    .txt file include
    59 Posts 6 Posters 38.7k Views 6 Watching
      banbutcher
      wow… works like a charm! lists all tv shows perfectly! :)
      is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
      and possibly limit output to 10 lines?
      Thanks,
      Richie
        sdetweil @banbutcher
        @banbutcher >is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
        sure
        // should make this a config variable by adding to module defaults
        // then would be this.config.counter
        // get display limit, 10 if not specified in defaults
        var counter=this.config.counter || 10
                  var table=document.createElement("table")
                  wrapper.appendChild(table)
                  for(filename of this.dataFile) {
                       // if the name is not zero length (split could have returned for just linefeed
                       // and the view limit has not been reached
                       if(filename.length >0 && counter>0) {
                              // get the filename prefix
                              var tr=document.createElement("tr")
                              table.appendChild(tr)
                              var td=document.createElement("td")
                              tr.appendChild(td)
                              var split = splitRegExp.exec(filename);
                              if(split)
                                  td.innerText=split
                              else
                                  td.innerText='name not matched '+ filename
                              counter--;
        return wrapper;
        or using the text form
        		if(this.dataFile){
                                var output_list= [];
                                // setup regex, no i  no g (only once, and case sensitive)
                                var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/;
                                // loop thru the list of filenames
                                    if(filename.length >0 && counter >0) {
                                       // save name to the output list, as a table entry
                                       // remove space after the ->< , the forum hides everything after unless a space
                                       // table has a row,
                                       output_list.push("< tr>< td>")
                                       // with data
                                       if(split)
                                          output_list.push(split)
                                       else
                                           output_list.push('name not matched '+ filename)
                                       // end of data and row
                                       output_list.push("< /td>< /tr>")
                                       counter--;
                                // insert the table into the wrapper
        			wrapper.innerHTML = "< table>" + output_list.join('')+ "< /table>";
        		} else {
          banbutcher
          the counter part worked great, but then when i tried to add it if loop for the name check, im getting “no data” maybe i messed up copying across?
          			var counter=this.config.counter || 11
                                         // table has a row,
                                         output_list.push("<tr><td>")
          			       // with data
          			       if(split )
          			       else
          			          output_list.push('name not found:'+ filename)
                                         output_list.push("</td></tr>")
          			       counter--;
          			wrapper.innerHTML = "<table>" + output_list.join('')+ "</table>";
          		 } else {
          			wrapper.innerHTML = "No Data";
            @banbutcher said in .txt file include:
            sorry, don’t understand the words…
            this is the test if the regex worked
                                           if(split)
            			       else
              banbutcher
              this code works…
              		if(this.dataFile){
                                             // table has a row,
                                             // with data
              			       counter--;
              		 } else {
              this code doesnt…
                                             // table has a row,
              			       // with data
              			       if(split.length >0 )
              			       else
              			       counter--;
              		 } else {
              Richie :)
                @banbutcher
                my fault… I ‘assumed’ that regex would return an empty string… it returns a null value…
                I fixed my sample, and your paste with the correct test
                if(split)
                instead of
                if(split.length>0)
                  sdetweil
                  and for others trying to implement code, you can debug using the developers console, OR make little sample files and run them directly in node
                  i named this testit.js in the user home folder (~/testit.js)
                  var dataFile=["Archer S01E02Someshow.tv",
                  "Archer S01E03Someshow .tv",
                  "Archer S01e02Someshow .tv",
                  "Archer S01E04Someshow .tv",
                  "Archer S01E05someshow .tv",
                  "Archer s01E02Someshow .tv",
                  "Archer S01E09Someshow .tv",
                  var counter1=10
                                      if(dataFile){
                                         var counter=counter1 || 10
                                          for(filename of dataFile) {
                                                 // table has a row,
                                                 // with data
                                                 if(split)
                                                 else
                                                 counter--;
                              console.log( "<table>" + output_list.join('')+ "</table>");
                  and then
                  cd ~
                  node testit.js
                    banbutcher
                    Perfect!!
                    now i can go to bed! :D tomorrows task will be styling with css! any pointers?
                    as always… thanks again!!
                    Richie
                      sorry, that is my weakness… I cannot make anything look good… I can tell you if it DOES look good, but cannot do it myself… I have no eye for that all…
                      • 6
                      • 6 / 6
