    MMM-homeassistant-sensors- attributes ?
    2 Posts 2 Posters 695 Views 1 Watching
    • E Offline
      emailuser
      Hi , advice appreciated for a newbie , i have MM running on Pi 3B , i also have home assistant running on a different PI, i have added the above module and am able to display a sensor entity for bedroom temp, but it only shows the entity state as heat, i would like to show the actual temp, i beleive i might need to add an attribute in the config.js , but i have tried many combinations but all fail, here is example below of config.js
      prettyName: false,
      stripName: false,
      debuglogging: false,
      displayvalue: true,
      values: [{
      sensor: “climate.josh_bed”,
      attributes: [
      {“current_temperature”
      below is the states in HA … am i able to add these to MM ?
      • E Offline
        edd189 @emailuser
        @emailuser It looks like the very last line of your code has { instead of }
        See if that resolves it?
