawberry 3.141
          @strawberry-3.141 Hi thank you.
          Sorry for the questions, i´m new in .js.
          Where do I insert the nodehelper und the module and and what I need to modify?
          I have insert the nodehelper code in the file: MagicMirror/modules/node_modules/node_helper/index.js.
          And the module code in /MagicMirror/modules/sensor/sensor.js.
          on the mirror is displayed : Sensor module_2_sensor…
            there is a general design your module have to look like
            you have to create a directory in ~/MagicMirror/modules/YOUR_MODULE_NAME
            then create a file YOUR_MODULE_NAME.js
            Module.register("YOUR_MODULE_NAME",{
                //here comes the rest of the code for module I posted above
            then create a file node_helper.js
            const NodeHelper = require("node_helper");
            const fs= require("fs");
                //here comes the part of the nodehelper after the 3 dots as posted above
              @strawberry-3.141 Thanks for the fast answer :)
              I did it , just as you said it. on the mirror is displayed : NO DATA
              Here is the code from the nodehelper:
              Is the path specified correctly or I need to change something?
              • readData: function(){
                fs.readFile(‘/home/pi/MagicMirror/Test-temp.txt’, (err, data) => {
                if (err) throw err;
                this.sendSocketNotification(‘DATA’, data);
                i think this should do the job
                fs.readFile('Test-temp.txt', (err, data) => {
                  @strawberry-3.141
                  hi, now i get " [object ArryBuffer]"
                  what did i worng?
                    sry wasn’t aware of that a buffer gets returned instead of a string if there is no encoding specified
                    fs.readFile('Test-temp.txt', 'utf8', (err, data) => {
                      @strawberry-3.141 said in .txt file include:
                      fs.readFile(‘Test-temp.txt’, ‘utf8’, (err, data) => {
                      Hi, sorry.
                      It didn´t work :/
                      Here is the node_helper.js code
                              this.readData();
                              setInterval(() => {
                                  this.readData();
                              if (err) throw err;
                      and here is the sensor.js code:
                      Module.register("sensor",{
                         defaults: {
                      start: function(){
                              this.updateDom();
                      getDom: function(){
                          if(this.dataFile){
                          } else {
                          return wrapper;
                      Waht did i wrong? :D
                      I hope you can help me.
                      Note from admin: Please use Markdown on code snippets for easier reading!
                        this works for me you had everywhere weird quotes and the updateinterval was also wrong
                        	defaults: {
                        		updateInterval: 30 * 60 * 1000 //reads the file every 30 mins
                        	start: function(){
                        		this.sendSocketNotification("START", this.config);
                        		if(notification === "DATA"){
                        			this.updateDom();
                        	getDom: function(){
                        		if(this.dataFile){
                        		} else {
                        			wrapper.innerHTML = "No data";
                        		return wrapper;
                        		if(notification === "START"){
                        			this.readData();
                            			setInterval(() => {
                                			this.readData();
                        		fs.readFile("Test-temp.txt", "utf8", (err, data) => {
                        			if (err) throw err;
                        			this.sendSocketNotification("DATA", data);
                          @strawberry-3.141
                          Mh… than i don´t know…
                          i have copy your code but it doesen´t work…
                          I need to change anything els?
                          And thank you for your patience :)
                            @strawberry-3.141 1_1472575446381_sensor.js 0_1472575446381_node_helper.js 0_1472575579268_config.js
                            Here are my code files. Maybe this can help?
                              do you get any error in the console or in the electron console (cmd+shift+I)
                              did you place your Test-temp.txt in ~/MagicMirror or somewhere else?
                                @strawberry-3.141
                                Sorry i hade no time the last days.
                                I put the Test-temp.txt in ~/MagicMirror and for tests ind~/MagicMirror/modules/sensor.
                                But nothing happens.
                                I get only an error about the weatherforecast bu nothing els…
                                  @dominic can you remove the weatherforecast from the config when its causing issues, so we can troubleshoot this module?
                                  • yawnsY Offline
                                    yawns Moderator
                                    Hm, maybe you could try this.
                                    Put the file in the modules folder and open it with “./Test-temp.txt“
                                    Additionally i would suggest to go with lowercase during testing to exclude case sensitive mistakes.
                                    strawberry 3.141S D 2 Replies Last reply Reply Quote 0
                                      strawberry 3.141 Project Sponsor Module Developer @yawns
                                      @yawns electron is running in ~/MagicMirror, so putting the file in the modules directory and do ./Test-temp.txt won’t work. The code is generally working I tested it on my rpi
                                        @strawberry-3.141 Hi :) it works :)
                                        i don´t know why, but it works. I have reseted the system and after taht ist works.
                                        Thank you very mutch.
                                        i want to display not all the text out of the .txt file.
                                        Do you know what i must change in the node_helper.js?
                                          i think this depends on the content of the file
                                            @strawberry-3.141 in the file are values from a dht22 temp.sensor.
                                            but i only need the values for Humidity = xx and Temperature =xx.
                                            is there any why to get only this values ?
                                            • 1 / 3
