    Default Weather module, remove sunset time?
    3 Posts 2 Posters 897 Views 1 Watching
      smartroad
      Is there anyway to remove the sunset time from the (Current) Weather module (the new one)? I’m using a Raspberry Pi lcd screen and it overlaps the forecast weather next to it. I can’t see anything in the docs to say it can be removed as I don’t need it anyway?
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @smartroad
        @smartroad add to your config.
        onlyTemp: true,
          smartroad @Stoffbeuteluwe
          @Stoffbeuteluwe said in Default Weather module, remove sunset time?:
          onlyTemp: true,
          Thanks for the reply, that works but removes all of the data, I only want the sunrise/set time removed, in the same way the humidity can be with “showIndoorHumidity”
