    .txt file include
    59 Posts 6 Posters 46.6k Views 6 Watching
    • strawberry 3.141S
      getDom: function(){
      		if(this.dataFile){
                              var humidityRegExp = /Humidity = (.*?) %/ig;
                              var humidity = humidityRegExp.exec(this.dataFile)[1];
                              var temperatureRegExp = /Temperature = (.*?) *C/ig;
                              var temperature = temperatureRegExp.exec(this.dataFile)[1];
      			wrapper.innerHTML = "Humidity: " + humidity + "% and Temperature: " + temperature + "°C";
      		} else {
      			wrapper.innerHTML = "No data";
      		return wrapper;
      D 1 Reply Last reply
        dominic @strawberry 3.141
        @strawberry-3.141 HI Thanks. Sorry but, where do I insert the code?
        I´m new in this…
        • strawberry 3.141S
          in sensor.js you have the function getdom replace it with this
            @strawberry-3.141 Yeah :) Thanks :)
              SaschaSP
              @strawberry-3-141 great solution from you.
              I want to use your solution not for showing Temperatur/ Humidity rather for showing alerts from sensors.
              The content from my txt is for example:
              Meldung Stellmotor Antrieb blockiert
              Zone Nebenantrieb
              Zeit 6.Juni 2018 10:40
              +++ENDE DER DATEI+++
              I change the sensor.js:
              Module.register("Home-Status",{
              	defaults: {
              		updateInterval: 0.5 * 60 * 1000 //reads the file every 30 seconds
              	start: function(){
              		this.sendSocketNotification("START", this.config);
              		if(notification === "DATA"){
              			this.dataFile = payload;
              			this.updateDom();
              	getDom: function(){
              		if(this.dataFile){
                                      var meldungRegExp = /Meldung = (.*?) /ig;
                                      var meldung = meldungRegExp.exec(this.dataFile)[1];
                                      var zoneRegExp = /Zone = (.*?) /ig;
                                      var zone = zoneRegExp.exec(this.dataFile)[1];
              			var zeitRegExp = /Zeit = (.*?) /ig;
              			var zeit = zeitRegExp.exec(this.dataFile)[1];
              			wrapper.innerHTML = "Meldung: " + meldung + " , Zone: " + zone + " , "Zeit: " + zeit" ;
              		} else {
              			wrapper.innerHTML = "No Data";
              		return wrapper;
              but it dosn´t work.
              Firtst problem: my txt have no seperators like = or :
              second probleme: my alert text (Meldung) contains of several words
              third Problem: only the newest txt should be displayed. The Names from the txt files are for example 20180112090125.txt or 20185912085949.txt etc. It´s not possible to edit the incoming txt names. Best way is to automaticly delete the previous txt
              I hope you can help me to Display " Meldung, Zone, Zeit" on my MagicMirror
              Best regards
              Sascha
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @SaschaSP
                @saschasp you can change your regular expressions to the following:
                /Meldung (.*)/ig;, /Zone (.*)/ig; and /Zeit (.*)/ig;. This should help you displaying the data. For the problem with the newest file you need to do the following steps: Scan the directory, sort file list by highest number, read the first file.
                Scan the directory https://nodejs.org/api/fs.html#fs_fs_readdir_path_options_callback
                Sort the file names https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort
                Read the file https://nodejs.org/api/fs.html#fs_fs_readfile_path_options_callback
                  SaschaSP @strawberry 3.141
                  @strawberry-3-141
                  Ok, i will try step by step.
                  Beginning with my first probleme:
                  The Output message (displayed on the mirror) is only displaying one word after the “identifyer-word”
                  identifyer "Meldung"
                  MagicMirror Display only Stellmotor
                  Antrieb blockiert is missing
                  The identifyer-wordsare Meldung Zone Zeit
                  The content from my txt:
                  Zone Nebenantrieb
                  My edited sensor.js:
                  	defaults: {
                  	start: function(){
                  			this.updateDom();
                  	getDom: function(){
                  		if(this.dataFile){
                                          var meldungRegExp = /Meldung (.*?) /ig;
                                          var zoneRegExp = /Zone (.*?) /ig;
                  			var zeitRegExp = /Zeit (.*?) /ig;
                  			wrapper.innerHTML = "Meldung: " + meldung + " Zone: " + zone + " Zeit: " + zeit;
                  		} else {
                  		return wrapper;
                  Result wich is displayed at MagicMirror:
                  Meldung:Stellmotor Zone:Nebenantrieb Zeit:6.Juni
                  • strawberry 3.141S
                    @saschasp your regular expressens are different from the one i posted, use them and I’m sure it will work
                      banbutcher
                      hi,
                      sorry to be dragging up old posts, but im trying to get my mirror to display the contents of a txt file and i have it partly working… i have the contents displaying on my mirror but its all showing up on one line, how can i display it with each line break as in txt file?
                      thanks
                        sdetweil @banbutcher
                        @banbutcher you will have to replace the line feeds (\n) with html breaks (
                          banbutcher
                          hi again,
                          im after getting my script to update my txt file with the names of downloaded movies and tv series… how would i go about reading the title of the series and just having the title and info ie:
                          if title has S**E** in it then
                          filename - Archer S01E01pilot 1080p x265.mkv
                          desired result - Archer S01E01
                          else its a movie and just add movie name
                          i think this is the bit of code im to edit but i havent got it working :(
                          	getDom: function(){
                          		if(this.dataFile){
                          		} else {
                          		return wrapper;
                          thanks
                          Richie
                            @banbutcher said in .txt file include:
                            using the regex tester,
                            https://regex101.com/
                            I think this is the regex u want
                            /.*[S][(0-9)]+[E][(0-9)]+/
                              banbutcher
                              that worked great…
                              however, im a little bit stuck again… your expression works fine and return the correct result but only on the first line of the file and only if i remove the [1] from the end of line 5 of the code
                              	getDom: function(){
                              		if(this.dataFile){
                                                      var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/ig;
                                                      var split = splitRegExp.exec(this.dataFile)[1];
                              			wrapper.innerHTML = split;
                              		} else {
                              		return wrapper;
                              do i need to stick it in some kind of loop? or am i reading the contents of file wrong?
                              again thanks for your help :)
                                @banbutcher is dataFile an array of filenames? then yes, you’ll need a loop.
                                so, you are moving part of name a, to a new array
                                then part of name b to the next slot in the array
                                array.push(item)
                                adds item to the end of the array
                                name_of_array =[] initializes name_of_array to be an empty array
                                then u will need to format the array of partial names
                                var x = name_of_array.join(separator)
                                will turn the array into x, a string with separator between the names
                                  banbutcher
                                  Band.Of.Brothers.E01.1080p.5.1Ch.BluRay.ReEnc-DeeJayAhmed.srt <br>
                                  Archer S01E03 Diversity Hire (1080p x265 10bit S94 Joy).mkv <br>
                                  devs.s01e02.720p.hdtv.x264-river[eztv].mkv <br>
                                  What.We.Do.in.the.Shadows.S02E02.Ghosts.720p.AMZN.WEBRip.DDP5.1.x264-NTb[eztv.io].mkv <br>
                                  What.We.Do.in.the.Shadows.S02E01.Resurrection.720p.AMZN.WEBRip.DDP5.1.x264-NTb[eztv.io].mkv <br>
                                  this is the file im reading from… im not sure if thats an array, sorry and i want them outputted same line by line just missing the trailing parts.
                                    @banbutcher reading how
                                      banbutcher
                                      this is my main module .js
                                      i think this is where im reading from :/
                                      Module.register("deluge",{
                                      	defaults: {
                                      		updateInterval: 10 * 60 * 1000 //reads the file every 10 mins
                                      	start: function(){
                                      			this.updateDom();
                                      //	getDom: function(){
                                      //		var wrapper = document.createElement("div");
                                      //		if(this.dataFile){
                                      //			wrapper.innerHTML = this.dataFile;
                                      //		} else {
                                      //			wrapper.innerHTML = "No data";
                                      //		return wrapper;
                                      	getDom: function(){
                                      		if(this.dataFile){
                                                              var split = splitRegExp.exec(this.dataFile);
                                      		} else {
                                      		return wrapper;
                                      im in way overmy head here!
                                      S 2 Replies Last reply
                                        @banbutcher reading in the node_helper, sending up to the module.
                                          banbutcher
                                          Node_helper :)
                                          const NodeHelper = require("node_helper");
                                          const fs= require("fs");
                                          //here comes the part of the nodehelper after the 3 dots as posted above
                                          		if(notification === "START"){
                                          			this.config = payload;
                                          			this.readData();
                                              			setInterval(() => {
                                                  			this.readData();
                                              			}, this.config.updateInterval);
                                          	readData: function(){
                                          		//to read a file to do the following
                                          		fs.readFile("new-tv-list.txt", "utf8", (err, data) => {
                                          			if (err) throw err;
                                          			this.sendSocketNotification("DATA", data);
                                            @banbutcher I won’t have time to look at this tonight
                                            B 1 Reply Last reply
                                            • 2 / 3
