    Installing modules on windows
    16 Posts 2 Posters 6.4k Views 2 Watching
    • V Offline
      vintage89
      I’m trying to install modules on windows - but I get the following error. I’ve installed python - but no change.
      Any suggestions? :)
      gyp ERR! find Python
      gyp ERR! find Python Python is not set from command line or npm configuration
      gyp ERR! find Python Python is not set from environment variable PYTHON
      gyp ERR! find Python checking if "python" can be used
      gyp ERR! find Python - "python" is not in PATH or produced an error
      gyp ERR! find Python checking if "python2" can be used
      gyp ERR! find Python - "python2" is not in PATH or produced an error
      gyp ERR! find Python checking if "python3" can be used
      gyp ERR! find Python - "python3" is not in PATH or produced an error
      gyp ERR! find Python checking if the py launcher can be used to find Python 2
      gyp ERR! find Python - "py.exe" is not in PATH or produced an error
      gyp ERR! find Python checking if Python is C:\Python27\python.exe
      gyp ERR! find Python - "C:\Python27\python.exe" could not be run
      gyp ERR! find Python checking if Python is C:\Python37\python.exe
      gyp ERR! find Python - "C:\Python37\python.exe" could not be run
      gyp ERR! find Python **********************************************************
      gyp ERR! find Python You need to install the latest version of Python.
      gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
      gyp ERR! find Python you can try one of the following options:
      gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
      gyp ERR! find Python   (accepted by both node-gyp and npm)
      gyp ERR! find Python - Set the environment variable PYTHON
      gyp ERR! find Python - Set the npm configuration variable python:
      gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"
      gyp ERR! find Python For more information consult the documentation at:
      gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
      gyp ERR! fi
        sdetweil @vintage89
        @vintage89 which git did u install? mine is a binary
          sdetweil @vintage89
          @vintage89 also, after installing python, did you close and re-open the command prompt? the path is set only when the window opens
          • V Offline
            vintage89 @sdetweil
            @sdetweil Tried installing this module https://github.com/Thlb/MMM-synology-ds
              sdetweil @vintage89
              @vintage89 said in Installing modules on windows:
              ok, that installed, fine, but has an embedded component that is electron version sensitive
              so
              cd ~/MagicMirror
              npm install electron-rebuild
              cd modules/MMM-synology-ds
              ../../node_modules/.bin/electron-rebuild
              cd ~/MagicMirror
              npm start
              • V Offline
                vintage89
                I´ve run the script, but when I tried to start it gave me this:
                > magicmirror@2.11.0 start /home/pi/MagicMirror
                > electron js/electron.js
                (electron:8589): Gtk-WARNING **: 14:59:29.032: cannot open display:
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.11.0 start: `electron js/electron.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.11.0 start script.
                npm ERR!     /home/pi/.npm/_logs/2020-04-11T12_59_29_059Z-debug.log
                I changed the package.json to this - like you said in my other post:
                  sdetweil @vintage89
                  @vintage89 do
                  export DISPLAY=:0
                  then
                  npm start
                  these two steps are what the original code did, would have worked on linux… just not on Windows…
                  windows doesn’t have ‘xwindows display’
                  V 2 Replies Last reply Reply Quote 0
                  • V Offline
                    vintage89 @sdetweil
                    Gave me this, did I do something wrong? :)
                    pi@raspberrypi:~ $ export DISPLAY=:0
                    pi@raspberrypi:~ $ cd MagicMirror/
                    (electron:813): Gtk-WARNING **: 15:08:03.027: cannot open display: :0
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /home/pi/.npm/_logs/2020-04-11T13_08_03_102Z-debug.log
                    • V Offline
                      vintage89 @sdetweil
                      @sdetweil ahh, sorry - forgot to mention that I got my rassberry today, so I’m on a raspberry now. My bad!!
                        sdetweil @vintage89
                        @vintage89 how are u connected to the pi? ssh, vnc, on the monitor?
                        and you are using the graphical desktop version of Raspian, right?? u must to display on the pi…
                        • V Offline
                          vintage89 @sdetweil
                          I’m connected via ssh and vnc. I managed to start it with the original config.json. It’s after I put in the synology-module that everything went out the window.
                            sdetweil @vintage89
                            @vintage89 eh… I cut/pasted the sample config for that module into config.js at the end of the module list and it came up just fine
                            • V Offline
                              vintage89 @sdetweil
                              I´ll try and start from scratch again :)
                              So If I understand you correctly - I don’t have to change the package.json when I’m on the raspberry? :)
                                sdetweil @vintage89
                                @vintage89 correct… (long as its a pi3 or 4)
                                  sdetweil @vintage89
                                  @vintage89 u don’t need to start from scratch… just copy the config/config.js.sample to config/config.js
                                  • V Offline
                                    vintage89
                                    @sdetweil Hehe, allready did - and now things are playing along well :D Thanks alot!
