    .txt file include
    59 Posts 6 Posters 46.4k Views 6 Watching
    • strawberry 3.141S
      i think this should do the job
      fs.readFile('Test-temp.txt', (err, data) => {
      D 1 Reply Last reply
        dominic @strawberry 3.141
        @strawberry-3.141
        hi, now i get " [object ArryBuffer]"
        what did i worng?
        • strawberry 3.141S
          sry wasn’t aware of that a buffer gets returned instead of a string if there is no encoding specified
          fs.readFile('Test-temp.txt', 'utf8', (err, data) => {
            @strawberry-3.141 said in .txt file include:
            fs.readFile(‘Test-temp.txt’, ‘utf8’, (err, data) => {
            Hi, sorry.
            It didn´t work :/
            Here is the node_helper.js code
            const NodeHelper = require("node_helper");
            const fs= require("fs");
                //here comes the part of the nodehelper after the 3 dots as posted above
                if(notification === 'START'){
                    this.config = payload;
                    this.readData();
                    setInterval(() => {
                        this.readData();
                    }, this.config.updateInterval);
            readData: function(){
                //to read a file to do the following
                    if (err) throw err;
                    this.sendSocketNotification('DATA', data);
            and here is the sensor.js code:
            Module.register("sensor",{
               defaults: {
                updateInterval: 30*60*1000 //reads the file every 30 mins
            start: function(){
                this.sendSocketNotification('START', this.config);
                if(notification === 'DATA'){
                    this.dataFile = payload;
                    this.updateDom();
            getDom: function(){
                var wrapper = document.createElement('div');
                if(this.dataFile){
                    wrapper.innerHTML = this.dataFile;
                } else {
                    wrapper.innerHTML = 'No data';
                return wrapper;
            Waht did i wrong? :D
            I hope you can help me.
            • strawberry 3.141S
              this works for me you had everywhere weird quotes and the updateinterval was also wrong
              	defaults: {
              		updateInterval: 30 * 60 * 1000 //reads the file every 30 mins
              	start: function(){
              		this.sendSocketNotification("START", this.config);
              		if(notification === "DATA"){
              			this.updateDom();
              	getDom: function(){
              		if(this.dataFile){
              		} else {
              			wrapper.innerHTML = "No data";
              		return wrapper;
              		if(notification === "START"){
              			this.readData();
                  			setInterval(() => {
                      			this.readData();
              		fs.readFile("Test-temp.txt", "utf8", (err, data) => {
              			if (err) throw err;
              			this.sendSocketNotification("DATA", data);
              D 2 Replies Last reply
                @strawberry-3.141
                Mh… than i don´t know…
                i have copy your code but it doesen´t work…
                I need to change anything els?
                And thank you for your patience :)
                  @strawberry-3.141 1_1472575446381_sensor.js 0_1472575446381_node_helper.js 0_1472575579268_config.js
                  Here are my code files. Maybe this can help?
                  • strawberry 3.141S
                    do you get any error in the console or in the electron console (cmd+shift+I)
                    did you place your Test-temp.txt in ~/MagicMirror or somewhere else?
                      @strawberry-3.141
                      Sorry i hade no time the last days.
                      I put the Test-temp.txt in ~/MagicMirror and for tests ind~/MagicMirror/modules/sensor.
                      But nothing happens.
                      I get only an error about the weatherforecast bu nothing els…
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @dominic
                        @dominic can you remove the weatherforecast from the config when its causing issues, so we can troubleshoot this module?
                        • Y
                          yawns Moderator
                          Hm, maybe you could try this.
                          Put the file in the modules folder and open it with “./Test-temp.txt“
                          Additionally i would suggest to go with lowercase during testing to exclude case sensitive mistakes.
                          strawberry 3.141S D 2 Replies Last reply
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @yawns
                            @yawns electron is running in ~/MagicMirror, so putting the file in the modules directory and do ./Test-temp.txt won’t work. The code is generally working I tested it on my rpi
                              @strawberry-3.141 Hi :) it works :)
                              i don´t know why, but it works. I have reseted the system and after taht ist works.
                              Thank you very mutch.
                              i want to display not all the text out of the .txt file.
                              Do you know what i must change in the node_helper.js?
                              • strawberry 3.141S
                                i think this depends on the content of the file
                                  @strawberry-3.141 in the file are values from a dht22 temp.sensor.
                                  but i only need the values for Humidity = xx and Temperature =xx.
                                  is there any why to get only this values ?
                                    dominic @yawns
                                    @yawns Danke für deinen Tipp. Aber es läuft nun.
                                    Habe aber nun ein anderes Problem ;)
                                    gibt es eine Möglichkeit, die asugabe der txt Datei zu beregenzen, so dass mir nur bestimmte Werte angezeigt werden.
                                    In der Datei stehen Werte von einem dht22 sensor und ich möchte nur diese werte ausgeben ohne die den anderen INhalt.
                                    • strawberry 3.141S
                                      are these all in seperate lines?
                                      if so then you could check in a for loop if there is the word humidity or temperature otherwise ignore the line
                                        @strawberry-3.141
                                        No. There is only one line.
                                        • strawberry 3.141S
                                          can you please upload your txt file i have no clue how it looks like, so we can help you out with that
                                            @strawberry-3.141
                                            Raspberry Pi wiringPi DHT22 reader www.lolware.net Data not good, skip Data not good, skip Data not good, skip Humidity = 47.10 % Temperature = 24.50 *C .
                                            This is the contetn of the .txt file. And its all in one line.
