    .txt file include
    59 Posts 6 Posters 37.9k Views 6 Watching
    • strawberry 3.141S Offline
      i think this should do the job
      fs.readFile('Test-temp.txt', (err, data) => {
        dominic @strawberry 3.141
        @strawberry-3.141
        hi, now i get " [object ArryBuffer]"
        what did i worng?
          sry wasn’t aware of that a buffer gets returned instead of a string if there is no encoding specified
          fs.readFile('Test-temp.txt', 'utf8', (err, data) => {
            @strawberry-3.141 said in .txt file include:
            fs.readFile(‘Test-temp.txt’, ‘utf8’, (err, data) => {
            Hi, sorry.
            It didn´t work :/
            Here is the node_helper.js code
            const NodeHelper = require("node_helper");
            const fs= require("fs");
                //here comes the part of the nodehelper after the 3 dots as posted above
                if(notification === 'START'){
                    this.config = payload;
                    this.readData();
                    setInterval(() => {
                        this.readData();
                    }, this.config.updateInterval);
            readData: function(){
                //to read a file to do the following
                    if (err) throw err;
                    this.sendSocketNotification('DATA', data);
            and here is the sensor.js code:
            Module.register("sensor",{
               defaults: {
                updateInterval: 30*60*1000 //reads the file every 30 mins
            start: function(){
                this.sendSocketNotification('START', this.config);
                if(notification === 'DATA'){
                    this.dataFile = payload;
                    this.updateDom();
            getDom: function(){
                var wrapper = document.createElement('div');
                if(this.dataFile){
                    wrapper.innerHTML = this.dataFile;
                } else {
                    wrapper.innerHTML = 'No data';
                return wrapper;
            Waht did i wrong? :D
            I hope you can help me.
              this works for me you had everywhere weird quotes and the updateinterval was also wrong
              	defaults: {
              		updateInterval: 30 * 60 * 1000 //reads the file every 30 mins
              	start: function(){
              		this.sendSocketNotification("START", this.config);
              		if(notification === "DATA"){
              			this.updateDom();
              	getDom: function(){
              		if(this.dataFile){
              		} else {
              			wrapper.innerHTML = "No data";
              		return wrapper;
              		if(notification === "START"){
              			this.readData();
                  			setInterval(() => {
                      			this.readData();
              		fs.readFile("Test-temp.txt", "utf8", (err, data) => {
              			if (err) throw err;
              			this.sendSocketNotification("DATA", data);
                @strawberry-3.141
                Mh… than i don´t know…
                i have copy your code but it doesen´t work…
                I need to change anything els?
                And thank you for your patience :)
                  @strawberry-3.141 1_1472575446381_sensor.js 0_1472575446381_node_helper.js 0_1472575579268_config.js
                  Here are my code files. Maybe this can help?
                    do you get any error in the console or in the electron console (cmd+shift+I)
                    did you place your Test-temp.txt in ~/MagicMirror or somewhere else?
                      @strawberry-3.141
                      Sorry i hade no time the last days.
                      I put the Test-temp.txt in ~/MagicMirror and for tests ind~/MagicMirror/modules/sensor.
                      But nothing happens.
                      I get only an error about the weatherforecast bu nothing els…
                        strawberry 3.141 Project Sponsor Module Developer @dominic
                        @dominic can you remove the weatherforecast from the config when its causing issues, so we can troubleshoot this module?
                        • 1 / 6
