    .txt file include
    59 Posts 6 Posters 45.1k Views 6 Watching
    • strawberry 3.141S Offline
      do you get any error in the console or in the electron console (cmd+shift+I)
      did you place your Test-temp.txt in ~/MagicMirror or somewhere else?
        dominic @strawberry 3.141
        @strawberry-3.141
        Sorry i hade no time the last days.
        I put the Test-temp.txt in ~/MagicMirror and for tests ind~/MagicMirror/modules/sensor.
        But nothing happens.
        I get only an error about the weatherforecast bu nothing els…
          strawberry 3.141 Project Sponsor Module Developer @dominic
          @dominic can you remove the weatherforecast from the config when its causing issues, so we can troubleshoot this module?
          • Y Offline
            yawns Moderator
            Hm, maybe you could try this.
            Put the file in the modules folder and open it with “./Test-temp.txt“
            Additionally i would suggest to go with lowercase during testing to exclude case sensitive mistakes.
            strawberry 3.141S D 2 Replies Last reply Reply Quote 0
              strawberry 3.141 Project Sponsor Module Developer @yawns
              @yawns electron is running in ~/MagicMirror, so putting the file in the modules directory and do ./Test-temp.txt won’t work. The code is generally working I tested it on my rpi
                @strawberry-3.141 Hi :) it works :)
                i don´t know why, but it works. I have reseted the system and after taht ist works.
                Thank you very mutch.
                i want to display not all the text out of the .txt file.
                Do you know what i must change in the node_helper.js?
                  i think this depends on the content of the file
                    @strawberry-3.141 in the file are values from a dht22 temp.sensor.
                    but i only need the values for Humidity = xx and Temperature =xx.
                    is there any why to get only this values ?
                      dominic @yawns
                      @yawns Danke für deinen Tipp. Aber es läuft nun.
                      Habe aber nun ein anderes Problem ;)
                      gibt es eine Möglichkeit, die asugabe der txt Datei zu beregenzen, so dass mir nur bestimmte Werte angezeigt werden.
                      In der Datei stehen Werte von einem dht22 sensor und ich möchte nur diese werte ausgeben ohne die den anderen INhalt.
                        are these all in seperate lines?
                        if so then you could check in a for loop if there is the word humidity or temperature otherwise ignore the line
                          @strawberry-3.141
                          No. There is only one line.
                            can you please upload your txt file i have no clue how it looks like, so we can help you out with that
                              @strawberry-3.141
                              Raspberry Pi wiringPi DHT22 reader www.lolware.net Data not good, skip Data not good, skip Data not good, skip Humidity = 47.10 % Temperature = 24.50 *C .
                              This is the contetn of the .txt file. And its all in one line.
                                @strawberry-3.141 Hi, do you have any idea?
                                  getDom: function(){
                                  		if(this.dataFile){
                                                          var humidityRegExp = /Humidity = (.*?) %/ig;
                                                          var humidity = humidityRegExp.exec(this.dataFile)[1];
                                                          var temperatureRegExp = /Temperature = (.*?) *C/ig;
                                                          var temperature = temperatureRegExp.exec(this.dataFile)[1];
                                  			wrapper.innerHTML = "Humidity: " + humidity + "% and Temperature: " + temperature + "°C";
                                  		} else {
                                  			wrapper.innerHTML = "No data";
                                  		return wrapper;
                                    @strawberry-3.141 HI Thanks. Sorry but, where do I insert the code?
                                    I´m new in this…
                                      in sensor.js you have the function getdom replace it with this
                                        @strawberry-3.141 Yeah :) Thanks :)
                                          SaschaSP
                                          @strawberry-3-141 great solution from you.
                                          I want to use your solution not for showing Temperatur/ Humidity rather for showing alerts from sensors.
                                          The content from my txt is for example:
                                          Meldung Stellmotor Antrieb blockiert
                                          Zone Nebenantrieb
                                          Zeit 6.Juni 2018 10:40
                                          +++ENDE DER DATEI+++
                                          I change the sensor.js:
                                          Module.register("Home-Status",{
                                          	defaults: {
                                          		updateInterval: 0.5 * 60 * 1000 //reads the file every 30 seconds
                                          	start: function(){
                                          		this.sendSocketNotification("START", this.config);
                                          		if(notification === "DATA"){
                                          			this.dataFile = payload;
                                          			this.updateDom();
                                          	getDom: function(){
                                          		if(this.dataFile){
        var meldungRegExp = /Meldung = (.*?) /ig;
        var meldung = meldungRegExp.exec(this.dataFile)[1];
        var zoneRegExp = /Zone = (.*?) /ig;
        var zone = zoneRegExp.exec(this.dataFile)[1];
                                          			var zeitRegExp = /Zeit = (.*?) /ig;
                                          			var zeit = zeitRegExp.exec(this.dataFile)[1];
                                          			wrapper.innerHTML = "Meldung: " + meldung + " , Zone: " + zone + " , "Zeit: " + zeit" ;
                                          		} else {
                                          			wrapper.innerHTML = "No Data";
                                          		return wrapper;
                                          but it dosn´t work.
                                          Firtst problem: my txt have no seperators like = or :
                                          second probleme: my alert text (Meldung) contains of several words
                                          third Problem: only the newest txt should be displayed. The Names from the txt files are for example 20180112090125.txt or 20185912085949.txt etc. It´s not possible to edit the incoming txt names. Best way is to automaticly delete the previous txt
                                          I hope you can help me to Display " Meldung, Zone, Zeit" on my MagicMirror
                                          Best regards
                                          Sascha
                                            strawberry 3.141 Project Sponsor Module Developer @SaschaSP
                                            @saschasp you can change your regular expressions to the following:
                                            /Meldung (.*)/ig;, /Zone (.*)/ig; and /Zeit (.*)/ig;. This should help you displaying the data. For the problem with the newest file you need to do the following steps: Scan the directory, sort file list by highest number, read the first file.
                                            Scan the directory https://nodejs.org/api/fs.html#fs_fs_readdir_path_options_callback
                                            Sort the file names https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort
                                            Read the file https://nodejs.org/api/fs.html#fs_fs_readfile_path_options_callback
                                            • 2 / 3
