    Can't clone from GitHub
    107 Posts 3 Posters 82.8k Views 3 Watching
      MMRPi1
      So whenever I try to clone a repo from GitHub (to update or to add a new module) I get an error saying it can’t access the repo.
      The exact error is:
      fatal: unable to access <repo_url> gnutls_handshake() failed
      I saw a few others with the same error but didn’t find a solution that worked.
      Any help would be greatly appreciated.
        sdetweil @MMRPi1
        @MMRPi1 can u show us the git clone command exactly as u used it…
          MMRPi1
          git pull from the MagicMirror folder.
            sdetweil @MMRPi1
            @MMRPi1 that’s different from clone
              MMRPi1
              pull to update, clone to install modules. I get the same error in any case.
                sdetweil @MMRPi1
                @MMRPi1 ok, there was another person that had a similar problem and there was an extra . On the end of the url
                  MMRPi1 @sdetweil
                  @sdetweil Oh alright. I think the issue here is somewhat security related but I could be wrong.
                  Not sure what to do about it though. Since I’ve been able to update MM and also add new modules in the past.
                    sdetweil @MMRPi1
                    @MMRPi1 some folks are experiencing this cause their antivirus live protection has downlevel tls (https) support
                    https://github.community/t5/How-to-use-Git-and-GitHub/Unable-to-Push-to-repo-gnutls-handshake-failed/td-p/6584/page/2
                      MMRPi1 @sdetweil
                      @sdetweil Hmm, tried disabling my Antivirus but I still got the same error.
                        MMRPi1 @sdetweil
                        @sdetweil Do you know what else might be the problem?
                          sdetweil @MMRPi1
                          @MMRPi1 no… not really…
                          so when u go to clone, you open the project github page, push the green clone or download button mid page right, then push the copy button next to the url, right?
                          then open the terminal window and type git clone
                          and then paste in the url just copied…
                          lets try to get one file, not using git
                          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/dumpactivemodules.js >dumpactivemodules.js
                          should produce a tiny js file
                            MMRPi1 @sdetweil
                            @sdetweil I think that worked
                              sdetweil
                              this link says it might be a library update
                              are you on windows or linux?
                              for linux
                              https://stackoverflow.com/questions/52379234/gnutls-handshake-failed-error-in-the-pull-function
                              circa 2019…
                              for windows, do you use a proxy to access the network?
                                MMRPi1 @sdetweil
                                @sdetweil I’m using SSH on Windows to access the pi (Linux obviously). I tried on the pi as well but I got the same error.
                                I tried the advice on stack overflow but got the same error.
                                  sdetweil @MMRPi1
                                  @MMRPi1 how do you connect to the internet?
                                    MMRPi1 @sdetweil
                                    @sdetweil Through my router. Not sure I understand the question
                                      sdetweil @MMRPi1
                                      @MMRPi1 ok, just checking… some people have another machine acting as a router…
                                        @sdetweil can u use git clone on windows?
                                        (have to install git 1st)
                                          MMRPi1 @sdetweil
                                          @sdetweil Yes it works fine.
                                            sdetweil @MMRPi1
                                            @MMRPi1 said in Can't clone from GitHub:
                                            hm… what OS is this? and when was the last system update?
                                            sudo apt-get update
                                            sudo apt-get upgrade
                                            • 6
                                            • 1 / 6
