    MM crashes after latest update
    19 Posts 2 Posters 4.2k Views 2 Watching
      joberbroeckling
      https://github.com/Snille/MMM-homeassistant-sensors
        sdetweil @joberbroeckling
        @joberbroeckling ok. That one only has fonts as a dependency
          joberbroeckling
          I think it may be the DarkSky module. Since I have reached my API request limit it has stopped crashing.
            joberbroeckling
            I think I spoke too soon. I removed the DarkSky, Remote Control and Home Assistant Sensors modules and it still crashes on start up. The system load is high but after a while it decreases. I think I will try to a fresh install and see what happens.
              joberbroeckling
              I did a fresh install and installed the modules one at a time. I commented out the modules I already added in my config file. I did notice there is a thread going on regarding MMM-Remote-Control module not working with latest update. So I removed it because I don’t use it that much anyways.
              Then I un-commented all the modules in my config file and it crashed again. I think it has to do with Electron. But I am not a professional and I am only doing this for fun. The CPU load is huge when it starts up. I don’t think this will work on RPI 3 anymore.
              I reverted back to 2.10.1 and everything seems to work fine.
                @joberbroeckling i have it running on pi 0, pi 3, pi 4, odroid, nano, ubuntu, and Mac catalina
                no issues…
                I don’t use remote-control or pir, or buttons
                there is a fix for the remote-control in that topic (u have to change the code)
                so, fresh install, no additions/changes, does it run ok?
                  joberbroeckling
                  If I do a fresh install and add the same modules (except remote-control) I had before it crashes. So I am not sure how to test which module is causing the issue.
                    @joberbroeckling disabled all the modules u added,
                    add
                    disabled:true.
                    to each module section
                    module:?????,
                    disabled:true,
                    pm2 stop 0
                    one at a time, change true to false, restart mirror
                    npm start dev
                    if it works, ctrl-c to kill mirror, edit config, enable next
                    and repeat
                    if it fails, see the terminal window and developers window, console tab for errors
                    ctrl c on terminal window to exit
                      joberbroeckling
                      I think I figured out what the issue is. It has to do with the MMM-WatchDog and the interval was too low. It was previously set to 10s. I upped it to 30s and it hasn’t restarted since.
