    .txt file include
    59 Posts 6 Posters 46.4k Views 6 Watching
      dominic @strawberry 3.141
      @strawberry-3.141
      hi, now i get " [object ArryBuffer]"
      what did i worng?
      • strawberry 3.141S
        sry wasn’t aware of that a buffer gets returned instead of a string if there is no encoding specified
        fs.readFile('Test-temp.txt', 'utf8', (err, data) => {
        D 1 Reply Last reply
          @strawberry-3.141 said in .txt file include:
          fs.readFile(‘Test-temp.txt’, ‘utf8’, (err, data) => {
          Hi, sorry.
          It didn´t work :/
          Here is the node_helper.js code
          const NodeHelper = require("node_helper");
          const fs= require("fs");
              //here comes the part of the nodehelper after the 3 dots as posted above
              if(notification === 'START'){
                  this.config = payload;
                  this.readData();
                  setInterval(() => {
                      this.readData();
                  }, this.config.updateInterval);
          readData: function(){
              //to read a file to do the following
                  if (err) throw err;
                  this.sendSocketNotification('DATA', data);
          and here is the sensor.js code:
          Module.register("sensor",{
             defaults: {
              updateInterval: 30*60*1000 //reads the file every 30 mins
          start: function(){
              this.sendSocketNotification('START', this.config);
              if(notification === 'DATA'){
                  this.dataFile = payload;
                  this.updateDom();
          getDom: function(){
              var wrapper = document.createElement('div');
              if(this.dataFile){
                  wrapper.innerHTML = this.dataFile;
              } else {
                  wrapper.innerHTML = 'No data';
              return wrapper;
          Waht did i wrong? :D
          I hope you can help me.
          • strawberry 3.141S
            this works for me you had everywhere weird quotes and the updateinterval was also wrong
            	defaults: {
            		updateInterval: 30 * 60 * 1000 //reads the file every 30 mins
            	start: function(){
            		this.sendSocketNotification("START", this.config);
            		if(notification === "DATA"){
            			this.updateDom();
            	getDom: function(){
            		if(this.dataFile){
            		} else {
            			wrapper.innerHTML = "No data";
            		return wrapper;
            		if(notification === "START"){
            			this.readData();
                			setInterval(() => {
                    			this.readData();
            		fs.readFile("Test-temp.txt", "utf8", (err, data) => {
            			if (err) throw err;
            			this.sendSocketNotification("DATA", data);
            D 2 Replies Last reply
              @strawberry-3.141
              Mh… than i don´t know…
              i have copy your code but it doesen´t work…
              I need to change anything els?
              And thank you for your patience :)
                @strawberry-3.141 1_1472575446381_sensor.js 0_1472575446381_node_helper.js 0_1472575579268_config.js
                Here are my code files. Maybe this can help?
                • strawberry 3.141S
                  do you get any error in the console or in the electron console (cmd+shift+I)
                  did you place your Test-temp.txt in ~/MagicMirror or somewhere else?
                    @strawberry-3.141
                    Sorry i hade no time the last days.
                    I put the Test-temp.txt in ~/MagicMirror and for tests ind~/MagicMirror/modules/sensor.
                    But nothing happens.
                    I get only an error about the weatherforecast bu nothing els…
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @dominic
                      @dominic can you remove the weatherforecast from the config when its causing issues, so we can troubleshoot this module?
                      • Y
                        yawns Moderator
                        Hm, maybe you could try this.
                        Put the file in the modules folder and open it with “./Test-temp.txt“
                        Additionally i would suggest to go with lowercase during testing to exclude case sensitive mistakes.
                        strawberry 3.141S D 2 Replies Last reply
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @yawns
                          @yawns electron is running in ~/MagicMirror, so putting the file in the modules directory and do ./Test-temp.txt won’t work. The code is generally working I tested it on my rpi
                            @strawberry-3.141 Hi :) it works :)
                            i don´t know why, but it works. I have reseted the system and after taht ist works.
                            Thank you very mutch.
                            i want to display not all the text out of the .txt file.
                            Do you know what i must change in the node_helper.js?
                            • strawberry 3.141S
                              i think this depends on the content of the file
                                @strawberry-3.141 in the file are values from a dht22 temp.sensor.
                                but i only need the values for Humidity = xx and Temperature =xx.
                                is there any why to get only this values ?
                                  dominic @yawns
                                  @yawns Danke für deinen Tipp. Aber es läuft nun.
                                  Habe aber nun ein anderes Problem ;)
                                  gibt es eine Möglichkeit, die asugabe der txt Datei zu beregenzen, so dass mir nur bestimmte Werte angezeigt werden.
                                  In der Datei stehen Werte von einem dht22 sensor und ich möchte nur diese werte ausgeben ohne die den anderen INhalt.
                                  • strawberry 3.141S
                                    are these all in seperate lines?
                                    if so then you could check in a for loop if there is the word humidity or temperature otherwise ignore the line
                                      @strawberry-3.141
                                      No. There is only one line.
                                      • strawberry 3.141S
                                        can you please upload your txt file i have no clue how it looks like, so we can help you out with that
                                          @strawberry-3.141
                                          Raspberry Pi wiringPi DHT22 reader www.lolware.net Data not good, skip Data not good, skip Data not good, skip Humidity = 47.10 % Temperature = 24.50 *C .
                                          This is the contetn of the .txt file. And its all in one line.
                                            @strawberry-3.141 Hi, do you have any idea?
