    MMM-SynologySurveillance
    34 Posts 5 Posters 17.6k Views 5 Watching
      m3iaz
      Hi. I love Your module.
      Do You know if there is a way to get better resolution than width of 320px?
      I mention width only since I have one 4/3 cam and 3 reolink duo which is 8/3.
      For all of it, best quality I can get is 320/xxx.
      By many experiments I have found that this is best I can get and enlarging it with method you posted will drop in quality.
      I think it can be somewhere in DSP configuration but can not find it at all…
      BTW. none of my cameras provide mjpeg stream but can provide jpeg snapshots. Maybe it is worth to implement this solution as well…
      • wishmaster270W Offline
        wishmaster270 Module Developer @m3iaz
        @m3iaz Hi,
        the Reolink cams provide a fluent and a high quality stream.
        You can select three different stream types in the Surveillance Station. The MJPEG stream is generated of the one for reduced speed which in my setup is the fluent stream of the Reolink cam.
        I can select a 640x stream in my Reolink but it may depend of the camera.
        I do not have much time to program at the moment but you may checkout my EmbedURL module. It is able to embed images and a refresh rate can be configured. Some people use it to embed JPEG of public webcams already.
        BKeyportB M 2 Replies Last reply Reply Quote 0
        • BKeyportB Offline
          BKeyport Module Developer @wishmaster270
          @wishmaster270 and through use of an old pi for MotionEyeOS, I use it to embed a near-direct stream from my Reolink cameras. :)
            m3iaz @wishmaster270
            @wishmaster270 Thank You for quick answer. I will try it
            • 4 / 4
