    sqlite - anyone use it?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    14 Posts 3 Posters 5.9k Views 3 Watching
    • B
      bobt
      Pretty new to all of this. I was hoping to use sqlite instead of mysql but…
      MM can’t find node_sqlite3.node looking in electron-v6.0-linux-arm. In serveronly mode it works fine. Any hints??
        sdetweil @bobt
        @bobt it should only run on the node_helper.js side, not in the browser side…
        • B
          bobt
          Wow - thanks for the quick reply. The db work is in the helper - the require, connect, select. It gets kicked off with socketNotificationReceived. Sends data back with self.sendSocketNotification(“DATA”,self.data);
          • B
            bobt
            If I just send back data without using the sqlite3 it works too.
              sdetweil @bobt
              @bobt so, it works ok?
              • B
                bobt @sdetweil
                @sdetweil It works with fine serveronly. Gets data from the db and passes it to the script. But without the serveronly it chokes when it sees the var sqlite3 = require(“sqlite3”);
                error-
                [2020-04-01 20:36:15.609] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/node_modules/sqlite3/lib/binding/electron-v6.0-linux-arm/node_sqlite3.node’
                The module exists in /home/pi/MagicMirror/node_modules/sqlite3/lib/binding but not in the electron folder.
                No idea. I can’t just copy it in - version numbers don’t match.
                  sdetweil @bobt
                  @bobt for your module, you added that as a dependency in package.json, then do an npm install in your module folder.
                  it should be in
                  ‘/home/pi/MagicMirror/modules/modulename/node_modules/sqlite
                  • B
                    bobt @sdetweil
                    @sdetweil Thank you Sam for all your help. I created that folder and just copied the module in. I get:
                    [2020-04-02 07:42:08.104] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/node_modules/sqlite3/lib/binding/electron-v6.0-linux-arm/node_sqlite3.node’
                    I’m ready to just start over. If I started with a fresh install of MM and wanted to install sqlite how would I go about it? Should I be in the module folder? the MM folder?
                    Thanks again for your help.
                      sdetweil @bobt
                      @bobt as its used by the module, it should be in the module folder
                      just copy is always bad
                      npm install sqlite --save
                      –save will put it into the package.json in this folder
                      you should have one(package.json), then u can keep track of your dependencies…
                      npm init will create one
                      • B
                        bobt
                        Thanks - and one (hopefully last) question. If I wanted sqlite to be available for a number of modules where would I put it?
                          sdetweil @bobt
                          @bobt i don’t know
                          u might be able to put in in the base, and then change your require to include the path to the ~/MagicMirror/node_modules/sqlite version
                          • PerlchampP
                            Perlchamp
                            @bobt
                            did u find a solution for your problem ?
                            S B 2 Replies Last reply Reply Quote 0
                              sdetweil @Perlchamp
                              @Perlchamp you should create a package.json for the module
                              by doing npm init in the module folder, and answering the setup questins.
                              the questions only add text to the package.json, nothing else
                              and then
                              then install your dependencies
                              npm install --save sqlite3
                              –save means add this to the package.json dependencies section
                              when u are done, you can send the package.json to another person,
                              and they can run npm install in the module folder and get the same
                              supporting code installed for this module
                              and if you asked for a SPECIFIC version of some library,
                              that would be recorded in the package.json too, so the other user would get
                              the same level of the dependency
                              • B
                                bobt @Perlchamp
                                @Perlchamp
                                Thanks everyone for your help. What I was doing was using MMM-MarineWeather By Grena https://github.com/grenagit
                                as a template to create a MarineTides version. In my simplicity I was loading the tide predictions from NOAA into a table and trying to use sqlite. The problems caused me to do a better job. Now I link to the NOAA website for the info. This allows the module to get the tide info from any (US) location. Works well. I’ll clean it up and try to add it to Git. May need help with that.
                                Thanks again.
