.txt file include
59 Posts 6 Posters 34.6k Views 6 Watching
    dominic
    Hello, i have a .txt file,
    this file I want to embed to the mirror. So the
    Content is displayed on the mirror.
    In addition , the file should be up-dated after a time= x.
    can someone help me?
    S 1 Reply Last reply Aug 28, 2016, 12:18 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @dominic
      @dominic this should give you an idea how to solve your problem, I just wrote it down maybe you have to adjust something a little bit and it’s not a finished solution
      • nodehelper:
      const fs = require('fs');
          if(notification === 'START'){
              this.config = payload;
              this.readData();
              setInterval(() => {
                  this.readData();
              }, this.config.updateInterval);
      readData: function(){
          //to read a file to do the following
          fs.readFile('YOUR FILE PATH', (err, data) => {
              if (err) throw err;
              this.sendSocketNotification('DATA', data);
      • module:
      defaults: {
          updateInterval: 30*60*1000 //reads the file every 30 mins
      start: function(){
          this.sendSocketNotification('START', this.config);
          if(notification === 'DATA'){
              this.dataFile = payload;
              this.updateDom();
      getDom: function(){
          var wrapper = document.createElement('div');
          if(this.dataFile){
              wrapper.innerHTML = this.dataFile;
          } else {
              wrapper.innerHTML = 'No data';
          return wrapper;
      D 1 Reply Last reply Aug 28, 2016, 5:01 PM Reply Quote 1
        dominic @strawberry 3.141
        @strawberry-3.141 Hi thank you.
        Sorry for the questions, i´m new in .js.
        Where do I insert the nodehelper und the module and and what I need to modify?
        I have insert the nodehelper code in the file: MagicMirror/modules/node_modules/node_helper/index.js.
        And the module code in /MagicMirror/modules/sensor/sensor.js.
        on the mirror is displayed : Sensor module_2_sensor…
          there is a general design your module have to look like
          you have to create a directory in ~/MagicMirror/modules/YOUR_MODULE_NAME
          then create a file YOUR_MODULE_NAME.js
          Module.register("YOUR_MODULE_NAME",{
              //here comes the rest of the code for module I posted above
          then create a file node_helper.js
          const NodeHelper = require("node_helper");
          const fs= require("fs");
              //here comes the part of the nodehelper after the 3 dots as posted above
          D 1 Reply Last reply Aug 28, 2016, 5:25 PM Reply Quote 1
            @strawberry-3.141 Thanks for the fast answer :)
            I did it , just as you said it. on the mirror is displayed : NO DATA
            Here is the code from the nodehelper:
            Is the path specified correctly or I need to change something?
            • readData: function(){
              fs.readFile(‘/home/pi/MagicMirror/Test-temp.txt’, (err, data) => {
              if (err) throw err;
              this.sendSocketNotification(‘DATA’, data);
              i think this should do the job
              fs.readFile('Test-temp.txt', (err, data) => {
              D 1 Reply Last reply Aug 29, 2016, 5:12 PM Reply Quote 0
                @strawberry-3.141
                hi, now i get " [object ArryBuffer]"
                what did i worng?
                  sry wasn’t aware of that a buffer gets returned instead of a string if there is no encoding specified
                  fs.readFile('Test-temp.txt', 'utf8', (err, data) => {
                  D 1 Reply Last reply Aug 30, 2016, 1:27 PM Reply Quote 0
                    @strawberry-3.141 said in .txt file include:
                    fs.readFile(‘Test-temp.txt’, ‘utf8’, (err, data) => {
                    Hi, sorry.
                    It didn´t work :/
                    Here is the node_helper.js code
                            this.readData();
                            setInterval(() => {
                                this.readData();
                            if (err) throw err;
                    and here is the sensor.js code:
                    Module.register("sensor",{
                       defaults: {
                    start: function(){
                            this.updateDom();
                    getDom: function(){
                        if(this.dataFile){
                        } else {
                        return wrapper;
                    Waht did i wrong? :D
                    I hope you can help me.
                      this works for me you had everywhere weird quotes and the updateinterval was also wrong
                      	defaults: {
                      		updateInterval: 30 * 60 * 1000 //reads the file every 30 mins
                      	start: function(){
                      		this.sendSocketNotification("START", this.config);
                      		if(notification === "DATA"){
                      			this.updateDom();
                      	getDom: function(){
                      		if(this.dataFile){
                      		} else {
                      			wrapper.innerHTML = "No data";
                      		return wrapper;
                      		if(notification === "START"){
                      			this.readData();
                          			setInterval(() => {
                              			this.readData();
                      		fs.readFile("Test-temp.txt", "utf8", (err, data) => {
                      			if (err) throw err;
                      			this.sendSocketNotification("DATA", data);
                      D 2 Replies Last reply Aug 30, 2016, 4:37 PM Reply Quote 0
                      • 1 / 6
                      1 / 6
