    Default calendar - parsing of VEVENT
    3 Posts 2 Posters 904 Views 2 Watching
    • evroomE
      evroom
      HI,
      Can someone tell me how this Google event is parsed to the ‘data’ structure in calendarfetcher.js ?
      basic.ics part. (correct):
      BEGIN:VEVENT
      DTSTART;VALUE=DATE:20200330
      DTEND;VALUE=DATE:20200331
      DTSTAMP:20200329T132348Z
      UID:xxxl8quduqtvqbfe00fsk8xxx@google.com
      CREATED:20200329T132240Z
      DESCRIPTION:
      LAST-MODIFIED:20200329T132240Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:TEST_ENTRY_FULLDAY
      TRANSP:TRANSPARENT
      END:VEVENT
      calendarfetcher.js part (incorrect):
      0|mm  | { type: 'VEVENT',
      0|mm  |   params: [],
      0|mm  |   start: { 2020-03-29T22:00:00.000Z tz: undefined, dateOnly: true },
      0|mm  |   end: { 2020-03-30T22:00:00.000Z tz: undefined, dateOnly: true },
      0|mm  |   dtstamp: { 2020-03-29T13:23:15.000Z tz: undefined },
      0|mm  |   uid: 'xxxul8quduqtvqbfe00fsk8xxx@google.com',
      0|mm  |   created: { 2020-03-29T13:22:40.000Z tz: undefined },
      0|mm  |   description: '',
      0|mm  |   lastmodified: { 2020-03-29T13:22:40.000Z tz: undefined },
      0|mm  |   location: '',
      0|mm  |   sequence: '0',
      0|mm  |   status: 'CONFIRMED',
      0|mm  |   summary: 'TEST_ENTRY_FULLDAY',
      0|mm  |   transparency: 'TRANSPARENT' }
      The background of this question, is that a full day event for tomorrow, is shown on the MM as Today.
      Based on the start and end date from the calendar module, this may seem right, but does not match my correct Google calendar DTSTART and DTEND dates.
      This annoys me already for some time (also happens for reoccurring full day events) and I wanted to see where it might go wrong.
      Unfortunately I am not skilled enough to see where the actual parsing part takes place.
      It seems to me ‘locale’ or timezone issue and converting to unixtime.
      And it also annoys me that it shows as Today or in XX Days, when I would like to see it as Mon Mar 30th, like my normal events.
      Greetings,
      E.J.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom the calendar parser is downlevel and causes all kinds of problems…
        it uses the ical library, which we deliver as part of the MM install… (NOT download latest)…
        see issue https://github.com/MichMich/MagicMirror/issues/1926
        the parser is in calendarfetcher.js
        uses the preloaded modules/default/calendar/vendor/ical.js
        if u replace the ical.js with the latest, it works much better (most of the time)
        • evroomE
          evroom
          @sdetweil said in Default calendar - parsing of VEVENT:
          Ah, that was the missing link !
          Now I understand where it comes from (I mean the ‘data’ stuff that calendarfetcher.js uses).
          Will try with latest ical.js.
          Thanks.
