    .txt file include
    59 Posts 6 Posters 36.2k Views 6 Watching
      SaschaSP
      @strawberry-3-141 great solution from you.
      I want to use your solution not for showing Temperatur/ Humidity rather for showing alerts from sensors.
      The content from my txt is for example:
      Meldung Stellmotor Antrieb blockiert
      Zone Nebenantrieb
      Zeit 6.Juni 2018 10:40
      +++ENDE DER DATEI+++
      I change the sensor.js:
      Module.register("Home-Status",{
      	defaults: {
      		updateInterval: 0.5 * 60 * 1000 //reads the file every 30 seconds
      	start: function(){
      		this.sendSocketNotification("START", this.config);
      		if(notification === "DATA"){
      			this.dataFile = payload;
      			this.updateDom();
      	getDom: function(){
      		if(this.dataFile){
                              var meldungRegExp = /Meldung = (.*?) /ig;
                              var meldung = meldungRegExp.exec(this.dataFile)[1];
                              var zoneRegExp = /Zone = (.*?) /ig;
                              var zone = zoneRegExp.exec(this.dataFile)[1];
      			var zeitRegExp = /Zeit = (.*?) /ig;
      			var zeit = zeitRegExp.exec(this.dataFile)[1];
      			wrapper.innerHTML = "Meldung: " + meldung + " , Zone: " + zone + " , "Zeit: " + zeit" ;
      		} else {
      			wrapper.innerHTML = "No Data";
      		return wrapper;
      but it dosn´t work.
      Firtst problem: my txt have no seperators like = or :
      second probleme: my alert text (Meldung) contains of several words
      third Problem: only the newest txt should be displayed. The Names from the txt files are for example 20180112090125.txt or 20185912085949.txt etc. It´s not possible to edit the incoming txt names. Best way is to automaticly delete the previous txt
      I hope you can help me to Display " Meldung, Zone, Zeit" on my MagicMirror
      Best regards
      Sascha
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @SaschaSP
        @saschasp you can change your regular expressions to the following:
        /Meldung (.*)/ig;, /Zone (.*)/ig; and /Zeit (.*)/ig;. This should help you displaying the data. For the problem with the newest file you need to do the following steps: Scan the directory, sort file list by highest number, read the first file.
        Scan the directory https://nodejs.org/api/fs.html#fs_fs_readdir_path_options_callback
        Sort the file names https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort
        Read the file https://nodejs.org/api/fs.html#fs_fs_readfile_path_options_callback
          SaschaSP @strawberry 3.141
          @strawberry-3-141
          Ok, i will try step by step.
          Beginning with my first probleme:
          The Output message (displayed on the mirror) is only displaying one word after the “identifyer-word”
          identifyer "Meldung"
          MagicMirror Display only Stellmotor
          Antrieb blockiert is missing
          The identifyer-wordsare Meldung Zone Zeit
          The content from my txt:
          Zone Nebenantrieb
          My edited sensor.js:
          	defaults: {
          	start: function(){
          			this.updateDom();
          	getDom: function(){
          		if(this.dataFile){
                                  var meldungRegExp = /Meldung (.*?) /ig;
                                  var zoneRegExp = /Zone (.*?) /ig;
          			var zeitRegExp = /Zeit (.*?) /ig;
          			wrapper.innerHTML = "Meldung: " + meldung + " Zone: " + zone + " Zeit: " + zeit;
          		} else {
          		return wrapper;
          Result wich is displayed at MagicMirror:
          Meldung:Stellmotor Zone:Nebenantrieb Zeit:6.Juni
            @saschasp your regular expressens are different from the one i posted, use them and I’m sure it will work
              banbutcher
              hi,
              sorry to be dragging up old posts, but im trying to get my mirror to display the contents of a txt file and i have it partly working… i have the contents displaying on my mirror but its all showing up on one line, how can i display it with each line break as in txt file?
              thanks
                sdetweil @banbutcher
                @banbutcher you will have to replace the line feeds (\n) with html breaks (
                  banbutcher
                  hi again,
                  im after getting my script to update my txt file with the names of downloaded movies and tv series… how would i go about reading the title of the series and just having the title and info ie:
                  if title has S**E** in it then
                  filename - Archer S01E01pilot 1080p x265.mkv
                  desired result - Archer S01E01
                  else its a movie and just add movie name
                  i think this is the bit of code im to edit but i havent got it working :(
                  	getDom: function(){
                  		if(this.dataFile){
                  		} else {
                  		return wrapper;
                  thanks
                  Richie
                    @banbutcher said in .txt file include:
                    using the regex tester,
                    https://regex101.com/
                    I think this is the regex u want
                    /.*[S][(0-9)]+[E][(0-9)]+/
                      banbutcher
                      that worked great…
                      however, im a little bit stuck again… your expression works fine and return the correct result but only on the first line of the file and only if i remove the [1] from the end of line 5 of the code
                      	getDom: function(){
                      		if(this.dataFile){
                                              var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/ig;
                                              var split = splitRegExp.exec(this.dataFile)[1];
                      			wrapper.innerHTML = split;
                      		} else {
                      		return wrapper;
                      do i need to stick it in some kind of loop? or am i reading the contents of file wrong?
                      again thanks for your help :)
                        @banbutcher is dataFile an array of filenames? then yes, you’ll need a loop.
                        so, you are moving part of name a, to a new array
                        then part of name b to the next slot in the array
                        array.push(item)
                        adds item to the end of the array
                        name_of_array =[] initializes name_of_array to be an empty array
                        then u will need to format the array of partial names
                        var x = name_of_array.join(separator)
                        will turn the array into x, a string with separator between the names
                        • 6
                        • 4 / 6
