.txt file include
@strawberry-3.141
Mh… than i don´t know…
i have copy your code but it doesen´t work…
I need to change anything els?And thank you for your patience :)
@strawberry-3.141 1_1472575446381_sensor.js 0_1472575446381_node_helper.js 0_1472575579268_config.js
Here are my code files. Maybe this can help?
do you get any error in the console or in the electron console (cmd+shift+I)
did you place your Test-temp.txt in ~/MagicMirror or somewhere else?
@strawberry-3.141
Sorry i hade no time the last days.I put the Test-temp.txt in ~/MagicMirror and for tests ind~/MagicMirror/modules/sensor.
But nothing happens.I get only an error about the weatherforecast bu nothing els…
@dominic can you remove the weatherforecast from the config when its causing issues, so we can troubleshoot this module?
Hm, maybe you could try this.
Put the file in the modules folder and open it with “./Test-temp.txt“
Additionally i would suggest to go with lowercase during testing to exclude case sensitive mistakes. -
@yawns electron is running in
~/MagicMirror, so putting the file in the modules directory and do./Test-temp.txtwon’t work. The code is generally working I tested it on my rpi -
@strawberry-3.141 Hi :) it works :)
i don´t know why, but it works. I have reseted the system and after taht ist works.
Thank you very mutch.i want to display not all the text out of the .txt file.
Do you know what i must change in the node_helper.js? -
i think this depends on the content of the file
@strawberry-3.141 in the file are values from a dht22 temp.sensor.
but i only need the values for Humidity = xx and Temperature =xx.is there any why to get only this values ?
