    Cannot Access via HTTP even on MM Pi Device itself
    4 Posts 2 Posters 417 Views 2 Watching
      STS
      I just installed MM on a Pi 3B that also has PiHole on it. I can access the PiHole HTTP server without issue, but even when connected directly to the Pi console (or via RDP) I am unable to access the website. I am looking to troubleshoot before putting into production, but I’m unable to do so no matter which port I try… Currently the network config section is wide open:
      address: “0.0.0.0, ::”,
      port: 88,
      ipWhitelist: [],
      Any help would be most appreciated! Thank you
        sdetweil @STS
        @STS address:“0.0.0.0”
        Nothing else
          STS
          Thanks @sdetweil however that doesn’t work for me. Still getting a generic Connection_refused message in Chromium on the actual Pi and no connection from my workstation.
            sdetweil @STS
            @STS you are getting the server startup message, right
            Starting server on port 8080 …
            you could also do temporarliy,
            node serveronly
            instead of npm start
            and it will announce the address as well…
