    MMM-Remote-Control API Questions
    17 Posts 3 Posters 5.4k Views 3 Watching
      sgarg15
      @Jopyth Hey so i was going through your MMM-Remote-Control API and i had some questions.
      So i am trying to make a python script that detects a swiping motion to then change pages, but since this is a seperatte python script (not in a module), the MMM-pages module cant accept the notifications given to it.
      So the creater of MMM-pages, told me if i had a look at your API i could possible achieve this. but after giving it a thorough read, i was having difficulty figuring it out.
      So essentially i wanted something like this
      def swiper():
        #code here to detect swipe
        if leftSwipe:
          #send a notification to pages to go left
        if rightSwipe:
          #send a notification to pages to go right
        sgarg15
        If you could help me achieve this, or give me some info that could help me do this i would really appreciate it
          sgarg15
          If anyone else who understands the API could help me out i would really appreaciate it as well @sdetweil
            sdetweil @sgarg15
            @sgarg15 so, you need a node_helper for the python script to send the notice to(as it can launch the python script and read the messages) and then the node helper can send the notification up to its modulename.js, which can then send the notification.
            lots of modules work this way, PIR
            MMM-Swipe does this exact thing, which is what I think u want to use
            fork it, change the name, and modify the node_helper to launch your python script and accept your python messages
              sgarg15 @sdetweil
              @sdetweil If possible could you please give me an example of how i would do it, i dont know much about js. and i looked at the MMM-Swipe but i couldnt understand much
                sdetweil @sgarg15
                @sgarg15 swipe isn’t a good example after all, uses a library which hides all that… nor PIR…
                your python script needs to run forever and put out messages for each movement it sees…
                then you use the nodejs Python_Shell library to launch it
                import {PythonShell} from 'python-shell';
                let pyshell = new PythonShell('my_script.py');  // < --- whatever your script name, in the module folder
                // the .on handler gets called each time the pythin script writes a message to stdout
                pyshell.on('message', function (message) {
                  // received a message sent from the Python script (a simple "print" statement)
                  console.log(message);
                  // send info up to modulename.js
                  this.sendSocketNotification("movement", message)
                  sgarg15 @sdetweil
                  @sdetweil This may be a stupid question, but is there any way i can test this on my laptop, without the raspberry pi?
                    sdetweil @sgarg15
                    @sgarg15 of course. See my comments in .txt file include
                    https://forum.magicmirror.builders/topic/555/txt-file-include/57
                    Not the actual node_helper but the code inside. Of course u can install mm on your PC as well
                    S 3 Replies Last reply Reply Quote 0
                      sgarg15 @sdetweil
                      This post is deleted!
                        sgarg15 @sdetweil
                        var dataFile=["Archer S01E02Someshow.tv",
                        "Archer S01E03Someshow .tv",
                        "Archer S01e02Someshow .tv",
                        "Archer S01E04Someshow .tv",
                        "Archer S01E05someshow .tv",
                        "Archer s01E02Someshow .tv",
                        "Archer S01E09Someshow .tv",
                        var counter1=10
                                            if(dataFile){
                                                var output_list= [];
                                                // should make this a config variable by adding to module defaults
                                               // then would be this.config.counter
                                               // get display limit, 10 if not specified in defaults
                                               var counter=counter1 || 10
                                                // setup regex, no i  no g (only once, and case sensitive)
                                                var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/;
                                                // loop thru the list of filenames
                                                for(filename of dataFile) {
                                                    // if the name is not zero length (split could have returned for just linefeed
                                                    if(filename.length >0 && counter >0) {
                                                       // get the filename prefix
                                                       var split = splitRegExp.exec(filename);
                                                       // save name to the output list, as a table entry
                                                       // remove space after the ->< , the forum hides everything after unless a space
                                                       // table has a row,
                                                       output_list.push("<tr><td>")
                                                       // with data
                                                       if(split)
                                                          output_list.push(split)
                                                       else
                                                           output_list.push('name not matched '+ filename)
                                                       // end of data and row
                                                       output_list.push("</td></tr>")
                                                       counter--;
                                                // insert the table into the wrapper
                                    console.log( "<table>" + output_list.join('')+ "</table>");
                        This correct?
                          sgarg15 @sdetweil
                          @sdetweil Also how do i make it so that the python file is always running?
                            sdetweil @sgarg15
                            @sgarg15 that was the example of running a little js app on the command line node js_filename
                            The exact code here doesn’t help you, but the prior code I posted is what u want to try. Altho I don’t know how u will hook it to the sensors on your pc
                              @sgarg15 your python PGM has to loop somehow. I don’t do python
                                sgarg15
                                @sdetweil so, i have my python script running in the background, and in my nodeHelper.js i would have
                                let pyshell = new PythonShell('Swiping.py');  // < --- whatever your script name, in the module folder
                                could you explain what movement and message mean in the sendSocketNotification?
                                • E Offline
                                  ertopps Banned
                                    sdetweil @ertopps
                                    @ertopps do what?
                                    • E Offline
                                      ertopps Banned
                                      I am stuck due to similar issues. And now I need some professional developers with Python knowledge and good programming skills. I am from the US, check this out. And you need to be able during my working hours, it will be a great advantage for fruitful cooperation. Send me a message to my private box for more details. I do hope to find someone here with your assistance.
