    Pi camera use for turning on mirror
    cameramotion-sensorpythonmodules
    6 Posts 2 Posters 2.1k Views 3 Watching
      reallykeene
      I have read multiple forums about motion detector and facial recognition for turning on the magic mirror. Is there one that is plug and play, or has a good walkthrough? I’m having difficulties with python and the motion software.
        sdetweil @reallykeene
        @reallykeene i use a logitech webcam for my camera… and I use the motion project for interfacing to the camera
        https://motion-project.github.io/
        sudo apt-get install motion
        i didn’t want to try to interface a module to lots of different camera… motion handles that.
        I didn’t want to deal with coding for all the different options I might needs (sensitivity, lightswitch flash. …
        you name it… motion handles it…
        i don’t know how it interfaces with face reco, but it can capture images, and forward those on for matching
          sdetweil
          i wrote my own module as I use TV and it can’t turn off, and I wanted webcam…
          https://github.com/sdetweil/MMM-SleepWake
          uses the motion module discussed above…
            reallykeene @sdetweil
            @sdetweil ok I now have motion working. Tested with vlc. But I’m unable to get your module to work. What screen shots might you need to help?
            I changed the time to 1min but the screen will not hide.
              @reallykeene did u set the motion config to trigger my script?
                @reallykeene also, if u look in /var/log/motion.log to see motion events
