    .txt file include
    59 Posts 6 Posters 45.5k Views 6 Watching
    • B
      banbutcher
      Band.Of.Brothers.E01.1080p.5.1Ch.BluRay.ReEnc-DeeJayAhmed.srt <br>
      Archer S01E03 Diversity Hire (1080p x265 10bit S94 Joy).mkv <br>
      devs.s01e02.720p.hdtv.x264-river[eztv].mkv <br>
      What.We.Do.in.the.Shadows.S02E02.Ghosts.720p.AMZN.WEBRip.DDP5.1.x264-NTb[eztv.io].mkv <br>
      What.We.Do.in.the.Shadows.S02E01.Resurrection.720p.AMZN.WEBRip.DDP5.1.x264-NTb[eztv.io].mkv <br>
      this is the file im reading from… im not sure if thats an array, sorry and i want them outputted same line by line just missing the trailing parts.
      again thanks for your help :)
        sdetweil @banbutcher
        @banbutcher reading how
        • B
          banbutcher
          this is my main module .js
          i think this is where im reading from :/
          Module.register("deluge",{
          	defaults: {
          		updateInterval: 10 * 60 * 1000 //reads the file every 10 mins
          	start: function(){
          		this.sendSocketNotification("START", this.config);
          		if(notification === "DATA"){
          			this.dataFile = payload;
          			this.updateDom();
          //	getDom: function(){
          //		var wrapper = document.createElement("div");
          //		if(this.dataFile){
          //			wrapper.innerHTML = this.dataFile;
          //		} else {
          //			wrapper.innerHTML = "No data";
          //		return wrapper;
          	getDom: function(){
          		if(this.dataFile){
                                  var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/ig;
                                  var split = splitRegExp.exec(this.dataFile);
          			wrapper.innerHTML = split;
          		} else {
          			wrapper.innerHTML = "No Data";
          		return wrapper;
          im in way overmy head here!
            @banbutcher reading in the node_helper, sending up to the module.
            • B
              banbutcher
              Node_helper :)
              const NodeHelper = require("node_helper");
              const fs= require("fs");
              //here comes the part of the nodehelper after the 3 dots as posted above
              		if(notification === "START"){
              			this.config = payload;
              			this.readData();
                  			setInterval(() => {
                      			this.readData();
                  			}, this.config.updateInterval);
              	readData: function(){
              		//to read a file to do the following
              		fs.readFile("new-tv-list.txt", "utf8", (err, data) => {
              			if (err) throw err;
              			this.sendSocketNotification("DATA", data);
                @banbutcher I won’t have time to look at this tonight
                • B
                  banbutcher @sdetweil
                  not a problem at all, i really appreciate your help so far in this topic and every other question ive had across the board! :thumbs_up_light_skin_tone:
                    @banbutcher ok, the fs.readFile() returns ALL the content of the file. I still would remove the utf8.
                    but you want a list of names, not a stream of characters…
                    so you need to split the stream into an array.
                    a list of text ‘lines’ has a character after each, called a line feed, we don’t want those
                    but the last filename MAY or MAY NOT be followed by a line feed. (depends on how the file was created)
                    anyhow we can fix that
                    I would change the readData function in node_helper like this
                    		fs.readFile("new-tv-list.txt", (err, data) => {
                                            var output_data = null
                                            // if there was no error
                    			if (!err){
                                              // convert byte stream to array of names
                                              output_data=data.toString().concat("\n").split('\n')
                                            // always send something back to module, so it can display messages
                                            // might be null if there was an error
                    			this.sendSocketNotification("DATA", output_data);
                    then to fix the module side
                    build an html table structure
                    		if(this.dataFile){
                                            var output_list= [];
                                            // setup regex, no i  no g (only once, and case sensitive)
                                            var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/;
                                            // loop thru the list of filenames
                                            for(filename of this.dataFile) {
                                                // if the name is not zero length (split could have returned for just linefeed
                                                if(filename.length >0) {
                                                   // get the filename prefix
                                                   var split = splitRegExp.exec(filename);
                                                   // save name to the output list, as a table entry
                                                   // remove space after the ->< , the forum hides everything after unless a space
                                                   // table has a row,
                                                   output_list.push("< tr>< td>")
                                                   // with data
                                                   output_list.push(split)
                                                   // end of data and row
                                                   output_list.push("< /td>< /tr>")
                                            // insert the table into the wrapper
                    			wrapper.innerHTML = "< table>" + output_list.join('')+ "< /table>";
                    		} else {
                      @banbutcher
                      you can also you divs instead of a table, and then set a css style
                      ‘display’:‘inline-flex’
                      ‘flex-direction’:‘vertical’
                      and u can also use code to create the tree instead of text (don’t use the output_list anymore)
                      (and u can use this with divs too, don’t need as many elements)
                      var table=document.createElement("table")
                      wrapper.appendChild(table)
                                            var tr=document.createElement("tr")
                                            table.appendChild(tr)
                                            var td=document.createElement("td")
                                            tr.appendChild(td)
                                            td.innerText=split
                      return wrapper;
                      • B
                        banbutcher
                        Awesome i will try and get it working tonight!
                        Thanks,
                        Richie
                        • B
                          banbutcher
                          wow… works like a charm! lists all tv shows perfectly! :)
                          is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
                          and possibly limit output to 10 lines?
                          Thanks,
                          Richie
                            @banbutcher >is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
                            sure
                            // should make this a config variable by adding to module defaults
                            // then would be this.config.counter
                            // get display limit, 10 if not specified in defaults
                            var counter=this.config.counter || 10
                                           // and the view limit has not been reached
                                           if(filename.length >0 && counter>0) {
                                                  tr.appendChild(td)
                                                  if(split)
                                                      td.innerText=split
                                                  else
                                                      td.innerText='name not matched '+ filename
                                                  counter--;
                            return wrapper;
                            or using the text form
                            		if(this.dataFile){
                                                        if(filename.length >0 && counter >0) {
                                                           // table has a row,
                                                           // with data
                                                           if(split)
                                                           else
                                                               output_list.push('name not matched '+ filename)
                                                           counter--;
                            		} else {
                            • B
                              banbutcher
                              the counter part worked great, but then when i tried to add it if loop for the name check, im getting “no data” maybe i messed up copying across?
                              			var counter=this.config.counter || 11
                                                             // table has a row,
                                                             output_list.push("<tr><td>")
                              			       // with data
                              			       if(split )
                              			       else
                              			          output_list.push('name not found:'+ filename)
                                                             output_list.push("</td></tr>")
                              			       counter--;
                              			wrapper.innerHTML = "<table>" + output_list.join('')+ "</table>";
                              		 } else {
                                @banbutcher said in .txt file include:
                                sorry, don’t understand the words…
                                this is the test if the regex worked
                                                               if(split)
                                			       else
                                • B
                                  banbutcher
                                  this code works…
                                  		if(this.dataFile){
        // table has a row,
        // with data
                                  			       counter--;
                                  		 } else {
                                  this code doesnt…
        // table has a row,
                                  			       // with data
                                  			       if(split.length >0 )
                                  			       else
                                  			       counter--;
                                  		 } else {
                                  Richie :)
                                    @banbutcher
                                    my fault… I ‘assumed’ that regex would return an empty string… it returns a null value…
                                    I fixed my sample, and your paste with the correct test
                                    if(split)
                                    instead of
                                    if(split.length>0)
                                      sdetweil
                                      and for others trying to implement code, you can debug using the developers console, OR make little sample files and run them directly in node
                                      i named this testit.js in the user home folder (~/testit.js)
                                      var dataFile=["Archer S01E02Someshow.tv",
                                      "Archer S01E03Someshow .tv",
                                      "Archer S01e02Someshow .tv",
                                      "Archer S01E04Someshow .tv",
                                      "Archer S01E05someshow .tv",
                                      "Archer s01E02Someshow .tv",
                                      "Archer S01E09Someshow .tv",
                                      var counter1=10
                                                          if(dataFile){
                                                             var counter=counter1 || 10
                                                              for(filename of dataFile) {
        // table has a row,
        // with data
        if(split)
        else
        counter--;
                                                  console.log( "<table>" + output_list.join('')+ "</table>");
                                      and then
                                      cd ~
                                      node testit.js
                                      • B
                                        banbutcher
                                        Perfect!!
                                        now i can go to bed! :D tomorrows task will be styling with css! any pointers?
                                        as always… thanks again!!
                                        Richie
                                          sorry, that is my weakness… I cannot make anything look good… I can tell you if it DOES look good, but cannot do it myself… I have no eye for that all…
                                          • 3 / 3
