    MMM-RTSPSTream and pm2 start
    3 Posts 1 Posters 970 Views 1 Watching
      ShadowMG Project Sponsor
      Hi everyone,
      got my two IPcams to work with MM finaly - network speed had been the most critical issue for the last two month :-)
      Now Cams are on cable and MM changed to Raspi4b - seems to work better now.
      My issue is that starting MM directly mit “./mm.sh” or “npm start” shows the streams - starting with pm2 does show black video-streams…
      Before I go into to much detail - is this a known issue maybe? I remember to have been a this stage wirh my Raspi3 at some point - but then decided to resetup everithing anyway - so did not chekc on that issue back then.
      So system is Rasp4b, Buster, installation done 4 days ago.
      One thing that might be special is that I needed to change MM port from 8080 to a different one - but again, works fine when startin manually in bash.
      Thank you ang good night for now.
      ShadowMG
        ShadowMG Project Sponsor @ShadowMG
        Solved.
        Used to try with VLC, changed that to OMX, working like charm now.
        THX, Shadow
          This post is deleted!
