    Black screen after update 2.11 (electron)
    24 Posts 2 Posters 7.2k Views 2 Watching
      Blackmirror
      Hello I get a black screen after the update.
      The problem is the modul MMM-Buttons.
      It’s need electron but a rebuild will not work it get’s the follow errors
      pi@Mirror:~/MagicMirror/modules/MMM-Buttons $ ./node_modules/.bin/electron-rebuild
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      gyp info it worked if it ends with ok
      gyp info using node-gyp@6.1.0
      gyp info using node@6.10.2 | linux | arm
      gyp info find Python using Python version 2.7.9 found at "/usr/bin/python"
      gyp info spawn /usr/bin/python
      gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp/gyp/gyp_main.py',
      gyp info spawn args   'binding.gyp',
      gyp info spawn args   '-f',
      gyp info spawn args   'make',
      gyp info spawn args   '-I',
      gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
      gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp/addon.gypi',
      gyp info spawn args   '/home/pi/.electron-gyp/6.1.9/include/node/common.gypi',
      gyp info spawn args   '-Dlibrary=shared_library',
      gyp info spawn args   '-Dvisibility=default',
      gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/6.1.9',
      gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp',
      gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/6.1.9/<(target_arch)/node.lib',
      gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
      gyp info spawn args   '-Dnode_engine=v8',
      gyp info spawn args   '--depth=.',
      gyp info spawn args   '--no-parallel',
      gyp info spawn args   '--generator-output',
      gyp info spawn args   'build',
      gyp info spawn args   '-Goutput_dir=.' ]
      make: Entering directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
      gyp info spawn make
      gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        CXX(target) Release/obj.target/epoll/src/epoll.o
      In file included from /home/pi/.electron-gyp/6.1.9/include/node/v8-internal.h:14:0,
                       from /home/pi/.electron-gyp/6.1.9/include/node/v8.h:25,
                       from ../src/epoll.cc:11:
      /home/pi/.electron-gyp/6.1.9/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
         declarator __attribute__((deprecated(message)))
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
         V8_DEPRECATE_SOON("Use *WithData version.",
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
      In file included from ../../nan/nan_converters.h:67:0,
                       from ../../nan/nan.h:202,
                       from ../src/epoll.cc:15:
      ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
      ../../nan/nan_converters_43_inl.h:18:69: error: no matching function for call to ‘v8::Value::ToBoolean(v8::Local<v8::Context>)’
             val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext())          \
      ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
       X(Boolean)
      ../../nan/nan_converters_43_inl.h:18:69: note: candidates are:
       X(Boolean)
      In file included from ../src/epoll.cc:11:0:
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2516:18: note: v8::Local<v8::Boolean> v8::Value::ToBoolean(v8::Isolate*) const
         Local<Boolean> ToBoolean(Isolate* isolate) const;
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2516:18: note:   no known conversion for argument 1 from ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:10428:16: note: v8::Local<v8::Boolean> v8::Value::ToBoolean() const
       Local<Boolean> Value::ToBoolean() const {
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:10428:16: note:   candidate expects 0 arguments, 1 provided
      ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
      ../../nan/nan_converters_43_inl.h:37:57: error: no matching function for call to ‘v8::Value::BooleanValue(v8::Local<v8::Context>)’
         return val->NAME ## Value(isolate->GetCurrentContext());                     \
      ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
       X(bool, Boolean)
      ../../nan/nan_converters_43_inl.h:37:57: note: candidates are:
       X(bool, Boolean)
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2532:8: note: bool v8::Value::BooleanValue(v8::Isolate*) const
         bool BooleanValue(Isolate* isolate) const;
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2532:8: note:   no known conversion for argument 1 from ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2541:43: note: bool v8::Value::BooleanValue() const
         V8_DEPRECATED("Use maybe version", bool BooleanValue() const);
      /home/pi/.electron-gyp/6.1.9/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2541:43: note:   candidate expects 0 arguments, 1 provided
      In file included from ../../nan/nan_new.h:189:0,
                       from ../../nan/nan.h:203,
      ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
      ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                                 , obj));
      ../../nan/nan_implementation_12_inl.h:105:32: note: candidate is:
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:4094:31: note: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
         static MaybeLocal<Function> New(
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:4094:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
      ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
      ../../nan/nan_implementation_12_inl.h:337:37: warning: ‘static v8::Local<v8::Value> v8::StringObject::New(v8::Local<v8::String>)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:5323): Use Isolate* version [-Wdeprecated-declarations]
         return v8::StringObject::New(value).As<v8::StringObject>();
      In file included from ../src/epoll.cc:15:0:
      ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
      ../../nan/nan.h:840:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/node.h:174): Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, func, argc, argv);
      ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
      ../../nan/nan.h:855:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/node.h:167): Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, symbol, argc, argv);
      ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
      ../../nan/nan.h:870:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/node.h:160): Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, method, argc, argv);
      ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
      ../../nan/nan.h:916:53: warning: ‘v8::Local<v8::String> v8::Value::ToString() const’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:10433): Use maybe version [-Wdeprecated-declarations]
             v8::Local<v8::String> string = from->ToString();
      ../../nan/nan.h:926:74: warning: ‘int v8::String::WriteUtf8(char*, int, int*, int) const’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2726): Use Isolate* version [-Wdeprecated-declarations]
               length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
      ../../nan/nan.h:1484:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/node.h:174): Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
      ../../nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:3330): Use maybe version [-Wdeprecated-declarations]
           New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
      ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
      ../../nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:3330): Use maybe version [-Wdeprecated-declarations]
           New(persistentHandle)->Set(key, value);
      ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
      ../../nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:3339): Use maybe version [-Wdeprecated-declarations]
           New(persistentHandle)->Set(index, value);
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
      ../../nan/nan.h:1556:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:3384): Use maybe version [-Wdeprecated-declarations]
               New(persistentHandle)->Get(New(key).ToLocalChecked()));
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
      ../../nan/nan.h:1562:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:3384): Use maybe version [-Wdeprecated-declarations]
           return scope.Escape(New(persistentHandle)->Get(key));
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
      ../../nan/nan.h:1567:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:3388): Use maybe version [-Wdeprecated-declarations]
           return scope.Escape(New(persistentHandle)->Get(index));
      In file included from /usr/include/c++/4.9/cassert:43:0,
                       from /home/pi/.electron-gyp/6.1.9/include/node/node_object_wrap.h:26,
                       from ../src/epoll.cc:13:
      ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
      ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
           assert(persistent().IsNearDeath());
      In file included from ../../nan/nan.h:2365:0,
      ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
      ../../nan/nan_object_wrap.h:67:18: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘MarkIndependent’
           persistent().MarkIndependent();
      ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
      ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
           assert(wrap->handle_.IsNearDeath());
      ../src/epoll.cc: In static member function ‘static void Epoll::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
      ../src/epoll.cc:175:39: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
         constructor.Reset(ctor->GetFunction());
      ../src/epoll.cc:175:39: note: candidate is:
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:5891:46: note: v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)
         V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
      /home/pi/.electron-gyp/6.1.9/include/node/v8.h:5891:46: note:   candidate expects 1 argument, 0 provided
      ../src/epoll.cc:177:23: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
      ../src/epoll.cc:177:23: note: candidate is:
      ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Add(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/epoll.cc:210:44: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2545): Use maybe version [-Wdeprecated-declarations]
         int err = epoll->Add(info[0]->Int32Value(), info[1]->Int32Value());
      ../src/epoll.cc:210:67: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2545): Use maybe version [-Wdeprecated-declarations]
      ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Modify(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/epoll.cc:230:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2545): Use maybe version [-Wdeprecated-declarations]
         int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
      ../src/epoll.cc:230:70: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2545): Use maybe version [-Wdeprecated-declarations]
      ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/epoll.cc:247:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated (declared at /home/pi/.electron-gyp/6.1.9/include/node/v8.h:2545): Use maybe version [-Wdeprecated-declarations]
         int err = epoll->Remove(info[0]->Int32Value());
      epoll.target.mk:107: recipe for target 'Release/obj.target/epoll/src/epoll.o' failed
      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
      make: *** [Release/obj.target/epoll/src/epoll.o] Error 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at emitTwo (events.js:106:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      gyp ERR! System Linux 4.9.22-v7+
      gyp ERR! command "/usr/bin/nodejs" "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.9" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source"
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll
      gyp ERR! node -v v6.10.2
      gyp ERR! node-gyp -v v6.1.0
      gyp ERR! not ok
      Failed with exit code: 1
      I hope the first part of the error text is enough. The complete text is to long.
      Thanks for some help.
        sdetweil @Blackmirror
        @Blackmirror did u npm install in the folder first?
          Blackmirror
          yes i have
            @Blackmirror what node version are you one
            node -v
              Blackmirror
              it is v6.10.2
                @Blackmirror hm… you should be on v 10.??
                how did u upgrade? and from what version?
                  Blackmirror
                  I have only git pull yesterday in cd Magicmirror and in all modules npm install.
                  After this I get a black screen so I have rebuild electron in cd magicmirror and all modules. and npm install again.
                    @Blackmirror said in Black screen after update 2.11 (electron):
                    and npm install (in base and module folders) (as this will copy down new files based on the MM changes)
                    and THEN
                    electron-rebuild
                    AND you did npm install in MagicMirror folder, BEFORE all modules
                      Blackmirror
                      yes. first cd magicmirror after this the modules
                        @sdetweil maybe run my upgrade script …
                        from here
                        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                          Blackmirror
                          @sdetweil said in Black screen after update 2.11 (electron):
                          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
                          ok. Now I have no black screnn but the mirror say i must install a config.js, but my old config.js is in the folder.
                            @Blackmirror how did u start mm??? pm2 or npm start?
                            open the developers window, ctrl-shift-i on keyboard, select the console tab, and scroll up to find any errors (usually red text)…
                            this same error is displayed in a module crashes hard
                              Blackmirror @sdetweil
                              sorry i have not all // delete from the MMM-Buttons module. It the same blank mirror.
                              At I get the same errors in the MMM-Buttons module after npm install. Your script have not wrote that it is make npm install at the MMM-Buttons module
                                MMM-Buttons
                                it should, there is a package.json file present…
                                please show me upgrade.log
                                ~/MagicMirror/installers/upgrade.log
                                  Blackmirror
                                  Yes it have it.
                                  I can not open the log file.
                                  No authorization.
                                  S B 2 Replies Last reply Reply Quote 0
                                    @Blackmirror eh? was created in user name running the script
                                    please do
                                    ls -laF ~/MagicMirror/installers
                                    show results
                                      Blackmirror @Blackmirror
                                      Okay works if it run in single steps
                                      Upgrade started - Sa Apr  4 17:52:55 CEST 2020
                                      system is Linux Mirror 4.9.22-v7+ #987 SMP Fri Apr 14 23:23:05 BST 2017 armv7l GNU/L$
                                      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Rele$
                                      user requested to force apply changes
                                      doing test run = false
                                      saving custom.css
                                      remote name = origin
                                      upgrading from version 2.11.0 to 2.11.0
                                      fetching latest revisions
                                      git fetch rc=0
                                      current branch = master
                                      On branch master
                                      Your branch is up-to-date with 'origin/master'.
                                      Changes not staged for commit:
                                        (use "git add <file>..." to update what will be committed)
                                        (use "git checkout -- <file>..." to discard changes in working directory)
                                              modified:   package.json
                                      Untracked files:
                                        (use "git add <file>..." to include in what will be committed)
                                              core
                                              css/save_custom.css
                                              modules/default/compliments/compliments.json
                                        @Blackmirror there should be more
                                          Untracked files:
                                                  core
                                                  css/save_custom.css
                                          no changes added to commit (use "git add" and/or "git commit -a")
                                          there are 1 local files that are different than the master repo
                                             package.json
                                          save/restore files selection = y
                                          Saved working directory and index state WIP on master: 447c0bf Merge pull request #1968 from MichMich/develop
                                          HEAD ist jetzt bei 447c0bf Merge pull request #1968 from MichMich/develop
                                          test merge result rc='' , if empty, no conflicts
                                          executing merge, apply specified
                                          merge result rc= 0
                                           Already up-to-date.
                                          processor architecture is armv7l
                                          updating MagicMirror runtime, please wait
                                          > magicmirror@2.11.0 install /home/pi/MagicMirror
                                          > echo "Installing vendor files ...
                                          " && cd vendor && npm install --loglevel=error
                                          > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                                          > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                          > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                                          > echo "Installing fonts ...
                                          " && cd fonts && npm install --loglevel=error
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none was installed.
                                          npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none was installed.
                                          npm install completed - Sa Apr  4 17:54:21 CEST 2020 on base
                                          downloading dumpactivemodules script
                                          processing dependency changes for active modules with package.json files
                                          processing for module MMM-Carousel please wait
                                          processing complete for module MMM-Carousel
                                          processing for module MMM-Podcast please wait
                                          > Magic-Mirror-Module-Podcast@1.0.1 postinstall /home/pi/MagicMirror/modules/MMM-Podcast
                                          > electron-rebuild -e ../../node_modules/electron
                                          - Searching dependency tree
                                          ✔ Rebuild Complete
                                          processing complete for module MMM-Podcast
                                          processing for module MMM-DWD-WarnWeather please wait
                                          processing complete for module MMM-DWD-WarnWeather
                                          processing for module MMM-Todoist please wait
                                          processing complete for module MMM-Todoist
                                          processing for module MMM-FRITZ-Box-Callmonitor please wait
                                          processing complete for module MMM-FRITZ-Box-Callmonitor
                                          processing for module MMM-RadioDe please wait
                                          processing complete for module MMM-RadioDe
                                          processing for module MMM-Fuel please wait
                                          npm WARN eslint-config-airbnb-base@11.1.3 requires a peer of eslint@^3.19.0 but none was installed.
                                          npm WARN eslint-plugin-import@2.2.0 requires a peer of eslint@2.x - 3.x but none was installed.
                                          processing complete for module MMM-Fuel
                                          restoring custom.css
                                          removing git alias
                                          we stashed a set of files that appear changed from the latest repo versions. you should review them
                                          Upgrade ended - Sa Apr  4 17:55:24 CEST 2020
                                          Upgrade started - Sa Apr  4 17:57:51 CEST 2020
                                          system is Linux Mirror 4.9.22-v7+ #987 SMP Fri Apr 14 23:23:05 BST 2017 armv7l GNU/Linux
                                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Release: 8.0 Codename: jessie
                                          saving custom.css
                                          git fetch rc=0
                                          On branch master
                                          Untracked files:
                                                  core
                                                  css/save_custom.css
                                                  installers/stashed_files
                                          nothing added to commit but untracked files present (use "git add" to track)
                                          no files different from github version
                                          merge result rc= 0
                                           Already up-to-date.
                                          npm install completed - Sa Apr  4 17:58:55 CEST 2020 on base
                                          no modules found needing npm refresh
                                          removing git alias
                                          Upgrade ended - Sa Apr  4 17:58:55 CEST 2020
                                            @Blackmirror can u show me the config.js section for MMM-Button?
                                            my code (dumpActiveModules.js) lists out the modules that are enabled…
